cs_cdovb_scalsys.h File Reference
Include dependency graph for cs_cdovb_scalsys.h:
void cs_cdovb_scalsys_init_sharing (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
 Set pointers to the main shared structures.
void * cs_cdovb_scalsys_define (int n_eqs, const cs_equation_system_param_t *sysp, cs_equation_core_t **block_factories, cs_cdo_system_helper_t **p_sh)
 Create and initialize factories for extra-diagonal blocks Build equation builders and scheme context structures for each equation which are in the extra-diagonal blocks related to a system of equations. Structures associated to diagonal blocks should be already initialized during the treatment of the classical full equations.
void * cs_cdovb_scalsys_free (int n_eqs, cs_equation_core_t **blocks, void *sys_context)
 Free an array of structures (equation parameters, equation builders or scheme context) for each equation which are in the extra-diagonal blocks related to a system of equations. Structures associated to diagonal blocks are freed during the treatment of the classical full equations.
void cs_cdovb_scalsys_solve_implicit (bool cur2prev, const cs_time_step_t *time_step, int n_equations, cs_equation_system_param_t *sysp, cs_equation_core_t **blocks, void *sys_context, cs_cdo_system_helper_t *sh)
 Build and solve the linear system of equations. The number of rows in the system is equal to the number of equations. Thus there are n_eqs*n_eqs blocks in the system. Each block corresponds potentially to a scalar-valued unsteady convection/diffusion/reaction equation with a CDO-Vb scheme using an implicit time scheme.
void cs_cdovb_scalsys_solve_implicit_incr (bool cur2prev, const cs_time_step_t *time_step, int n_equations, cs_equation_system_param_t *sysp, cs_equation_core_t **blocks, void *sys_context, cs_cdo_system_helper_t *sh)
 Build and solve the system of equations. The number of rows in the system is equal to the number of equations. Thus there are n_eqs*n_eqs blocks in the system. Each block corresponds potentially to a scalar-valued unsteady convection/diffusion/reaction equation with a CDO-Vb scheme using an implicit time scheme and an incremental resolution.
◆ cs_cdovb_scalsys_define()
void * cs_cdovb_scalsys_define ( int n_eqs,
const cs_equation_system_param_t * sysp,
cs_equation_core_t ** block_factories,
cs_cdo_system_helper_t ** p_sh )
Case of scalar-valued CDO-Vb scheme in each block
[in]n_eqsnumber of equations
[in]syspset of parameters to specify a system of eqs
[in,out]block_factoriesarray of the core members for an equation
[out]p_shsystem helper structure to initialize
a pointer to a new allocated system context structure
◆ cs_cdovb_scalsys_free()
void * cs_cdovb_scalsys_free ( int n_eqs,
cs_equation_core_t ** blocks,
void * sys_context )
[in,out]blocksarray of the core structures for an equation
[in,out]sys_contextpointer to a structure cast on-the-fly
◆ cs_cdovb_scalsys_init_sharing()
void cs_cdovb_scalsys_init_sharing ( const cs_mesh_t * mesh,
const cs_cdo_connect_t * connect,
const cs_cdo_quantities_t * quant,
const cs_time_step_t * time_step )
[in]meshbasic mesh structure
◆ cs_cdovb_scalsys_solve_implicit()
void cs_cdovb_scalsys_solve_implicit ( bool cur2prev,
const cs_time_step_t * time_step,
int n_equations,
void * sys_context,
cs_cdo_system_helper_t * sh )
[in]cur2prevdo a "current to previous" operation ?
[in]n_equationsnumber of equations
[in]syspset of paremeters for the system of equations
[in,out]blocksarray of the core members for an equation
[in,out]shpointer to a system helper structure
◆ cs_cdovb_scalsys_solve_implicit_incr()
void cs_cdovb_scalsys_solve_implicit_incr ( bool cur2prev,
int n_equations,
void * sys_context,
