Set of parameters specific for solving the Navier-Stokes system with an incremental projection algorithm. More...
#include <cs_navsto_coupling.h>
Collaboration diagram for cs_navsto_projection_t:Data Fields | |
| cs_equation_t * | prediction |
| cs_equation_t * | correction |
| cs_real_t * | div_st |
| cs_real_t * | bdy_pressure_incr |
| cs_field_t * | predicted_velocity |
| cs_field_t * | phi |
| cs_field_t * | pressure_incr_gradient |
All equations are not always created. It depends on the choice of the model
| bdy_pressure_incr |
Pressure increment at the boundary. Used as an array to set the boundary condition arising from a Dirichlet on the pressure.
| cs_equation_t* correction |
Pressure correction step related to the mass balance equation (scalar-valued)
| div_st |
Source term on the correction step stemming from the divergence of the predicted velocity
| cs_field_t* phi |
Predicted velocity field (value of the velocity at cells after the prediction step). This values may not be divergence-free.
| cs_equation_t* prediction |
Velocity prediction step related to the momentum balance equation (vector-valued)
Gradient of pressure increment. Used to store the gradient pressure increment. Only available with verbosity > 1.
