cs_gui_mesh.h
1#ifndef __CS_GUI_MESH_H__
2#define __CS_GUI_MESH_H__
5 * Management of the GUI parameters file: mesh related options
31 * Local headers
34#include "base/cs_base.h"
35#include "mesh/cs_mesh.h"
36
37/*----------------------------------------------------------------------------*/
38
41/*============================================================================
42 * Public function prototypes for Fortran API
43 *============================================================================*/
45/*============================================================================
46 * Public function prototypes
48
49/*-----------------------------------------------------------------------------
50 * Determine the mesh restart mode.
51 *----------------------------------------------------------------------------*/
52
53void
55
56/*-----------------------------------------------------------------------------
57 * Determine whether warped faces should be cut.
58 *----------------------------------------------------------------------------*/
59
60void
62
63/*-----------------------------------------------------------------------------
64 * Define joinings using a GUI-produced XML file.
65 *----------------------------------------------------------------------------*/
66
67void
69
70/*-----------------------------------------------------------------------------
71 * Define periodicities using a GUI-produced XML file.
72 *----------------------------------------------------------------------------*/
73
74void
76
77/*----------------------------------------------------------------------------
78 * Mesh smoothing.
79 *
80 * parameters:
81 * mesh <-> pointer to mesh structure to smoothe
82 *----------------------------------------------------------------------------*/
83
84void
86
87/*----------------------------------------------------------------------------
88 * Define user thin wall through the GUI.
89 *----------------------------------------------------------------------------*/
90
91void
93
94/*----------------------------------------------------------------------------
95 * Define user mesh extrude through the GUI.
96 *----------------------------------------------------------------------------*/
97
98void
100
101/*----------------------------------------------------------------------------
102 * Define mesh save behavior trough the GUI.
103 *----------------------------------------------------------------------------*/
104
105void
107
108/*----------------------------------------------------------------------------
109 * Read cartesian mesh parameters defined with GUI.
110 *----------------------------------------------------------------------------*/
111
112void
114
115/*----------------------------------------------------------------------------*/
116
118
119#endif /* __CS_GUI_MESH_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:543
void cs_gui_mesh_restart_mode(void)
Definition cs_gui_mesh.cpp:294
void cs_gui_mesh_save_if_modified(cs_mesh_t *mesh)
Definition cs_gui_mesh.cpp:665
void cs_gui_mesh_extrude(cs_mesh_t *mesh)
Definition cs_gui_mesh.cpp:607
void cs_gui_mesh_define_periodicities(void)
Definition cs_gui_mesh.cpp:418
void cs_gui_mesh_warping(void)
Definition cs_gui_mesh.cpp:328
void cs_gui_mesh_define_joinings(void)
Definition cs_gui_mesh.cpp:366
void cs_gui_mesh_smoothe(cs_mesh_t *mesh)
Definition cs_gui_mesh.cpp:516
void cs_gui_mesh_cartesian_define(void)
Definition cs_gui_mesh.cpp:694
void cs_gui_mesh_boundary(cs_mesh_t *mesh)
Definition cs_gui_mesh.cpp:567
Definition mesh.f90:26
Definition cs_mesh.h:85
