Atmospheric Imbrication module. This module contains the data structure and subroutines to perform atmospheric imbrication or nesting of a CFD domain within a large scale meteorological field. Starting from a set of large scale meteological profiles (in the format of meteo files) an interpolation is performed for each boundary face both spatially and temporally (using Cressman method)
More...
| subroutine | atmo_init_imbrication () |
| | Map Fortran to C variables.
| subroutine | allocate_all () |
| | Allocate variables adapted to the number of files and time step to be considered.
| subroutine | finalize_imbrication () |
| | Final step for deallocation.
| subroutine | interpolate_all_profiles (the_time) |
| | Time interpolation of all profiles -.
| subroutine | dump_interpolated_profiles |
| | Print the interpolated profiles for checking purposes.
| integer function | yo2j (year, ordinal) |
| | Converts a (year,ordinal) date to julian calendar date for calculating time shifts.
| subroutine | read_files_list (a_file, the_list) |
| | Reads a file having in each significative line a file name it returns then as 'the_list' the list of lines read a line is significative if it's first char is not / or # or ! The following 3 lines give an example from which one must remove the first two characters.
| subroutine | find_next_line (unilog, current_line, meteo_file, l_iostat) |
| | Find next validated line.
| subroutine | read_meteo_file (meteo_file) |
| | Reads a meteo_file for code_saturne Atmospheric Physics option.
| subroutine | check_chronologies |
| | Checks the time variables to ensure the chronology.
| subroutine | check_positions |
| | Check that the profiles position is the same over time.
| subroutine | check_altitudes |
| | Check that the profiles vertical grids heights are strictly increasing.
| subroutine | hydrostatic_pressure |
| | Compute the hydrostastic pressure by Laplace integration.
| subroutine | potential_temperature_and_density |
| | Computes the potential_temperature_and_density profiles.
| subroutine | get_index (the_array, the_value, lower, upper) |
| | Search for the position of a value in an array, assuming that the array is sorted in a strictly increasing order.
| subroutine | time_interpolation (the_time, the_times, the_profiles, interpolated_profile) |
| | Interpolates a "profile" at a given time. Given a series of profiles varying in time you get the profile interpolated from them at the given time.
| subroutine | altitude_interpolation (the_altitude, the_altitudes, the_profile, interpolated_value) |
| | interpolates in a profile at a given altitude
| subroutine | red_tape |
| | Compute radius of influence.
| subroutine | bounds (string, length, b, e) |
| | Identification of the first and last non white character of a string.
| subroutine | activate_imbrication () |
| | Prepare data for imbrication by reading meteo files.
| subroutine | summon_cressman (the_time) |
| | Prepare for the cressman interpolation of the variables.
| logical(c_bool), pointer | imbrication_flag |
| | activation flag
| logical(c_bool), pointer, save | imbrication_verbose |
| logical(c_bool), pointer | cressman_u |
| | Flags for activating the cressman interpolation for the boundary conditions.
| logical(c_bool), pointer | cressman_v |
| logical(c_bool), pointer | cressman_tke |
| logical(c_bool), pointer | cressman_eps |
| logical(c_bool), pointer | cressman_theta |
| logical(c_bool), pointer | cressman_qw |
| logical(c_bool), pointer | cressman_nc |
| real(c_double), pointer | vertical_influence_radius |
| | numerical parameters for the cressman interpolation formulas
| real(c_double), pointer | horizontal_influence_radius |
| integer | line_len |
| | Parameter for "meteo" files.
| character(line_len) | imbrication_files_list |
| character(line_len), dimension(:), allocatable | imbrication_files |
| integer | number_of_files |
| character *(3) | skip_chars |
| integer | thermal_profile_dim |
| | Profile dimension variable.
| integer | dynamical_profile_dim |
| integer | sections_per_file |
| | Time sections per files.
| integer, dimension(:,:), allocatable | years |
| | read data from "meteo" files
| integer, dimension(:,:), allocatable | ordinals |
| integer, dimension(:,:), allocatable | hours |
| integer, dimension(:,:), allocatable | minutes |
| double precision, dimension(:,:), allocatable | seconds |
| double precision, dimension(:,:), allocatable | xpos |
| | Positions.
| double precision, dimension(:,:), allocatable | ypos |
| double precision, dimension(:,:), allocatable | ground_pressure |
| double precision, dimension(:,:,:), allocatable | zt |
| | Vertical grid for temperature and humidity variables.
| double precision, dimension(:,:,:), allocatable | tempc |
| double precision, dimension(:,:,:), allocatable | qw |
| double precision, dimension(:,:,:), allocatable | nc |
| double precision, dimension(:,:,:), allocatable | zd |
| | Vertical grid for wind variables.
| double precision, dimension(:,:,:), allocatable | u |
| double precision, dimension(:,:,:), allocatable | v |
| double precision, dimension(:,:,:), allocatable | tke |
| double precision, dimension(:,:,:), allocatable | eps |
| double precision, dimension(:,:), allocatable, target | times |
| | derived data
| double precision, dimension(:,:,:), allocatable | pressure |
| double precision, dimension(:,:,:), allocatable | theta |
| double precision, dimension(:,:,:), allocatable | density |
| double precision, dimension(:,:), allocatable | ti_zt |
| | time interpolated profiles
| double precision, dimension(:,:), allocatable | ti_tempc |
| double precision, dimension(:,:), allocatable | ti_qw |
| double precision, dimension(:,:), allocatable | ti_nc |
| double precision, dimension(:,:), allocatable | ti_zd |
| double precision, dimension(:,:), allocatable | ti_u |
| double precision, dimension(:,:), allocatable | ti_v |
| double precision, dimension(:,:), allocatable | ti_tke |
| double precision, dimension(:,:), allocatable | ti_eps |
| double precision, dimension(:,:), allocatable | ti_pressure |
| double precision, dimension(:,:), allocatable | ti_theta |
| double precision, dimension(:,:), allocatable | ti_density |
| double precision, dimension(:,:,:), allocatable | coordinates_th |
| | additional variables
| double precision, dimension(:,:,:), allocatable | influence_param_th |
| double precision, dimension(:,:,:), allocatable | coordinates_dyn |
| double precision, dimension(:,:,:), allocatable | influence_param_dyn |
| integer(c_int), pointer | id_u |
| integer(c_int), pointer | id_v |
| integer(c_int), pointer | id_qw |
| integer(c_int), pointer | id_nc |
| integer(c_int), pointer | id_tke |
| integer(c_int), pointer | id_eps |
| integer(c_int), pointer | id_theta |
| double precision, dimension(:), pointer | times_sequence =>null() |
| | 1D array of times at which profiles are given
This imbrication reads additional meteo files.
