8.3
Module for turbulence constants
+ Collaboration diagram for Module for turbulence constants:
double precision, save xkappa = 0.42d0
 $ \kappa $ Karman constant. (= 0.42) Useful if and only if iturb >= 10. (mixing length, $k-\varepsilon$, $R_{ij}-\varepsilon$, LES, v2f or $k-\omega$) More...
real(c_double), pointer, save ypluli
 limit value of $y^+$ for the viscous sublayer. ypluli depends on the chosen wall function: it is initialized to 10.88 for the scalable wall function (iwallf=4), otherwise it is initialized to $1/\kappa\approx 2,38$. In LES, ypluli is taken by default to be 10.88. More...
real(c_double), pointer, save cmu
 constant $C_\mu$ for all the RANS turbulence models Warning, different values for the v2f model Useful if and only if iturb = 20, 21, 30, 31, 50, 51 or 60 ( $k-\varepsilon$, $R_{ij}-\varepsilon$ or $k-\omega$) More...
real(c_double), pointer, save csrij
 Coefficient of interfacial coefficient in k-eps, used in Lagrange treatment. More...
double precision, save xcl = 0.122d0
 constant of the Rij-epsilon EBRSM More...
double precision, save xa1 = 0.1d0
 constant in the expression of Ce1' for the Rij-epsilon EBRSM More...
double precision, save xct = 6.d0
real(c_double), pointer, save almax
 is a characteristic macroscopic length of the domain, used for the initialization of the turbulence and the potential clipping (with iclkep=1) More...
real(c_double), pointer, save uref
 the characteristic flow velocity, used for the initialization of the turbulence. Negative value: not initialized. More...
real(c_double), pointer, save xlesfl
 constant used in the definition of LES filtering diameter: $ \delta = \text{xlesfl} . (\text{ales} . volume)^{\text{bles}}$ xlesfl is a constant used to define, for each cell $\omega_i$, the width of the (implicit) filter: $\overline{\Delta}=xlesfl(ales*|\Omega_i|)^{bles}$
Useful if and only if iturb = 40 or 41 More...
real(c_double), pointer, save ales
 constant used to define, for each cell $Omega_i$, the width of the (implicit) filter: More...
real(c_double), pointer, save bles
 constant used to define, for each cell $Omega_i$, More...
real(c_double), pointer, save csmago
 Smagorinsky constant used in the Smagorinsky model for LES. The sub-grid scale viscosity is calculated by $\displaystyle\mu_{sg}=
 \rho C_{smago}^2\bar{\Delta}^2\sqrt{2\bar{S}_{ij}\bar{S}_{ij}}$ where $\bar{\Delta}$ is the width of the filter and $\bar{S}_{ij}$ the filtered strain rate. More...
real(c_double), pointer, save xlesfd
 ratio between explicit and explicit filter width for a dynamic model constant used to define, for each cell $\Omega_i$, the width of the explicit filter used in the framework of the LES dynamic model: $\widetilde{\overline{\Delta}}=xlesfd\overline{\Delta}$. More...
real(c_double), pointer, save cdries
 van Driest constant appearing in the van Driest damping function applied to the Smagorinsky constant: More...
double precision, save volmin
 minimal control volume More...
double precision, save volmax
 maximal control volume More...
double precision, save voltot
 total domain volume More...
real(c_double), pointer, save xclt
 constant of EB-AFM and EB-DFM More...
◆ ales
  • $\overline{\Delta}=xlesfl(ales*|Omega_i|)^{bles}$
Useful if and only if iturb = 40 or 41.
◆ almax
  • Negative value: not initialized (the code then uses the cubic root of the domain volume).
Useful if and only if iturb = 20, 21, 30, 31, 50 or 60 (RANS models)
◆ bles
◆ cdries
  • $ (1-\exp^{(-y^+/cdries}) $.
◆ cmu
◆ csmago
Note
In theory Smagorinsky constant is 0.18. For a planar canal plan, 0.065 value is rather taken.
◆ csrij
constant $C_s$ for the $R_{ij}-\varepsilon$ models.
◆ uref
Useful if and only if iturb = 20, 21, 30, 31, 50 or 60 (RANS model) and the turbulence is not initialized somewhere else (restart file or subroutine cs_user_initialization)
◆ volmax
◆ volmin
◆ voltot
total domain volume
◆ xa1
◆ xcl
◆ xclt
◆ xct
◆ xkappa
◆ xlesfd
Useful if and only if iturb = 41
◆ xlesfl
◆ ypluli
Always useful
