cs_atmo_source_terms.h
1#ifndef __CS_ATMO_SOURCE_TERMS_H__
2#define __CS_ATMO_SOURCE_TERMS_H__
5 * Main for atmospheric source terms
31 * Local headers
34#include "base/cs_base.h"
41 * Local Macro definitions
45 * Type definitions
49 * Static global variables
51
52/*============================================================================
53 * Public function definitions
54 *============================================================================*/
55
56/*----------------------------------------------------------------------------*/
65/*----------------------------------------------------------------------------*/
66
67void
68cs_atmo_source_term(int f_id,
69 cs_real_t exp_st[],
70 cs_real_t imp_st[]);
71
72/*----------------------------------------------------------------------------*/
73
74/*----------------------------------------------------------------------------*/
84/*----------------------------------------------------------------------------*/
85
86void
88 cs_real_t exp_st[]);
89
90/*----------------------------------------------------------------------------*/
97/*----------------------------------------------------------------------------*/
98
99void
101
102
103/*----------------------------------------------------------------------------*/
104
106
107#endif /* __CS_ATMO_SOURCE_TERMS_H__ */
void cs_atmo_source_term_for_inlet(cs_real_3_t exp_st[])
Additional right-hand side source terms for momentum equation in case of free inlet.
Definition cs_atmo_source_terms.cpp:811
void cs_atmo_source_term(int f_id, cs_real_t exp_st[], cs_real_t imp_st[])
Phase change source terms - Exchange terms between the injected liquid and the water vapor phase in t...
Definition cs_atmo_source_terms.cpp:446
void cs_atmo_scalar_source_term(int f_id, cs_real_t exp_st[])
Additional right-hand side source terms for scalar equations taking into account dry and humid atmosp...
Definition cs_atmo_source_terms.cpp:613
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
cs_real_t cs_real_3_t[3]
Definition cs_defs.h:359
