cs_grid.h
1#ifndef __CS_GRID_H__
2#define __CS_GRID_H__
5 * Grid connectivity and data used for multigrid coarsening
6 * and associated matrix construction.
7 *============================================================================*/
8
9/*
10 This file is part of code_saturne, a general-purpose CFD tool.
11
12 Copyright (C) 1998-2025 EDF S.A.
13
14 This program is free software; you can redistribute it and/or modify it under
15 the terms of the GNU General Public License as published by the Free Software
16 Foundation; either version 2 of the License, or (at your option) any later
17 version.
18
19 This program is distributed in the hope that it will be useful, but WITHOUT
20 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
21 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
22 details.
23
24 You should have received a copy of the GNU General Public License along with
25 this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
26 Street, Fifth Floor, Boston, MA 02110-1301, USA.
27*/
28
29/*----------------------------------------------------------------------------*/
30
31/*----------------------------------------------------------------------------
32 * Local headers
33 *----------------------------------------------------------------------------*/
34
35#include "base/cs_base.h"
36
37#include "base/cs_dispatch.h"
38#include "base/cs_halo.h"
39#include "alge/cs_matrix.h"
45/*============================================================================
46 * Macro definitions
48
50 * Type definitions
52
53/* Aggregation algorithm */
54
65
66/* Structure associated with opaque grid object */
67
68typedef struct _cs_grid_t cs_grid_t;
69
70/*============================================================================
71 * Global variables
72 *============================================================================*/
73
74/* Names for coarsening options */
75
76extern const char *cs_grid_coarsening_type_name[];
77
78/*============================================================================
79 * Semi-private function prototypes
80 *
81 * The following functions are intended to be used by the multigrid layer
82 * (cs_multigrid.c), not directly by the user, so they are no more
83 * documented than private static functions)
84 *============================================================================*/
85
86/*----------------------------------------------------------------------------
87 * Create base grid by mapping from shared mesh values.
88 *
89 * Note that as arrays given as arguments are shared by the created grid
90 * (which can only access them, not modify them), the grid should be
91 * destroyed before those arrays.
92 *
93 * parameters:
94 * n_faces <-- Local number of faces
95 * db_size <-- Block sizes for diagonal
96 * eb_size <-- Block sizes for extra-diagonal
97 * face_cell <-- Face -> cells connectivity
98 * a <-- Associated matrix
99 * conv_diff <-- Convection-diffusion mode
100 *
101 * returns:
102 * base grid structure
103 *----------------------------------------------------------------------------*/
104
105cs_grid_t *
107 cs_lnum_t db_size,
108 cs_lnum_t eb_size,
109 const cs_lnum_2_t *face_cell,
110 const cs_matrix_t *a,
111 bool conv_diff);
112
113/*----------------------------------------------------------------------------
114 * Create base grid by mapping from parent (possibly shared) matrix.
115 *
116 * Note that as arrays given as arguments are shared by the created grid
117 * (which can only access them, not modify them), the grid should be
118 * destroyed before those arrays.
119 *
120 * parameters:
121 * a <-- associated matrix
122 * n_ranks <-- number of active ranks (<= 1 to restrict to local values)
123 *
124 * returns:
125 * base grid structure
126 *----------------------------------------------------------------------------*/
127
128cs_grid_t *
130 int n_ranks);
131
132/*----------------------------------------------------------------------------
133 * Destroy a grid structure.
134 *
135 * parameters:
136 * grid <-> Pointer to grid structure pointer
137 *----------------------------------------------------------------------------*/
138
139void
141
142/*----------------------------------------------------------------------------
143 * Free a grid structure's associated quantities.
144 *
145 * The quantities required to compute a coarser grid with relaxation from a
146 * given grid are not needed after that stage, so may be freed.
147 *
148 * parameters:
149 * g <-> Pointer to grid structure
150 *----------------------------------------------------------------------------*/
151
152void
154
155/*----------------------------------------------------------------------------
156 * Get grid information.
