1#ifndef __CS_MACFB_MONOLITHIC_H__
2#define __CS_MACFB_MONOLITHIC_H__
159 void *scheme_context);
175 void *scheme_context);
192 void *scheme_context);
211 void *scheme_context);
int cs_boundary_type_t
Definition cs_boundary.h:69
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
cs_real_t * cs_equation_get_face_values(const cs_equation_t *eq, bool previous)
For a given equation, retrieve an array of values related to each face of the mesh for the unknowns.
Definition cs_equation.cpp:3221
cs_equation_t * cs_equation_by_name(const char *eqname)
Find the cs_equation_t structure with name eqname Return null if not find.
Definition cs_equation.cpp:503
void * cs_macfb_monolithic_init_scheme_context(const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *bf_type, void *cc_context)
Initialize a cs_macfb_monolithic_t structure.
Definition cs_macfb_monolithic.cpp:1043
void cs_macfb_monolithic_steady_nl(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Solve the steady Navier-Stokes system with a MAC face-based scheme using a monolithic approach and Pi...
Definition cs_macfb_monolithic.cpp:1396
void cs_macfb_monolithic(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Solve the unsteady Navier-Stokes system with a MAC face-based scheme using a monolithic approach....
Definition cs_macfb_monolithic.cpp:1565
void cs_macfb_monolithic_steady(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Solve the steady Navier-Stokes system with a MAC face-based scheme using a monolithic approach.
Definition cs_macfb_monolithic.cpp:1315
void cs_macfb_monolithic_init_sharing(const cs_equation_param_t *mom_eqp, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Definition cs_macfb_monolithic.cpp:982
void cs_macfb_monolithic_nl(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Definition cs_macfb_monolithic.cpp:1644
void cs_macfb_monolithic_finalize_common(void)
Free shared pointers with lifecycle dedicated to this file.
Definition cs_macfb_monolithic.cpp:1025
void * cs_macfb_monolithic_free_scheme_context(void *scheme_context)
Destroy a cs_macfb_monolithic_t structure.
Definition cs_macfb_monolithic.cpp:1269
static cs_real_t * cs_macfb_monolithic_get_face_velocity(bool previous)
Retrieve the values of the velocity on the faces.
Definition cs_macfb_monolithic.h:77
Definition cs_advection_field.h:151
Definition cs_cdo_connect.h:61
Definition cs_cdo_quantities.h:145
Definition cs_equation_param.h:193
Definition cs_navsto_param.h:263
time step descriptor
Definition cs_time_step.h:64
