struct | cs_inflow_sem_t |
typedef struct _cs_inlet_t | cs_inlet_t |
Enumerations | |
enum | cs_les_inflow_type_t { CS_INFLOW_LAMINAR , CS_INFLOW_RANDOM , CS_INFLOW_BATTEN , CS_INFLOW_SEM } |
void | cs_les_inflow_initialize (void) |
Creation of structures for the LES inflows. | |
void | cs_les_inflow_finalize (void) |
Finalize turbulent inflow generation API. | |
void | cs_les_inflow_add_inlet (cs_les_inflow_type_t type, bool volume_mode, const cs_zone_t *zone, int n_entities, int verbosity, const cs_real_t *vel_r, cs_real_t k_r, cs_real_t eps_r) |
Add an inlet definition for synthetic turbulence inflow generation. | |
void | cs_les_inflow_compute (void) |
General synthetic turbulence generation. | |
void | cs_les_synthetic_eddy_restart_read (void) |
void | cs_les_synthetic_eddy_restart_write (void) |
void | cs_les_synthetic_eddy_method (cs_lnum_t n_points, const cs_lnum_t elt_ids[], const cs_real_3_t point_coordinates[], const cs_real_t *point_weight, int initialize, int verbosity, cs_inflow_sem_t *inflow, cs_real_t t_cur, const cs_real_3_t vel_m_l[], const cs_real_6_t rij_l[], const cs_real_t eps_l[], cs_real_3_t fluctuations[]) |
Generation of synthetic turbulence via the Synthetic Eddy Method (SEM). | |
void | cs_les_rescale_fluctuations (cs_lnum_t n_points, const cs_real_6_t statistics[], cs_real_3_t fluctuations[]) |
Rescale fluctuations by statistics following the Lund method. | |
void | cs_les_synthetic_eddy_set_n_restart_structures (int n_structures) |
Set number of structures used for volume SEM when restarting from another turbulence model. | |
int | cs_les_synthetic_eddy_get_n_restart_structures (void) |
Return number of structures used for volume SEM when restarting from another turbulence model. | |
void | cs_les_inflow_get_restart (bool *allow_read, bool *allow_write) |
Query behavior of the LES inflow module in case of restart. | |
void | cs_les_inflow_set_restart (bool allow_read, bool allow_write) |
Define behavior of the LES inflow module in case of restart. | |
void | cs_user_les_inflow_define (void) |
Define parameters of synthetic turbulence at LES inflow. | |
void | cs_user_les_inflow_update (const cs_zone_t *zone, cs_real_t vel_r[3], cs_real_t *k_r, cs_real_t *eps_r) |
Update of the characteristics of a given synthetic turbulence inlet. | |
void | cs_user_les_inflow_advanced (const cs_zone_t *zone, cs_real_3_t vel_l[], cs_real_6_t rij_l[], cs_real_t eps_l[]) |
Definition of mean velocity, Reynolds stresses and dissipation rate for each boundary face of the given synthetic turbulence inlet. |
typedef struct _cs_inlet_t cs_inlet_t |
enum cs_les_inflow_type_t |
void cs_les_inflow_add_inlet | ( | cs_les_inflow_type_t | type, |
bool | volume_mode, | ||
const cs_zone_t * | zone, | ||
int | n_entities, | ||
int | verbosity, | ||
const cs_real_t * | vel_r, | ||
cs_real_t | k_r, | ||
cs_real_t | eps_r ) |
[out] | type | type of inflow method at the inlet |
[out] | volume_mode | if true, generate turbulence over the whole domain (only if type is CS_INFLOW_SEM) |
[in] | zone | pointer to associated boundary zone |
[out] | n_entities | number of structures or modes |
[out] | verbosity | verbosity level |
[out] | vel_r | reference mean velocity |
[out] | k_r | reference turbulent kinetic energy |
[out] | eps_r | reference turbulent dissipation |
void cs_les_inflow_compute | ( | void | ) |
void cs_les_inflow_finalize | ( | void | ) |
See cs_les_synthetic_eddy_set_restart for details.
