1#ifndef __CS_CDO_TURBULENCE_H__
2#define __CS_CDO_TURBULENCE_H__
49#define CS_NAVSTO_TOTAL_VISCOSITY "total_viscosity"
50#define CS_NAVSTO_LAM_VISCOSITY "laminar_viscosity"
51#define CS_NAVSTO_TURB_VISCOSITY "turbulent_viscosity"
void cs_turbulence_finalize_setup(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs)
Finalize the setup of the turbulence modelling and especially the equations/properties and other rela...
Definition cs_cdo_turbulence.cpp:478
void cs_turbulence_init_setup(cs_turbulence_t *tbs, cs_equation_t *mom_eq)
Initialize the structure managing the turbulence modelling.
Definition cs_cdo_turbulence.cpp:390
void * cs_turb_free_k_eps_context(void *tbc)
Free the context structure related to the k-epsilon turbulence model.
Definition cs_cdo_turbulence.cpp:726
void * cs_turb_init_k_eps_context(const cs_turb_model_t *tbm)
Allocate and initialize the context structure related to the k-epsilon turbulence model.
Definition cs_cdo_turbulence.cpp:628
void * cs_turb_init_context_t(const cs_turb_model_t *tbm)
Allocate and initialize the context structure related to a given turbulence modelling.
Definition cs_cdo_turbulence.h:121
void cs_turbulence_free(cs_turbulence_t **p_turb_struct)
Free the structure managing the turbulence modelling.
Definition cs_cdo_turbulence.cpp:362
cs_turbulence_t * cs_turbulence_create(cs_turbulence_param_t *tbp)
Allocate the structure managing the turbulence modelling.
Definition cs_cdo_turbulence.cpp:311
void cs_turb_compute_t(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs)
Compute for the current time step the new state for the turbulence model. This means that all related...
Definition cs_cdo_turbulence.h:151
void * cs_turb_free_context_t(void *turb_context)
Free the context structure related to a given turbulence modelling.
Definition cs_cdo_turbulence.h:134
void cs_turbulence_init_values(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs)
Initialize the values of quantities related to a turbulence model.
Definition cs_cdo_turbulence.cpp:595
cs_turbulence_param_t * cs_turbulence_param_create(void)
Allocate the structure storing the set of parameters for the turbulence modelling.
Definition cs_cdo_turbulence.cpp:284
void cs_turb_update_t(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, const cs_turbulence_t *tbs)
Update properties, arrays related to the turbulent variables.
Definition cs_cdo_turbulence.h:170
void cs_turb_compute_k_eps(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs)
Definition cs_cdo_turbulence.cpp:827
void cs_turb_update_k_eps(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, const cs_turbulence_t *tbs)
Update for the current time step the new state for the turbulence model. This is used to update the t...
Definition cs_cdo_turbulence.cpp:752
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_cdo_turbulence.h:182
cs_turb_compute_t * compute_steady
Definition cs_cdo_turbulence.h:294
cs_turbulence_param_t * param
Definition cs_cdo_turbulence.h:194
cs_real_t * mu_tot_array
Definition cs_cdo_turbulence.h:233
cs_equation_t * mom_eq
Definition cs_cdo_turbulence.h:199
cs_field_t * rij
Definition cs_cdo_turbulence.h:251
cs_turb_free_context_t * free_context
Definition cs_cdo_turbulence.h:281
Definition cs_cdo_turbulence.h:287
cs_field_t * mu_t_field
Definition cs_cdo_turbulence.h:245
cs_property_t * rho
Definition cs_cdo_turbulence.h:210
cs_turb_init_context_t * init_context
Definition cs_cdo_turbulence.h:275
cs_property_t * mu_t
Definition cs_cdo_turbulence.h:228
void * context
Definition cs_cdo_turbulence.h:269
cs_turb_update_t * update
Definition cs_cdo_turbulence.h:301
cs_property_t * mu_l
Definition cs_cdo_turbulence.h:222
cs_property_t * mu_tot
Definition cs_cdo_turbulence.h:216
Definition cs_cdo_connect.h:61
Definition cs_cdo_quantities.h:145
Definition cs_field.h:158
time step descriptor
Definition cs_time_step.h:64
LES turbulence model descriptor.
Definition cs_turbulence_model.h:274
Turbulence model general options descriptor.
Definition cs_turbulence_model.h:129
RANS turbulence model descriptor.
Definition cs_turbulence_model.h:197
Definition cs_turbulence_model.h:186
Structure storing the parameters related to the resolution of the turbulence modelling....
Definition cs_cdo_turbulence.h:64
cs_turb_rans_model_t * rans_param
Definition cs_cdo_turbulence.h:79
cs_turb_model_t * model
Definition cs_cdo_turbulence.h:71
cs_turb_les_model_t * les_param
Definition cs_cdo_turbulence.h:87
cs_turb_ref_values_t * reference_values
Definition cs_cdo_turbulence.h:93