157 *
158 * parameters:
159 * g <-- Grid structure
160 * level --> Level in multigrid hierarchy (or NULL)
161 * symmetric --> Symmetric matrix coefficients indicator (or NULL)
162 * db_size --> Size of the diagonal block (or NULL)
163 * eb_size --> Size of the extra diagonal block (or NULL)
164 * n_ranks --> number of ranks with data (or NULL)
165 * n_rows --> Number of local rows (or NULL)
166 * n_cols_ext --> Number of columns including ghosts (or NULL)
167 * n_entries --> Number of entries (or NULL)
168 * n_g_rows --> Number of global rows (or NULL)
169 *----------------------------------------------------------------------------*/
170
171void
173 int *level,
174 bool *symmetric,
175 cs_lnum_t *db_size,
176 cs_lnum_t *eb_size,
177 int *n_ranks,
178 cs_lnum_t *n_rows,
179 cs_lnum_t *n_cols_ext,
180 cs_lnum_t *n_entries,
181 cs_gnum_t *n_g_rows);
182
183/*----------------------------------------------------------------------------
184 * Get memory allocation mode corresponding to a grid.
185 *
186 * parameters:
187 * g <-- Grid structure
188 *
189 * returns:
190 * memory allocation typt
191 *----------------------------------------------------------------------------*/
192
195
196/*----------------------------------------------------------------------------
197 * Get number of rows corresponding to a grid.
198 *
199 * parameters:
200 * g <-- Grid structure
201 *
202 * returns:
203 * number of rows of grid structure
204 *----------------------------------------------------------------------------*/
205
208
209/*----------------------------------------------------------------------------
210 * Get number of extended (local + ghost) columns corresponding to a grid.
211 *
212 * parameters:
213 * g <-- Grid structure
214 *
215 * returns:
216 * number of extended columns of grid structure
217 *----------------------------------------------------------------------------*/
218
221
222/*----------------------------------------------------------------------------
223 * Get maximum number of extended (local + ghost) columns corresponding to
224 * a grid, both with and without merging between ranks
225 *
226 * parameters:
227 * g <-- Grid structure
228 *
229 * returns:
230 * maximum number of extended columns of grid structure, with or without
231 * merging
232 *----------------------------------------------------------------------------*/
233
236
237/*----------------------------------------------------------------------------
238 * Get global number of rows corresponding to a grid.
239 *
240 * parameters:
241 * g <-- Grid structure
242 *
243 * returns:
244 * global number of rows of grid structure
245 *----------------------------------------------------------------------------*/
246
249
250/*----------------------------------------------------------------------------
251 * Get grid's associated matrix information.
252 *
253 * parameters:
254 * g <-- Grid structure
255 *
256 * returns:
257 * pointer to matrix structure
258 *----------------------------------------------------------------------------*/
259
260const cs_matrix_t *
262
263#if defined(HAVE_MPI)
264
265/*----------------------------------------------------------------------------
266 * Get the MPI subcommunicator for a given grid.
267 *
268 * parameters:
269 * g <-- Grid structure
270 *
271 * returns:
272 * MPI communicator
273 *----------------------------------------------------------------------------*/
274
275MPI_Comm
276cs_grid_get_comm(const cs_grid_t *g);
277
278/*----------------------------------------------------------------------------
279 * Get the MPI subcommunicator for a given merge stride.
280 *
281 * parameters:
282 * parent <-- parent MPI communicator
283 * merge_stride <-- associated merge stride
284 *
285 * returns:
286 * MPI communicator
287 *----------------------------------------------------------------------------*/
288
289MPI_Comm
290cs_grid_get_comm_merge(MPI_Comm parent,
291 int merge_stride);
292
293#endif
294
295/*----------------------------------------------------------------------------
296 * Create coarse grid from fine grid.
297 *
298 * parameters:
299 * f <-- Fine grid structure
300 * alloc_mode <-- Memory allocation mode
301 * coarsening_type <-- Coarsening criteria type
302 * aggregation_limit <-- Maximum allowed fine rows per coarse rows
303 * verbosity <-- Verbosity level
304 * merge_stride <-- Associated merge stride
305 * merge_rows_mean_threshold <-- mean number of rows under which
306 * merging should be applied
307 * merge_rows_glob_threshold <-- global number of rows under which
308 * merging should be applied
309 * relaxation_parameter <-- P0/P1 relaxation factor
310 *
311 * returns:
312 * coarse grid structure
313 *----------------------------------------------------------------------------*/
314
315cs_grid_t *
317 cs_alloc_mode_t alloc_mode,
318 cs_grid_coarsening_t coarsening_type,
319 int aggregation_limit,
320 int verbosity,
321 int merge_stride,
322 int merge_rows_mean_threshold,
323 cs_gnum_t merge_rows_glob_threshold,
324 double relaxation_parameter);
325
326/*----------------------------------------------------------------------------
327 * Create coarse grid with only one row per rank from fine grid.
