cs_mesh_warping.h
1#ifndef __CS_MESH_WARPING_H__
2#define __CS_MESH_WARPING_H__
5 * Cut warped faces in serial or parallel with/without periodicity.
31 * Local headers
34#include "base/cs_base.h"
35#include "mesh/cs_mesh.h"
36
37/*----------------------------------------------------------------------------*/
38
41/*============================================================================
42 * Macro definitions
43 *============================================================================*/
45/*============================================================================
46 * Type definitions
48
49/*=============================================================================
50 * Public function prototypes
52
53/*----------------------------------------------------------------------------
54 * Cut warped faces.
55 *
56 * Updates border face connectivity and associated mesh quantities.
57 *
58 * parameters:
59 * mesh <-> pointer to mesh structure.
60 * max_warp_angle <-- criterion to know which face to cut
61 * post_flag <-- 1 if we have to post-process cut faces, 0 otherwise
62 *----------------------------------------------------------------------------*/
63
64void
66 double max_warp_angle,
67 bool post_flag);
68
69/*----------------------------------------------------------------------------
70 * Set defaults for cutting of warped faces.
71 *
72 * parameters:
73 * max_warp_angle <-- maximum warp angle (in degrees) over which faces will
74 * be cut; negative (-1) if faces should not be cut
75 * postprocess <-- 1 if postprocessing should be activated when cutting
76 * warped faces, 0 otherwise
77 *----------------------------------------------------------------------------*/
78
79void
80cs_mesh_warping_set_defaults(double max_warp_angle,
81 int postprocess);
82
83/*----------------------------------------------------------------------------
84 * Get defaults for cutting of warped faces.
85 *
86 * parameters:
87 * max_warp_angle --> if non-null, returns maximum warp angle (in degrees)
88 * over which faces will be cut, or -1 if faces should
89 * not be cut
90 * postprocess --> if non-null, returns 1 if postprocessing should be
91 * activated when cutting warped faces, 0 otherwise
92 *----------------------------------------------------------------------------*/
93
94void
95cs_mesh_warping_get_defaults(double *max_warp_angle,
96 int *postprocess);
97
98/*----------------------------------------------------------------------------*/
99
101
102#endif /* __CS_MESH_WARPING_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:543
void cs_mesh_warping_cut_faces(cs_mesh_t *mesh, double max_warp_angle, bool post_flag)
Cut warped boundary faces.
Definition cs_mesh_warping.cpp:542
void cs_mesh_warping_get_defaults(double *max_warp_angle, int *postprocess)
Definition cs_mesh_warping.cpp:702
void cs_mesh_warping_set_defaults(double max_warp_angle, int postprocess)
Definition cs_mesh_warping.cpp:678
Definition mesh.f90:26
Definition cs_mesh.h:85