[out] | allow_read | pointer to read flag, or NULL |
[out] | allow_write | pointer to write flag, or NULL |
[out] | allow_read | pointer to read flag, or nullptr |
[out] | allow_write | pointer to write flag, or nullptr |
void cs_les_inflow_initialize | ( | void | ) |
By default, a restart file is read if present, and a checkpoint written. If not read, synthetic fluctuations are re-initialized.
[in] | allow_read | allow reading a relevant checkpoint if present |
[in] | allow_write | allow writing a relevant checkpoint if present |
By default, a specific file is read if present in the restart folder, and files written in the checkpoint folder at global checkpoint intervals.
void cs_les_rescale_fluctuations | ( | cs_lnum_t | n_points, |
const cs_real_6_t | statistics[], | ||
cs_real_3_t | fluctuations[] ) |
One assumes that the statistics are interlaced and ordered as follows: <u'u'> <v'v'> <w'w'> <u'v'> <v'w'> <u'w'>
[in] | n_points | local number of points where turbulence is generated |
[in] | statistics | statistics (i.e. Reynolds stresses) |
[in,out] | fluctuations | velocity fluctuations generated |
int cs_les_synthetic_eddy_get_n_restart_structures | ( | void | ) |
void cs_les_synthetic_eddy_method | ( | cs_lnum_t | n_points, |
const cs_lnum_t | elt_ids[], | ||
const cs_real_3_t | point_coordinates[], | ||
const cs_real_t * | point_weight, | ||
int | initialize, | ||
cs_inflow_sem_t * | inflow, | ||
cs_real_t | t_cur, | ||
const cs_real_3_t | vel_m_l[], | ||
const cs_real_6_t | rij_l[], | ||
const cs_real_t | eps_l[], | ||
[in] | elt_ids | local id of inlet elements |
[in] | point_coordinates | point coordinates |
[in] | point_weight | point weights (surface, volume or NULL) |
[in] | initialize | initialization indicator |
[in] | verbosity | verbosity level |
[in] | inflow | pointer to structure for Batten method |
[in] | t_cur | current time |
[in] | vel_m_l | mean velocity at each point |
[in] | rij_l | reynolds stresses at each point |
[in] | eps_l | dissipation rate at each point |
[out] | fluctuations | velocity fluctuations at each point |
[in] | elt_ids | local id of inlet boundary faces |
[in] | point_weight | point weights (surface, volume or nullptr) |
[in] | rij_l | Reynolds stresses at each point |
void cs_les_synthetic_eddy_restart_read | ( | void | ) |
void cs_les_synthetic_eddy_restart_write | ( | void | ) |
void cs_les_synthetic_eddy_set_n_restart_structures | ( | int | n_structures | ) |
[in] | n_structures | number of structures for initialization |
void cs_user_les_inflow_advanced | ( | const cs_zone_t * | zone, |
cs_real_3_t | vel_l[], | ||
cs_real_t | eps_l[] ) |
Accurate definition of mean velocity, Reynolds stresses and dissipation rate for each boundary face of the given synthetic turbulence inlet
Rij components are ordered as usual: XX, YY, ZZ, XY, YZ, XZ
Arrays are pre-initialized before this function is called (see cs_user_les_inflow_define).
vel_l[face_id][coo_id] = vel_r[coo_id]
rij_l[face_id][0] = 2./3. * k_l rij_l[face_id][1] = 2./3. * k_l rij_l[face_id][2] = 2./3. * k_l rij_l[face_id][3] = 0 rij_l[face_id][4] = 0 rij_l[face_id][5] = 0
eps_l[face_id] = eps_r
[in,out] | vel_l | velocity a zone faces |
[in,out] | rij_l | reynods stresses at zone faces |
[in,out] | eps_l | reference turbulent dissipation |
void cs_user_les_inflow_define | ( | void | ) |
void cs_user_les_inflow_update | ( | const cs_zone_t * | zone, |
cs_real_t | vel_r[3], | ||
cs_real_t * | k_r, | ||
cs_real_t * | eps_r ) |
