#include <ple_locator.h>#include "fvm/fvm_nodal.h"#include "base/cs_base.h"#include "base/cs_halo.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_quantities.h"Go to the source code of this file.
| void | cs_atmo_aerosol_ssh_initialize (void) |
| This function initializes SSH-aerosol. | |
| void | cs_atmo_aerosol_ssh_finalize (void) |
| This function finalizes SSH-aerosol. | |
| void | cs_atmo_aerosol_ssh_compute_numbers (cs_real_t *) |
| This function computes the number of aerosols using the given array. | |
| void | cs_atmo_aerosol_ssh_set_t_p_h (cs_real_t *T, cs_real_t *P, cs_real_t *yw) |
| This function takes as input absolute temperature T total pressure P water mass fraction yw It computes absolute temperature relative humidity Then updates the humidity in SSH. | |
| void | cs_atmo_aerosol_ssh_set_aero (cs_real_t *) |
| This function uses the given array to update the aerosol concentrations and numbers in SSH-aerosol. | |
| void | cs_atmo_aerosol_ssh_get_aero (cs_real_t *) |
| This function fills the given array with aerosol concentrations and numbers from SSH-aerosol. | |
| void | cs_atmo_aerosol_ssh_set_gas (cs_real_t *) |
| This function uses the given array to update the gas concentrations in SSH-aerosol. | |
| void | cs_atmo_aerosol_ssh_get_gas (cs_real_t *) |
| This function fills the given array with gas concentrations from SSH-aerosol. | |
| void | cs_atmo_aerosol_ssh_time_advance (void) |
| This function computes a time step of gaseous chemistry and aerosols dynamic using SSH-aerosol. | |
| void cs_atmo_aerosol_ssh_compute_numbers | ( | cs_real_t * | dlconc0 | ) |
| void cs_atmo_aerosol_ssh_finalize | ( | void | ) |
| void cs_atmo_aerosol_ssh_get_aero | ( | cs_real_t * | array | ) |
| void cs_atmo_aerosol_ssh_get_gas | ( | cs_real_t * | array | ) |
| void cs_atmo_aerosol_ssh_initialize | ( | void | ) |
| void cs_atmo_aerosol_ssh_set_aero | ( | cs_real_t * | array | ) |
| void cs_atmo_aerosol_ssh_set_gas | ( | cs_real_t * | array | ) |
| void cs_atmo_aerosol_ssh_time_advance | ( | void | ) |
