#include "fvm_defs.h"
#include "fvm_nodal.h"
#include "fvm_writer.h"
| void * | fvm_to_histogram_init_writer (const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency) |
| void * | fvm_to_histogram_finalize_writer (void *writer) |
| void | fvm_to_histogram_set_mesh_time (void *writer, const int time_step, const double time_value) |
| void | fvm_to_histogram_export_field (void *writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[]) |
| void | fvm_to_histogram_flush (void *writer) |
◆ fvm_to_histogram_display_t
Function pointer to display histograms.
parameters: var_min <– minimum variable value var_max <– maximum variable value count <– count for each histogram slice f <– pointer to the histogram file
◆ cs_histogram_format_t
| Enumerator |
| CS_HISTOGRAM_TXT | |
| CS_HISTOGRAM_TEX | |
| CS_HISTOGRAM_PNG | |
◆ fvm_to_histogram_export_field()
| void fvm_to_histogram_export_field |
void * |
writer, |
const fvm_nodal_t * |
mesh, |
const char * |
name, |
fvm_writer_var_loc_t |
location, |
int |
dimension, |
cs_interlace_t |
interlace, |
int |
n_parent_lists, |
const cs_lnum_t |
parent_num_shift[], |
cs_datatype_t |
datatype, |
int |
time_step, |
double |
time_value, |
const void *const |
field_values[] |
◆ fvm_to_histogram_finalize_writer()
| void * fvm_to_histogram_finalize_writer |
void * |
writer | ) |
◆ fvm_to_histogram_flush()
| void fvm_to_histogram_flush |
void * |
writer | ) |
◆ fvm_to_histogram_init_writer()
| void * fvm_to_histogram_init_writer |
const char * |
name, |
const char * |
path, |
const char * |
options, |
fvm_writer_time_dep_t |
time_dependency |
◆ fvm_to_histogram_set_mesh_time()
| void fvm_to_histogram_set_mesh_time |
void * |
writer, |
const int |
time_step, |
const double |
time_value |