328 *
329 * parameters:
330 * f <-- Fine grid structure
331 * alloc_mode <-- Memory allocation mode
332 * merge_stride <-- Associated merge stride
333 * verbosity <-- Verbosity level
334 *
335 * returns:
336 * coarse grid structure
337 *----------------------------------------------------------------------------*/
338
339cs_grid_t *
341 cs_alloc_mode_t alloc_mode,
342 int merge_stride,
343 int verbosity);
344
345/*----------------------------------------------------------------------------
346 * Project coarse grid row numbers to base grid.
347 *
348 * If a global coarse grid row number is larger than max_num, its
349 * value modulo max_num is used.
350 *
351 * parameters:
352 * g <-- Grid structure
353 * n_base_rows <-- Number of rows in base grid
354 * max_num <-- Values of c_row_num = global_num % max_num
355 * c_row_num --> Global coarse row number (modulo max_num)
356 *----------------------------------------------------------------------------*/
357
358void
360 cs_lnum_t n_base_rows,
361 int max_num,
362 int c_row_num[]);
363
364/*----------------------------------------------------------------------------
365 * Project coarse grid row rank to base grid.
366 *
367 * parameters:
368 * g <-- Grid structure
369 * n_base_rows <-- Number of rows in base grid
370 * f_row_rank --> Global coarse row rank projected to fine rows
371 *----------------------------------------------------------------------------*/
372
373void
375 cs_lnum_t n_base_rows,
376 int f_row_rank[]);
377
378/*----------------------------------------------------------------------------
379 * Project variable from coarse grid to base grid
380 *
381 * parameters:
382 * g <-- Grid structure
383 * n_base_rows <-- Number of rows in base grid
384 * c_var <-- Row variable on coarse grid
385 * f_var --> Row variable projected to fine grid
386 *----------------------------------------------------------------------------*/
387
388void
390 cs_lnum_t n_base_rows,
391 const cs_real_t c_var[],
392 cs_real_t f_var[]);
393
394/*----------------------------------------------------------------------------
395 * Compute diagonal dominance metric and project it to base grid
396 *
397 * parameters:
398 * g <-- Grid structure
399 * n_base_rows <-- Number of rows in base grid
400 * diag_dom --> Diagonal dominance metric (on fine grid)
401 *----------------------------------------------------------------------------*/
402
403void
405 cs_lnum_t n_base_rows,
406 cs_real_t diag_dom[]);
407
408/*----------------------------------------------------------------------------
409 * Finalize global info related to multigrid solvers
410 *----------------------------------------------------------------------------*/
411
412void
414
415/*----------------------------------------------------------------------------
416 * Dump grid structure
417 *
418 * parameters:
419 * g <-- grid structure that should be dumped
420 *----------------------------------------------------------------------------*/
421
422void
424
426
427#ifdef __cplusplus
428
429/*----------------------------------------------------------------------------
430 * Compute coarse row variable values from fine row values
431 *
432 * parameters:
433 * ctx <-> Reference to dispatch context
434 * f <-- Fine grid structure
435 * c <-- Fine grid structure
436 * f_var <-- Variable defined on fine grid rows
437 * c_var --> Variable defined on coarse grid rows
438 *
439 * returns:
440 * coarse grid structure
441 *----------------------------------------------------------------------------*/
442
443void
444cs_grid_restrict_row_var(cs_dispatch_context &ctx,
445 const cs_grid_t *f,
446 const cs_grid_t *c,
447 const cs_real_t *f_var,
448 cs_real_t *c_var);
449
450/*----------------------------------------------------------------------------
451 * Compute fine row variable values from coarse row values
452 *
453 * parameters:
454 * ctx <-> Reference to dispatch context
455 * c <-- Fine grid structure
456 * f <-- Fine grid structure
457 * increment <-- if true, add value to f_var; otherwise, overwrite it
458 * c_var <-- Variable defined on coarse grid rows
459 * f_var <-> Variable defined on fine grid rows
460 *----------------------------------------------------------------------------*/
461
462void
463cs_grid_prolong_row_var(cs_dispatch_context &ctx,
464 const cs_grid_t *c,
465 const cs_grid_t *f,
466 bool increment,
467 cs_real_t *c_var,
468 cs_real_t *f_var);
469
470#endif
471
473
474/*=============================================================================
475 * Public function prototypes
476 *============================================================================*/
477
478/*----------------------------------------------------------------------------
479 * Set matrix tuning behavior for multigrid coarse meshes.
