atsoil.f90 File Reference
Module for the atmospheric soil model adapted to the IGN "land use" file format. More...
Modules
module  atsoil
integer, save nfmodsol
 Number of boundary faces with soil features.
integer, save nbrsol
 Number of soil model's type.
real(c_double), pointer, save tsini
 initial soil surface temperature for Sea, it is also the surface temperature
real(c_double), pointer, save tprini
 initial deep soil temperature
real(c_double), pointer, save qvsini
 initial soil specific humidity
real(c_double), pointer, save w1ini
 initial water content of the first reservoir
real(c_double), pointer, save w2ini
 initial water content of the second reservoir
double precision, dimension(:), pointer csol
 Thermal inertia of the soil.
double precision, dimension(:), pointer rugdyn
 Dynamic roughness length.
double precision, dimension(:), pointer rugthe
 Thermal roughness length.
double precision, dimension(:), pointer soil_cat_albedo
 Albedo.
double precision, dimension(:), pointer soil_cat_emissi
 emissivity
double precision, dimension(:), pointer soil_cat_vegeta
 Vegetation index.
double precision, dimension(:), pointer soil_cat_c1w
 maximum water capacity of shallow reservoir
double precision, dimension(:), pointer soil_cat_c2w
 ratio of the maximum water capacity of the shallow reservoir to the deep reservoir [0,1]
double precision, dimension(:), pointer soil_cat_r1
 Rij value for Rij1.
double precision, dimension(:), pointer soil_cat_r2
 Rij value for Rij2.
