8.3
Module for definition of general parameters
integer nscamx
 maximum number of scalars solutions of an advection equation, apart from the variables of the turbulence model $ (k, \varepsilon, R_{ij}, \omega, \varphi, \overline{f}, \alpha, \nu_t$) , that is to say the temperature and other scalars (passive or not, user-defined or not) More...
integer nvarmx
 maximal number of variables = nscamx + 12 (u,v,w,P,Rij,e,alp) More...
integer iindef
  pointer for undefined type face (non-standard case) More...
integer ientre
  if itypfb=ientre: inlet face. More...
integer isolib
  if itypfb=isolib: free outlet face (or more precisely free inlet/outlet with forced pressure) More...
integer isymet
  if itypfb=isymet: symmetry face (or wall without friction). More...
integer iparoi
  if itypfb=iparoi: smooth solid wall face, impermeable and with friction. More...
integer iparug
  if itypfb=iparug: rough solid wall face, impermeable and with friction. More...
integer iesicf
 if itypfb=iesicf: imposed inlet/outlet for compressible flow (for example, supersonic inlet). More...
integer isspcf
 if itypfb=isspcf: supersonic outlet for compressible flow. More...
integer isopcf
 if itypfb=isopcf: mixed outlet for compressible flow with a given pressure. More...
integer iephcf
 if itypfb=iephcf: mixed inlet for compressible flow with given total pressure and total enthalpy (reservoir boundary conditions). More...
integer ieqhcf
integer icscpl
  code/code coupling condition More...
integer icscpd
  code/code coupling condition with decentered flux More...
integer ifrent
  if itypfb=ifrent: free entrance based on Bernoulli equation when the flow is incoming, standard outlet when outgoing More...
integer ifresf
  if itypfb=ifresf: free surface for mobile mesh boundary condition More...
integer i_convective_inlet
  if itypfb=i_convective_inlet: inlet face where the total mass flux is prescribed. More...
integer ibfixe
  boundary condition type for mesh velocity in ALE: fixed wall More...
integer igliss
  boundary condition type for mesh velocity in ALE: sliding wall More...
integer ivimpo
  boundary condition type for mesh velocity in ALE: imposed velocity. More...
integer ibalfs
  Boundary condition type for mesh velocity in ALE for modelling free surface ( $ \vect{u} \cdot \vect{S} = \vect{w} \cdot \vect{S} $). More...
integer nstrmx
 maximum number of structures in ALE More...
◆ i_convective_inlet
  • Zero-flux condition for pressure and Dirichlet condition for all other variables. The value of the Dirichlet must be given in rcodcl(ifac,ivar,1) for every value of ivar, except for ivar = ipr. The other values of rcodcl and icodcl are filled automatically. The diffusive flux is CANCELLED (therefore the total mass flux is due to convection only).
◆ ibalfs
integer ibalfs
◆ ibfixe
integer ibfixe
◆ icscpd
integer icscpd
◆ icscpl
integer icscpl
◆ ientre
integer ientre
◆ iephcf
integer iephcf
  • Boundary values are obtained by solving a Riemann problem between an inner (values at boundary cells center) and an outer state.
  • Homogeneous Neumann boundary condition for the pressure (seen by the reconstruction gradients and the diffusion operator).
  • Dirichlet (icodcl=1) for velocity and total energy.
  • Analytical boundary convective fluxes of momentum and total energy are computed. Note that the pressure boundary value is needed to compute those two fluxes (seen by the pressure gradient of the momentum equation).
    • If the mass flow is coming in, Dirichlet condition for the scalars and the turbulent quantities is used (or zero-flux condition if no Dirichlet value has been specified).
  • If the mass flow is going out, zero-flux condition are set for the scalars and the turbulent quantities.
◆ ieqhcf
integer ieqhcf
◆ iesicf
integer iesicf
  • A boundary value has to be given for the following quantities:
    • velocity
    • two of the four thermodynamical properties: density, pressure, total energy, temperature
    • all other variables.
  • Dirichlet condition for the velocity and the total energy.
  • The boundary convective fluxes of momentum and total energy are computed from a Rusanov scheme for stability reasons. Note that the pressure boundary value is needed to compute those two fluxes (seen by the pressure gradient of the momentum equation).
◆ ifrent
integer ifrent
◆ ifresf
integer ifresf
  • Homogeneous Neumann boundary condition for velocity and total energy (seen by the reconstruction gradients and the diffusion operator).
  • Dirichlet (icodcl=1) for the pressure.
◆ igliss
integer igliss
◆ iindef
integer iindef
◆ iparoi
integer iparoi
◆ iparug
integer iparug
◆ isolib
integer isolib
  • The pressure is always treated with a Dirichlet condition, calculated with the constraint $\displaystyle \frac{\partial }{\partial n}\left(\frac{ \partial P}{\partial \tau}\right)=0$. The pressure is set to $P_0$ at the first isolib face met. The pressure calibration is always done on a single face, even if there are several outlets.
  • if the mass flow is coming in, the velocity is set to zero and a Dirichlet condition for the scalars and the turbulent quantities is used (or zero-flux condition if no Dirichlet value has been specified).
  • if the mass flow is going out, zero-flux condition are set for the velocity, the scalars and the turbulent quantities.
  • Nothing is written in icodcl or rcodcl for the pressure or the velocity. An optional Dirichlet condition can be specified for the scalars and turbulent quantities.
    Remarks
    A standard isolib outlet face amounts to a Dirichlet condition (icodcl=1) for the pressure, a zero Dirichlet condition if the mass flux is entering (or a homogeneous Neumann if outgoing) for the velocity, and a Dirichlet condition (icodcl=1) if the user has specified a Dirichlet value or a zero-flux condition (icodcl=3) for the other variables.
◆ isopcf
integer isopcf
  • Boundary values are obtained by solving a Riemann problem between an inner (values at boundary cells center) and an outer state. The given pressure is considered as an outer value.
  • Dirichlet (icodcl=1) for the velocity and the total energy.
  • Analytical boundary convective fluxes of momentum and total energy are computed. Note that the pressure boundary value is needed to compute those two fluxes. (seen by the pressure gradient of the momentum equation).
◆ isspcf
integer isspcf
  • Nothing needs to be given. The imposed state at the boundary is the upstream state (values in boundary cells).
  • Dirichlet (icodcl=1) for the velocity and the total energy. (pressure boundary value seen by the pressure gradient of the momentum equation).
◆ isymet
integer isymet
  • Nothing to be writen in icodcl and rcodcl.
◆ ivimpo
integer ivimpo
  • In the case where all the nodes of a face have a imposed displacement, it is not necessary to fill the tables with boundary conditions mesh velocity for this face, they will be erased. In the other case, the value of the Dirichlet must be given in rcodcl(ifac,ivar,1) for every value of ivar (iuma, ivma and iwma). The other boxes of rcodcl and icodcl are completed automatically. The tangential mesh velocity is taken like a tape speed under the boundary conditions of wall for the fluid, except if wall fluid velocity was specified by the user in the interface or cs_user_boundary_conditions (in which case it is this speed which is considered).
◆ nscamx
integer nscamx
◆ nstrmx
integer nstrmx
◆ nvarmx
integer nvarmx
