8.3
cs_combustion_gas_model_t Struct Reference
#include <cs_combustion_gas.h>
+ Collaboration diagram for cs_combustion_gas_model_t:
Data Fields
int n_gas_el_comp
int n_gas_species
int n_atomic_species
int n_reactions
int n_tab_points
double pcigas
double xco2
double xh2o
double wmole [CS_COMBUSTION_GAS_MAX_ELEMENTARY_COMPONENTS]
double wmolat [CS_COMBUSTION_GAS_MAX_ATOMIC_SPECIES]
double oxyn2 [CS_COMBUSTION_GAS_MAX_OXYDANTS]
double oxyh2o [CS_COMBUSTION_GAS_MAX_OXYDANTS]
double oxyco2 [CS_COMBUSTION_GAS_MAX_OXYDANTS]
double th [CS_COMBUSTION_GAS_MAX_TABULATION_POINTS]
cs_combustion_gas_model_type_t type
char * data_file_name
bool use_janaf
int iic
int iico2
int iio2
int isoot
double hinfue
double tinfue
double tinoxy
double hinoxy
double xsoot
double rosoot
double wmolg [CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES]
double coefeg [CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES][CS_COMBUSTION_GAS_MAX_ELEMENTARY_COMPONENTS]
double compog [CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES][CS_COMBUSTION_GAS_MAX_ELEMENTARY_COMPONENTS]
double fs [CS_COMBUSTION_GAS_MAX_GLOBAL_REACTIONS]
double cpgazg [CS_COMBUSTION_GAS_MAX_TABULATION_POINTS][CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES]
double srrom
double fmin_lwc
double fmax_lwc
double hmin_lwc
double hmax_lwc
Gas combustion model parameters structure
Field Documentation
◆ coefeg
mass fraction conversion coefficients from global species to elementary species
◆ compog
mole fraction conversion coefficients from global species to elementary species
◆ cpgazg
cpgazg[j][i] is the massic calorific capacity (J/kg/K) of the i-th global species at temperature
◆ data_file_name
char* data_file_name
◆ fmax_lwc
double fmax_lwc
◆ fmin_lwc
double fmin_lwc
Libby Williams parameters
◆ fs
Mixing rate at the stoichiometry
◆ hinfue
double hinfue
input mass enthalpy for fuel
◆ hinoxy
double hinoxy
input mass enthalpy for the oxidant
◆ hmax_lwc
double hmax_lwc
◆ hmin_lwc
double hmin_lwc
◆ iic
int iic
use NIST-JANAF tables for enthalpy/temperature conversion rank of C in gas composition (base 1)
◆ iico2
int iico2
rank of CO2 in gas composition (base 1)
◆ iio2
int iio2
rank of O2 in gas composition (base 1)
◆ isoot
int isoot
soot production modeling flag
◆ n_atomic_species
number of atomic species
◆ n_gas_el_comp
int n_gas_el_comp
number of elementary gas components
◆ n_gas_species
int n_gas_species
number of global species
◆ n_reactions
int n_reactions
number of global reactions in gas phase
◆ n_tab_points
int n_tab_points
number of tabulation points
◆ oxyco2
composition of CO2 oxidants
◆ oxyh2o
composition of H2O oxidants
◆ oxyn2
composition of N2 oxidants
◆ pcigas
double pcigas
combustible reaction enthalpy (Lower Calorific Value)
◆ rosoot
double rosoot
soot density
◆ srrom
double srrom
sub-relaxation coefficient for the density: $\rho^{n+1}$\,=\,srrom\,$\rho^n$+(1-srrom)\,$\rho^{n+1}$ (hence, with a zero value, there is no sub-relaxation)
◆ th
temperature in K
◆ tinfue
double tinfue
input temperature for fuel en K
◆ tinoxy
double tinoxy
input temperature for oxydant
◆ type
combustion model type
◆ use_janaf
bool use_janaf
◆ wmolat
molar mass of atomic species
◆ wmole
molar mass of an elementary gas component
◆ wmolg
molar mass of global species
◆ xco2
double xco2
molar coefficient of CO2
◆ xh2o
double xh2o
molar coefficient of H2O
◆ xsoot
double xsoot
soot fraction production (isoot = 0)
