8.3
cs_boundary_condition_pm_info_t Struct Reference
#include <cs_boundary_conditions.h>
+ Collaboration diagram for cs_boundary_condition_pm_info_t:
Data Fields
int * izfppp
int * itrifb
int iqimp [CS_MAX_BC_PM_ZONE_NUM+1]
int icalke [CS_MAX_BC_PM_ZONE_NUM+1]
cs_real_t qimp [CS_MAX_BC_PM_ZONE_NUM+1]
cs_real_t dh [CS_MAX_BC_PM_ZONE_NUM+1]
cs_real_t xintur [CS_MAX_BC_PM_ZONE_NUM+1]
int ientfu [CS_MAX_BC_PM_ZONE_NUM+1]
int ientox [CS_MAX_BC_PM_ZONE_NUM+1]
int ientgb [CS_MAX_BC_PM_ZONE_NUM+1]
int ientgf [CS_MAX_BC_PM_ZONE_NUM+1]
double tkent [CS_MAX_BC_PM_ZONE_NUM+1]
double fment [CS_MAX_BC_PM_ZONE_NUM+1]
double tgf
double frmel
int * iautom
int iprofm [CS_MAX_BC_PM_ZONE_NUM+1]
boundary zone number associated with each boundary face (specific physical models)
Deprecated:
This is used for cs_boundary_condition_pm_info_t only.
Legacy physical model boundary conditions.
Remarks
The amppings of member arrays of this structure are shifted by 1 when mapped to Fortran, so that both in Fortran and C, we can use the natural indexing (1-based and 0-based respectively) without needing to shift the zone id/number.
Deprecated:
This should be used for Fortran compatibilty and migration to C only. In C, we should then move to high level boundary condition definitions not requiring indexing by legacy zone numbers indexed by cs_glob_bc_face_zone.
Field Documentation
◆ dh
hydraulic diameter
◆ fment
double fment[CS_MAX_BC_PM_ZONE_NUM+1]
Mean Mixture Fraction at Inlet (gas combustion)
◆ frmel
double frmel
◆ iautom
int* iautom
atmo
◆ icalke
int icalke[CS_MAX_BC_PM_ZONE_NUM+1]
Turbulence inlet type:
  • 0: given by the user
  • 1: automatic, from hydraulic diameter and input velocity performed.
  • 2: automatic, from turbulent intensity and input velocity performed.
◆ ientfu
int ientfu[CS_MAX_BC_PM_ZONE_NUM+1]
gas combustion (cogz)
◆ ientgb
int ientgb[CS_MAX_BC_PM_ZONE_NUM+1]
◆ ientgf
int ientgf[CS_MAX_BC_PM_ZONE_NUM+1]
◆ ientox
int ientox[CS_MAX_BC_PM_ZONE_NUM+1]
◆ iprofm
int iprofm[CS_MAX_BC_PM_ZONE_NUM+1]
◆ iqimp
int iqimp[CS_MAX_BC_PM_ZONE_NUM+1]
Imposed flow zone indicator (for inlet zones). If the mass flow is imposed (iqimp(z_id) = 1), the matching qimp value must be set, and the defined velocity boundary condition will be rescaled so as to match the given mass flow (i.e. only its original direction is used. Otherwise, the given velocity boundary condition given by rcodcl1 is unchanged.
◆ itrifb
int* itrifb
indirection array allowing to sort the boundary faces according to their boundary condition type bc_type
◆ izfppp
int* izfppp
Legacy physical model zone id per boundary face
◆ qimp
Imposed flow value (for inlet zones). If the mass flow is imposed (iqimp(z_num - 1) = 1), the matching qimp value must be set, and the defined velocity boundary condition will be rescaled so as to match the given mass flow (i.e. only its original direction is used. Otherwise, the given velocity boundary condition given by rcodcl1 is unchanged.
◆ tgf
double tgf
EBU combustion model parameters (legacy)
◆ tkent
double tkent[CS_MAX_BC_PM_ZONE_NUM+1]
inlet temperature (gas combustion)
◆ xintur
turbulent intensity
