| void | cs_lagr_sde (cs_real_t dt_p, const cs_real_t **taup, const cs_real_3_t **tlag, const cs_real_3_t **piil, const cs_real_33_t **bx, cs_real_t tsfext[], cs_real_3_t *force_p, cs_real_t terbru[], const cs_real_t vislen[], const cs_real_3_t **beta, cs_lnum_t *nresnew) |
| | Integration of particle equations of motion:
| void | cs_lagr_sde_attr (cs_lagr_attribute_t attr, cs_real_t *tcarac, cs_real_t *pip) |
| | Integration of a stochastic differential equation (SDE) for a user particle variable (attribute).
◆ cs_lagr_sde()
| void cs_lagr_sde |
cs_real_t | dt_p, |
const cs_real_t ** | taup, |
const cs_real_3_t ** | tlag, |
const cs_real_3_t ** | piil, |
const cs_real_33_t ** | bx, |
cs_real_t | tsfext[], |
cs_real_3_t * | force_p, |
cs_real_t | terbru[], |
const cs_real_t | vislen[], |
const cs_real_3_t ** | beta, |
cs_lnum_t * | nresnew ) |
- Standard Model : First or second order
- Deposition submodel (Guingo & Minier, 2008) if needed
- Parameters
| [in] | dt_p | lagrangian time step |
| [in] | taup | dynamic characteristic time |
| [in] | tlag | fluid characteristic time |
| [in] | piil | terme in P-U SDE integration |
| [in] | bx | turbulence characteristics |
| [out] | tsfext | info for return coupling source terms |
| [out] | force_p | forces per mass unit on particles (m/s^2) |
| [out] | terbru | Diffusion coefficient accounting for Brownian (molecular) effect |
| [in] | vislen | nu/u* = y/y+ |
| [in] | beta | proportional to the gradient of T_lag |
- Parameters
| [in] | piil | term in integration of U-P SDEs |
◆ cs_lagr_sde_attr()
When there is interaction with a boundary face, the integration degenerates to order 1 (even if the 2nd order scheme is active).
- Parameters
| [in] | attr | attribute/variable |
| [in] | tcarac | variable characteristic time |
autotoc_md54
- Parameters
| [in] | pip | right-hand side associated with SDE |
- Parameters