480 *
481 * The finest mesh (level 0) is handled by the default tuning options,
482 * so only coarser meshes are considered here.
483 *
484 * parameters:
485 * fill_type <-- associated matrix fill type
486 * max_level <-- maximum level for which tuning is active
487 *----------------------------------------------------------------------------*/
488
489void
491 int max_level);
492
493/*----------------------------------------------------------------------------*/
494
496
497#endif /* __CS_GRID_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:342
cs_lnum_t cs_lnum_2_t[2]
Definition cs_defs.h:352
unsigned cs_gnum_t
global mesh entity number
Definition cs_defs.h:327
Definition cs_defs.h:543
Definition cs_defs.h:335
void cs_grid_restrict_row_var(cs_dispatch_context &ctx, const cs_grid_t *f, const cs_grid_t *c, const cs_real_t *f_var, cs_real_t *c_var)
Definition cs_grid.cpp:8966
void cs_grid_prolong_row_var(cs_dispatch_context &ctx, const cs_grid_t *c, const cs_grid_t *f, bool increment, cs_real_t *c_var, cs_real_t *f_var)
Definition cs_grid.cpp:9080
void cs_grid_project_row_num(const cs_grid_t *g, cs_lnum_t n_base_rows, int max_num, int c_row_num[])
cs_grid_t * cs_grid_create_from_parent(const cs_matrix_t *a, int n_ranks)
cs_grid_t * cs_grid_coarsen_to_single(const cs_grid_t *f, cs_alloc_mode_t alloc_mode, int merge_stride, int verbosity)
void cs_grid_dump(const cs_grid_t *g)
cs_lnum_t cs_grid_get_n_cols_ext(const cs_grid_t *g)
cs_grid_t * cs_grid_coarsen(const cs_grid_t *f, cs_alloc_mode_t alloc_mode, cs_grid_coarsening_t coarsening_type, int aggregation_limit, int verbosity, int merge_stride, int merge_rows_mean_threshold, cs_gnum_t merge_rows_glob_threshold, double relaxation_parameter)
Definition cs_grid.h:55
@ CS_GRID_COARSENING_SPD_MX
Definition cs_grid.h:59
@ CS_GRID_COARSENING_DEFAULT
Definition cs_grid.h:57
@ CS_GRID_COARSENING_CONV_DIFF_DX
Definition cs_grid.h:61
@ CS_GRID_COARSENING_SPD_DX
Definition cs_grid.h:58
@ CS_GRID_COARSENING_SPD_PW
Definition cs_grid.h:60
const char * cs_grid_coarsening_type_name[]
cs_alloc_mode_t cs_grid_get_alloc_mode(const cs_grid_t *g)
void cs_grid_project_var(const cs_grid_t *g, cs_lnum_t n_base_rows, const cs_real_t c_var[], cs_real_t f_var[])
const cs_matrix_t * cs_grid_get_matrix(const cs_grid_t *g)
cs_gnum_t cs_grid_get_n_g_rows(const cs_grid_t *g)
void cs_grid_set_matrix_tuning(cs_matrix_fill_type_t fill_type, int max_level)
Definition cs_grid.cpp:8924
cs_lnum_t cs_grid_get_n_rows(const cs_grid_t *g)
void cs_grid_project_diag_dom(const cs_grid_t *g, cs_lnum_t n_base_rows, cs_real_t diag_dom[])
Definition cs_grid.h:68
cs_grid_t * cs_grid_create_from_shared(cs_lnum_t n_faces, cs_lnum_t db_size, cs_lnum_t eb_size, const cs_lnum_2_t *face_cell, const cs_matrix_t *a, bool conv_diff)
cs_lnum_t cs_grid_get_n_cols_max(const cs_grid_t *g)
void cs_grid_project_row_rank(const cs_grid_t *g, cs_lnum_t n_base_rows, int f_row_rank[])
void cs_grid_destroy(cs_grid_t **grid)
void cs_grid_finalize(void)
void cs_grid_get_info(const cs_grid_t *g, int *level, bool *symmetric, cs_lnum_t *db_size, cs_lnum_t *eb_size, int *n_ranks, cs_lnum_t *n_rows, cs_lnum_t *n_cols_ext, cs_lnum_t *n_entries, cs_gnum_t *n_g_rows)
void cs_grid_free_quantities(cs_grid_t *g)
Definition cs_matrix.h:110
Definition cs_matrix.h:72
cs_alloc_mode_t
Definition cs_mem.h:50
