#include "base/cs_base.h"#include "base/cs_halo.h"#include "base/cs_internal_coupling.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_quantities.h"Go to the source code of this file.
Enumerations | |
| enum | cs_gradient_type_t { CS_GRADIENT_GREEN_ITER , CS_GRADIENT_LSQ , CS_GRADIENT_GREEN_LSQ , CS_GRADIENT_GREEN_VTX , CS_GRADIENT_GREEN_R } |
| enum | cs_gradient_limit_t { CS_GRADIENT_LIMIT_NONE = -1 , CS_GRADIENT_LIMIT_CELL = 0 , CS_GRADIENT_LIMIT_FACE = 1 } |
| void | cs_gradient_initialize (void) |
| Initialize gradient computation API. | |
| void | cs_gradient_finalize (void) |
| Finalize gradient computation API. | |
| void | cs_gradient_free_quantities (void) |
| Free saved gradient quantities. | |
| void | cs_gradient_scalar (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int hyd_p_flag, int w_stride, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, cs_real_3_t f_ext[], const cs_field_bc_coeffs_t *bc_coeffs, cs_real_t var[], cs_real_t *c_weight, const cs_internal_coupling_t *cpl, cs_real_t grad[][3]) |
| void | cs_gradient_vector (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_field_bc_coeffs_t *bc_coeffs_v, cs_real_t var[][3], cs_real_t *c_weight, const cs_internal_coupling_t *cpl, cs_real_t gradv[][3][3]) |
| void | cs_gradient_tensor (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_field_bc_coeffs_t *bc_coeffs_ts, cs_real_6_t *var, cs_real_63_t *grad) |
| void | cs_gradient_scalar_synced_input (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int hyd_p_flag, int w_stride, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, cs_real_t f_ext[][3], const cs_field_bc_coeffs_t *bc_coeffs, const cs_real_t var[], const cs_real_t *c_weight, const cs_internal_coupling_t *cpl, cs_real_t grad[][3]) |
| void | cs_gradient_vector_synced_input (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_field_bc_coeffs_t *bc_coeffs_v, const cs_real_t var[][3], const cs_real_t val_f[][3], const cs_real_t c_weight[], const cs_internal_coupling_t *cpl, cs_real_t grad[][3][3]) |
| Compute cell gradient of vector field. | |
| void | cs_gradient_tensor_synced_input (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_field_bc_coeffs_t *bc_coeffs_ts, const cs_real_t var[][6], const cs_real_t val_f[][6], cs_real_63_t *grad) |
| Compute cell gradient of tensor. | |
| void | cs_gradient_scalar_cell (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_field_bc_coeffs_t *bc_coeffs, const cs_real_t var[], const cs_real_t c_weight[], cs_real_t grad[3]) |
| Compute the gradient of a scalar field at a given cell using least-squares reconstruction. | |
| void | cs_gradient_vector_cell (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_field_bc_coeffs_t *bc_coeffs_v, const cs_real_t var[][3], const cs_real_t c_weight[], cs_real_t grad[3][3]) |
| Compute the gradient of a vector field at a given cell using least-squares reconstruction. | |
| void | cs_gradient_tensor_cell (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_field_bc_coeffs_t *bc_coeffs_ts, const cs_real_t var[][6], const cs_real_t c_weight[], cs_real_t grad[6][3]) |
| Compute the gradient of a tensor field at a given cell using least-squares reconstruction. | |
| void | cs_gradient_type_by_imrgra (int imrgra, cs_gradient_type_t *gradient_type, cs_halo_type_t *halo_type) |
| void | cs_gradient_porosity_balance (int inc) |
| compute the steady balance due to porous modelling for the pressure gradient. | |
| const char * | cs_gradient_type_name [] |
| enum cs_gradient_limit_t |
| enum cs_gradient_type_t |
| void cs_gradient_finalize | ( | void | ) |
| void cs_gradient_free_quantities | ( | void | ) |
| void cs_gradient_initialize | ( | void | ) |
| void cs_gradient_porosity_balance | ( | int | inc | ) |
| void cs_gradient_scalar | ( | const char * | var_name, |
| cs_gradient_type_t | gradient_type, | ||
| int | inc, | ||
| int | n_r_sweeps, | ||
| int | hyd_p_flag, | ||
| int | w_stride, | ||
| int | verbosity, | ||
| cs_gradient_limit_t | clip_mode, | ||
| double | epsilon, | ||
| double | clip_coeff, | ||
| cs_real_3_t | f_ext[], | ||
| cs_real_t | var[], | ||
| cs_real_t * | c_weight, | ||
| cs_real_t | grad[][3] ) |
| void cs_gradient_scalar_cell | ( | const cs_mesh_t * | m, |
| cs_lnum_t | c_id, | ||
| cs_real_t | grad[3] ) |
When boundary conditions are provided, both the bc_coeff_a and bc_coeff_b arrays must be given. If boundary values are known, bc_coeff_a can point to the boundary values array, and bc_coeff_b set to nullptr. If bc_coeff_a is nullptr, bc_coeff_b is ignored.
| [in] | c_id | cell id |
| [in] | bc_coeffs | boundary condition structure |
| [in] | var | gradient's base variable |
| [in] | c_weight | cell variable weight, or nullptr |
| [out] | grad | gradient |
| void cs_gradient_scalar_synced_input | ( | const char * | var_name, |
| int | inc, | ||
| cs_real_t | f_ext[][3], | ||
| const cs_real_t * | c_weight, | ||
| void cs_gradient_tensor | ( | const char * | var_name, |
| int | inc, | ||
| const cs_field_bc_coeffs_t * | bc_coeffs_ts, | ||
| cs_real_6_t * | var, | ||
| cs_real_63_t * | grad ) |
| void cs_gradient_tensor_cell | ( | const cs_mesh_t * | m, |
| const cs_real_t | var[][6], | ||
| cs_real_t | grad[6][3] ) |
| [in] | bc_coeffs_ts | boundary condition structure |
| void cs_gradient_tensor_synced_input | ( | const char * | var_name, |
| int | inc, | ||
| const cs_real_t | val_f[][6], | ||
| [in] | var_name | variable name |
| [in] | gradient_type | gradient type |
| [in] | n_r_sweeps | if > 1, number of reconstruction sweeps (only used by CS_GRADIENT_GREEN_ITER) |
| [in] | clip_mode | clipping mode |
| [in] | epsilon | precision for iterative gradient calculation |
| [in] | clip_coeff | clipping coefficient |
| [out] | grad | gradient ( |
| void cs_gradient_type_by_imrgra | ( | int | imrgra, |
| cs_gradient_type_t * | gradient_type, | ||
| cs_halo_type_t * | halo_type ) |
| void cs_gradient_vector | ( | const char * | var_name, |
| int | inc, | ||
| const cs_field_bc_coeffs_t * | bc_coeffs_v, | ||
| cs_real_t | var[][3], | ||
| cs_real_t | gradv[][3][3] ) |
| void cs_gradient_vector_cell | ( | const cs_mesh_t * | m, |
| const cs_real_t | var[][3], | ||
| cs_real_t | grad[3][3] ) |
| void cs_gradient_vector_synced_input | ( | const char * | var_name, |
| int | inc, | ||
| const cs_real_t | val_f[][3], | ||
| cs_real_t | grad[][3][3] ) |
| [in] | bc_coeffs_v | boundary condition structure |
| [in] | cpl | associated internal coupling, or nullptr |
extern |
