wall functions descriptor.
More...
#include <cs_wall_functions.h>
Members of this wall functions descriptor are publicly accessible, to allow for concise syntax, as it is expected to be used in many places.
◆ iwalfs
wall functions for scalar
- CS_WALL_F_S_ARPACI_LARSEN: three layers (Arpaci and Larsen) or two layers (Prandtl-Taylor) for Prandtl number smaller than 0.1
- CS_WALL_F_S_VDRIEST: consistant with the 2 scales wall function for velocity using Van Driest mixing length
- CS_WALL_F_S_LOUIS: default wall function for atmospheric flows for potential temperature. This has influence on the dynamic.
- CS_WALL_F_S_MONIN_OBUKHOV: Monin Obukhov wall function for atmospheric flows for potential temperature. This has influence on the dynamic.
◆ iwallf
Indicates the type of wall function used for the velocity boundary conditions on a frictional wall.
- CS_WALL_F_DISABLED: no wall functions
- CS_WALL_F_1SCALE_POWER: one scale of friction velocities (power law)
- CS_WALL_F_1SCALE_LOG: one scale of friction velocities (log law)
- CS_WALL_F_2SCALES_LOG: two scales of friction velocities (log law)
- CS_WALL_F_SCALABLE_2SCALES_LOG: two scales of friction velocities (log law) (scalable wall functions)
- CS_WALL_F_2SCALES_VDRIEST: two scales of friction velocities (mixing length based on V. Driest analysis)
- CS_WALL_F_2SCALES_SMOOTH_ROUGH: wall function unifying rough and smooth friction regimes
- CS_WALL_F_2SCALES_CONTINUOUS: All
for low Reynolds models
iwallf is initialised to CS_WALL_F_1SCALE_LOG for model = 10, 40, 41 or 70 (mixing length, LES and Spalart Allmaras).
iwallf is initialised to CS_WALL_F_DISABLED for model = 0, 32, 50 or 51
iwallf is initialised to CS_WALL_F_2SCALES_LOG for model = 20, 21, 30, 31 or 60 (
LRR,
SSG and
SST models).
The v2f model (model=50) is not designed to use wall functions (the mesh must be low Reynolds).
The value iwallf = CS_WALL_F_2SCALES_LOG is not compatible with model=0, 10, 40 or 41 (laminar, mixing length and LES).
Concerning the
and
models, the two-scales model is usually at least as satisfactory as the one-scale model.
The scalable wall function allows to virtually shift the wall when necessary in order to be always in a logarithmic layer. It is used to make up for the problems related to the use of High-Reynolds models on very refined meshes.
Useful if model is different from 50.
◆ ypluli
limit value of
for the viscous sublayer
ypluli depends on the chosen wall function: it is initialized to 10.88 for the scalable wall function (iwallf=CS_WALL_F_SCALABLE_2SCALES_LOG), otherwise it is initialized to
. In LES, ypluli is taken by default to be 10.88. Always useful.
