8.3
pptssc.f90 File Reference
This subroutine defines the source terms for scalars which are part of specific physics models. Source terms are defined over one time step. More...
Functions/Subroutines
subroutine pptssc (iscal, smbrs, rovsdt)
Warning: source terms are treated differently from the way they are in cs_user_source_terms. rovsdt*d(var) = smbrs is solved. rovsdt and smbrs already hold possible user source terms values and thus have to be incremented (and not overwritten).
For stability reasons, only positive terms are added to rovsdt, while there are no such constrains on values to be added to smbrs.
In the case of a source term of the form cexp + cimp*var, the source term should be implemented as follows:
   smbrs  = smbrs  + cexp + cimp*var
   rovsdt = rovsdt + max(-cimp,0)
rovsdt and smbrs are provided here respectively in kg/s and in kg/s*[scalar]. Examples: velocity $ kg m/s^2 $ temperature $ kg K/s $ enthalpy $ J/s $
◆ pptssc()
subroutine pptssc ( integer(c_int), value  iscal,
real(c_double), dimension(ncelet)  smbrs,
real(c_double), dimension(ncelet)  rovsdt
[in]iscalscalar number
[in,out]smbrsexplicit source term part
[in,out]rovsdtimplicite source term part
