double precision, dimension(:), pointer | tmmet |
| time (in sec) of the meteo profile More...
double precision, dimension(:), pointer | zdmet |
| altitudes of the dynamic profiles (read in the input meteo file) More...
double precision, dimension(:), pointer | dpdt_met |
| Pressure drop integrated over a time step (used for automatic open boundaries) More...
double precision, dimension(:,:), pointer | mom_met |
| Momentum for each level (used for automatic open boundaries) More...
double precision, dimension(:,:), pointer | mom |
double precision, dimension(:), pointer | ztmet |
| altitudes of the temperature profile (read in the input meteo file) More...
double precision, dimension(:,:), pointer | umet |
| meteo u profiles (read in the input meteo file) More...
double precision, dimension(:,:), pointer | vmet |
| meteo v profiles (read in the input meteo file) More...
double precision, dimension(:,:), pointer | wmet |
| meteo w profiles - unused More...
double precision, dimension(:,:), pointer | ekmet |
| meteo turbulent kinetic energy profile (read in the input meteo file) More...
double precision, dimension(:,:), pointer | epmet |
| meteo turbulent dissipation profile (read in the input meteo file) More...
double precision, dimension(:,:), pointer | ttmet |
| meteo temperature (Celsius) profile (read in the input meteo file) More...
double precision, dimension(:,:), pointer | qvmet |
| meteo specific humidity profile (read in the input meteo file) More...
double precision, dimension(:,:), pointer | ncmet |
| meteo specific droplet number profile (read in the input meteo file) More...
double precision, dimension(:,:), pointer | xyp_met |
| X, Y coordinates and sea level pressure of the meteo profile (read in the input meteo file) More...
double precision, dimension(:,:), pointer | rmet |
| density profile More...
double precision, dimension(:,:), pointer | tpmet |
| potential temperature profile More...
double precision, dimension(:,:), pointer | phmet |
| hydrostatic pressure from Laplace integration More...
integer, save | iymw |
| total water content (for humid atmosphere) More...
integer, save | intdrp = -1 |
| intdrp—> total number of droplets (for humid atmosphere) More...
integer, save | itempc |
| temperature (in Celsius) More...
integer, save | iliqwt |
| liquid water content More...
integer, save | imomst |
| momentum source term field id (useful when iatmst > 0) More...
integer(c_int), pointer, save | imeteo |
| flag for reading the meteo input file More...
integer(c_int), pointer, save | nbmetd |
| numbers of altitudes for the dynamics More...
integer(c_int), pointer, save | nbmett |
| numbers of altitudes for the temperature and specific humidity More...
integer(c_int), pointer, save | nbmetm |
| numbers of time steps for the meteo profiles More...
integer(c_int), pointer, save | iatmst |
| add a momentum source term based on the meteo profile for automatic open boundaries More...
integer(c_int), pointer, save | theo_interp |
| flag for meteo velocity field interpolation More...
real(c_double), pointer, save | ps |
| reference pressure (to compute potential temp: 1.0d+5) More...
integer(c_int), pointer, save | syear |
| starting year More...
integer(c_int), pointer, save | squant |
| starting quantile More...
integer(c_int), pointer, save | shour |
| starting hour More...
integer(c_int), pointer, save | smin |
| starting min More...
real(c_double), pointer, save | ssec |
| starting second More...
real(c_double), pointer, save | xlon |
| longitude of the domain origin More...
real(c_double), pointer, save | xlat |
| latitude of the domain origin More...
real(c_double), pointer, save | xl93 |
| x coordinate of the domain origin in Lambert-93 More...
real(c_double), pointer, save | yl93 |
| y coordinate of the domain origin in Lambert-93 More...
integer(c_int), pointer, save | nbmaxt |
| Number of vertical levels (cf. 1-D radiative scheme) More...
integer(c_int), pointer, save | ihpm |
| flag to compute the hydrostatic pressure by Laplace integration in the meteo profiles = 0 : bottom to top Laplace integration, based on P(sea level) (default) = 1 : top to bottom Laplace integration based on P computed for the standard atmosphere at z(nbmaxt) More...
integer(c_int), pointer, save | nvert |
| number of vertical arrays More...
integer(c_int), pointer, save | kvert |
| number of levels (up to the top of the domain) More...
integer(c_int), pointer, save | kmx |
| Number of levels (up to 11000 m if 1-D radiative transfer used) (automatically computed) More...
real(c_double), pointer, save | meteo_zi |
| Height of the boundary layer. More...
integer(c_int), pointer, save | iatra1 |
| flag for the use of the 1-D atmo radiative model More...
integer(c_int), pointer, save | nfatr1 |
| 1D radiative model pass frequency More...
