Functions/Subroutines | |
| subroutine | reftra (pioc, piaero, gasym, gaero, tauc, taua, ref, tra, epsc, dqqv, mui) |
| Compute reflexion and transmission. More... | |
| subroutine | rayso (ivertc, k1, kmray, heuray, imer1, albe, qqv, qqqv, qqvinf, zqq, zray, qvray, qlray, fneray, romray, preray, temray, fos, rayst, ncray) |
| Compute solar fluxes for both clear and cloudy atmosphere following Lacis and Hansen (1974). The multiple diffusion is taken into account by an addition method and overlapping between water vapor and liquid water with k distribution method. Some improvements from original version concerns: More... | |
| double precision function | rayuoz (zh) |
| Computes ozone concentration for a given altitude. More... | |
| double precision function | raysve (y) |
| Aborption function of the solar radiation by water vapor. More... | |
| double precision function | dzyama (y, dy) |
| Aborption derivative-function of the solar radiation by water vapor. More... | |
| double precision function | raysoz (x) |
| Aborption function of the solar radiation by ozone. More... | |
| double precision function | dzxaoz (x, dx) |
| Absorption derivative-function of the solar radiation by ozone. More... | |
| double precision function | drayuoz (zh) |
| double precision function drayuoz | ( | double precision, intent(in) | zh | ) |
| double precision function dzxaoz | ( | double precision, intent(in) | x, |
| double precision, intent(in) | dx | ||
| [in] | x | |
| [in] | dx |
| double precision function dzyama | ( | double precision, intent(in) | y, |
| double precision, intent(in) | dy | ||
| [in] | y | optical depth for water vapor |
| [in] | dy | TODO? |
| subroutine rayso | ( | integer | ivertc, |
| integer | k1, | ||
| integer | kmray, | ||
| double precision | heuray, | ||
| integer | imer1, | ||
| double precision | albe, | ||
| double precision, dimension(kmx+1) | qqv, | ||
| double precision, dimension(kmx+1) | qqqv, | ||
| double precision | qqvinf, | ||
| double precision, dimension(kmx+1) | zqq, | ||
| double precision, dimension(kmx) | zray, | ||
| double precision, dimension(kmx) | qvray, | ||
| double precision, dimension(kmx) | qlray, | ||
| double precision, dimension(kmx) | fneray, | ||
| double precision, dimension(kmx) | romray, | ||
| double precision, dimension(kmx) | preray, | ||
| double precision, dimension(kmx) | temray, | ||
| double precision | fos, | ||
| double precision, dimension(kmx) | rayst, | ||
| double precision, dimension(kmx) | ncray | ||
| [in] | ivertc | index of vertical profile |
| [in] | k1 | index for ground level |
| [in] | kmray | vertical levels number for radiation |
| [in] | heuray | Universal time (Hour) |
| [in] | imer1 | sea index |
| [in] | albe | albedo |
| [in] | qqv | optical depth for water vapor (0,z) |
| [in] | qqqv | idem for intermediate levels |
| [in] | qqvinf | idem qqv but for altitude above 11000m |
| [in] | zqq | vertical levels |
| [in] | zray | altitude (physical mesh) |
| [in] | qvray | specific humidity for water vapor |
| [in] | qlray | specific humidity for liquid water |
| [in] | fneray | cloud fraction |
| [in] | romray | air density |
| [in] | preray | pressure |
| [in] | temray | temperature |
| [out] | fos | global downward solar flux at the ground |
| [out] | rayst | flux divergence of solar radiation |
| double precision function raysoz | ( | double precision, intent(in) | x | ) |
| [in] | x | optical depth for ozone |
| double precision function raysve | ( | double precision, intent(in) | y | ) |
| double precision function rayuoz | ( | double precision, intent(in) | zh | ) |
| [in] | zh | altitude |
| subroutine reftra | ( | double precision, intent(in) | pioc, |
| double precision, intent(in) | piaero, | ||
| double precision, intent(in) | gasym, | ||
| double precision, intent(in) | gaero, | ||
| double precision, intent(in) | tauc, | ||
| double precision, intent(in) | taua, | ||
| double precision, intent(inout) | ref, | ||
| double precision, intent(inout) | tra, | ||
| double precision, intent(in) | epsc, | ||
| double precision, intent(in) | dqqv, | ||
| double precision | mui | ||
| [in] | pioc | Albedo of simple diffusion for cloud (water) |
| [in] | piaero | Albedo of simple diffusion for aerosol |
| [in] | gasym | Asymmetry factor for clouds |
| [in] | gaero | Asymmetry factor for aerosols |
| [in] | tauc | Optical depth for clouds |
| [in] | taua | Optical depth for aersols |
| [out] | ref | Reflexion |
| [out] | tra | Transmission |
| [in] | epsc | clipping threshold |
| [in] | dqqv | Optical depth for Water vapor |
