◆ CS_BAD_CELL_GUILT
#define CS_BAD_CELL_GUILT (1 << 4) |
◆ CS_BAD_CELL_LSQ_GRAD
#define CS_BAD_CELL_LSQ_GRAD (1 << 2) |
◆ CS_BAD_CELL_OFFSET
#define CS_BAD_CELL_OFFSET (1 << 1) |
◆ CS_BAD_CELL_ORTHO_NORM
#define CS_BAD_CELL_ORTHO_NORM (1 << 0) |
◆ CS_BAD_CELL_RATIO
#define CS_BAD_CELL_RATIO (1 << 3) |
◆ CS_BAD_CELL_TO_REGULARIZE
#define CS_BAD_CELL_TO_REGULARIZE (1 << 6) |
◆ CS_BAD_CELL_USER
#define CS_BAD_CELL_USER (1 << 5) |
◆ cs_mesh_bad_cells_detect()
Compute bad cell quality indicators.
- Parameters
[in] | mesh | pointer to associated mesh structure |
[in,out] | mesh_quantities | pointer to associated mesh quantities structure |
◆ cs_mesh_bad_cells_get_options()
void cs_mesh_bad_cells_get_options |
int | compute[2], |
int | visualize[2] ) |
Indicate which cell quality indicators are used and when.
Each array is optional, and returns 2 flags; the first flag is used at initialization, the second one at each time step.
A flag is a mask to be compared using an "and" (&) operation with a given criteria type mask (CS_BAD_CELL_ORTHO_NORM, CS_BAD_CELL_OFFSET, ...).
- Parameters
[out] | compute | computation mask (initialization, per time step), or nullptr |
[out] | visualize | visualization mask (initialization, per time step), or nullptr |
◆ cs_mesh_bad_cells_postprocess()
Post-process time-independent bad cell quality indicators.
- Parameters
[in] | mesh_quantities | pointer to associated mesh quantities structure |
◆ cs_mesh_bad_cells_set_options()
void cs_mesh_bad_cells_set_options |
int | type_flag_mask, |
int | compute, |
int | visualize ) |
Define which cell quality indicators are used and when.
- Note
- We assume that if a given criterion is computed at each time step, it is also computed at initialization, but for visualization, it is either one or the other, as visualization formats and tools may not always accept both a fixed and time-varying instance of a given variable.
- Parameters
[in] | type_flag_mask | criterion type mask (0 for all) |
[in] | compute | 0: never compute; 1: compute at initialization; 2: compute at each time step |
[in] | visualize | 0: never visualize 1: visualize at initialization; 2: visualize at each time step |
