8.3
cs_param_convergence_t Struct Reference
Set of parameters to check the convergence (or the divergence) of an iterative process (tolerances or max. number of iterations) More...
#include <cs_param_types.h>
+ Collaboration diagram for cs_param_convergence_t:
Data Fields
double atol
double rtol
double dtol
int n_max_iter
Field Documentation
◆ atol
atol
Absolute tolerance under which the iterative process is stopped
◆ dtol
dtol
Tolerance above which the iterative process is stated as "diverged". Not used if < 0
◆ n_max_iter
n_max_iter
Maximal number of iterations before stopping the iterative process
◆ rtol
rtol
Relative tolerance under which the iterative process is stopped
