8.3
cs_iter_algo_param_aac_t Struct Reference
Structure storing all the parameters to drive the algorithm called Anderson acceleration. More...
#include <cs_iter_algo.h>
+ Collaboration diagram for cs_iter_algo_param_aac_t:
Data Fields
int n_max_dir
int starting_iter
double max_cond
double beta
cs_param_dotprod_type_t dp_type
Field Documentation
◆ beta
beta
Value of the relaxation coefficient (if this is equal to zero then there is non relaxation to perform)
◆ dp_type
dp_type
Type of dot product to apply (usual Euclidean 2-norm or CDO-based one)
◆ max_cond
max_cond
Tolerance under which terms are dropped in order to improve the conditionning number of the QR factorization
◆ n_max_dir
n_max_dir
Maximum number of directions
◆ starting_iter
starting_iter
Anderson acceleration starts at this iteration number