integer(c_int), pointer, save | iqv0 |
| flag for the standard atmo humidity profile More...
integer(c_int), pointer, save | idrayi |
| pointer for 1D infrared profile More...
integer(c_int), pointer, save | idrayst |
| pointer for 1D solar profile More...
integer, save | igrid |
| grid formed by 1D profiles More...
double precision, dimension(:,:), pointer | xyvert |
| horizontal coordinates of the vertical grid More...
double precision, dimension(:), pointer | zvert |
| vertical grid for 1D radiative scheme initialize in cs_user_atmospheric_model.f90 More...
double precision, dimension(:), pointer | acinfe |
| absorption for CO2 + 03 More...
double precision, dimension(:), pointer | dacinfe |
| differential absorption for CO2 + 03 More...
double precision, dimension(:,:), pointer | aco2 |
| absorption for CO2 only More...
double precision, dimension(:,:), pointer | aco2s |
double precision, dimension(:,:), pointer | daco2 |
| differential absorption for CO2 only More...
double precision, dimension(:,:), pointer | daco2s |
double precision, dimension(:), pointer | acsup |
| idem acinfe, flux descendant More...
double precision, dimension(:), pointer | acsups |
double precision, dimension(:), pointer | dacsup |
| internal variable for 1D radiative model More...
double precision, dimension(:), pointer | dacsups |
double precision, dimension(:), pointer | tauzq |
double precision, dimension(:), pointer | tauz |
double precision, dimension(:), pointer | zq |
double precision, dimension(:), pointer | soil_albedo |
| Defines the soil constants and variables of the vertical arrays used for the 1D radiative model soil albedo. More...
double precision, dimension(:), pointer | soil_emissi |
| emissivity More...
double precision, dimension(:), pointer | soil_ttsoil |
| soil thermo temperature More...
double precision, dimension(:), pointer | soil_tpsoil |
| soil potential temperature More...
double precision, dimension(:), pointer | soil_totwat |
| total water content More...
double precision, dimension(:), pointer | soil_pressure |
| surface pressure More...
double precision, dimension(:), pointer | soil_density |
| density More...
double precision, save | tausup |
double precision, dimension(:), pointer | zray |
double precision, dimension(:,:), pointer | rayi |
double precision, dimension(:,:), pointer | rayst |
double precision, dimension(:,:), pointer | iru |
| Upward and downward radiative fluxes (infrared, solar) along each vertical. More...
double precision, dimension(:,:), pointer | ird |
double precision, dimension(:,:), pointer | solu |
double precision, dimension(:,:), pointer | sold |
integer(c_int), pointer, save | iatsoil |
| Option for soil model. More...
logical(c_bool), pointer, save | compute_z_ground |
| Do we compute z ground every where? More...
integer(c_int), pointer, save | modsub |
| Option for subgrid models. More...
integer(c_int), pointer, save | moddis |
| Option for liquid water content distribution models. More...
integer(c_int), pointer, save | modnuc |
| Option for nucleation. More...
integer(c_int), pointer, save | modsedi |
| sedimentation flag More...
integer(c_int), pointer, save | moddep |
| deposition flag More...
real(c_double), pointer, save | sigc |
| logaritmic standard deviation of the log-normal law of the droplet spectrum adimensional: sigc=0.53 other referenced values are 0.28, 0.15 More...
integer, save | init_at_chem |
| force initilization in case of restart (this option is automatically set in lecamp) More...
integer, save | kopint |
| key id for optimal interpolation More...
real(c_double), pointer, save | aod_o3_tot |
| Aerosol optical properties. More...
real(c_double), pointer, save | aod_h2o_tot |
| adimensional : aod_h2o_tot=0.10 other referenced values are 0.06, 0.08 More...
double precision, save | gaero_o3 |
| Asymmetry factor for O3 (non-dimensional) climatic value gaero_o3=0.66. More...
double precision, save | gaero_h2o |
| Asymmetry factor for H2O (non-dimensional) climatic value gaero_h2o=0.64. More...
double precision, save | piaero_o3 |
| Single scattering albedo for O3 (non-dimensional) climatic value piaero_o3=0.84, other referenced values are 0.963. More...
double precision, save | piaero_h2o |
| Single scattering albedo for H2O (non-dimensional) climatic value piaero_h2o=0.84, other referenced values are 0.964. More...
double precision, save | black_carbon_frac |
| Fraction of Black carbon (non-dimensional): black_carbon_frac=1.d-8 for no BC. More...
double precision, save | zaero |
| Maximal height for aerosol distribution on the vertical important should be <= zqq(kmray-1); in meters : referenced value: zaero=6000. More...
