#include "base/cs_defs.h"#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft/bft_mem_usage.h"Functions | |
| void | bft_mem_usage_init (void) |
| Initialize memory usage count depending on system. | |
| void | bft_mem_usage_end (void) |
| End memory usage count depending on system. | |
| int | bft_mem_usage_initialized (void) |
| Indicates if bft_mem_usage_...() functions are initialized. | |
| size_t | bft_mem_usage_pr_size (void) |
| Return current process memory use (in kB) depending on system. | |
| size_t | bft_mem_usage_max_pr_size (void) |
| size_t | bft_mem_usage_max_vm_size (void) |
| size_t | bft_mem_usage_shared_lib_size (void) |
| void | bft_mem_usage_n_calls (size_t count[3]) |
Base memory usage information (System and Library dependent).
The memory-usage measurement functions provided here may be system-dependent. If they have not yet been ported to a given type of environment, these functions should return 0.
The user should thus check for the return values of such functions to avoid reporting invalid values, but the API is guaranteed.
| void bft_mem_usage_end | ( | void | ) |
| void bft_mem_usage_init | ( | void | ) |
This functions checks if it has already been called, so it is safe to call more than once (though it is not thread-safe). Only the first call is effective.
| int bft_mem_usage_initialized | ( | void | ) |
| size_t bft_mem_usage_max_pr_size | ( | void | ) |
| size_t bft_mem_usage_max_vm_size | ( | void | ) |
| void bft_mem_usage_n_calls | ( | size_t | count[3] | ) |
| size_t bft_mem_usage_pr_size | ( | void | ) |
If the information is not available (depending on availability of non-portable function calls), 0 is returned.
| size_t bft_mem_usage_shared_lib_size | ( | void | ) |
