void | cs_user_postprocess_writers (void) |
Define post-processing writers. More... | |
void | cs_user_postprocess_meshes (void) |
Define post-processing meshes. More... | |
void | cs_user_postprocess_probes (void) |
Define monitoring probes and profiles. More... | |
void | cs_user_postprocess_values (const char *mesh_name, int mesh_id, int cat_id, cs_probe_set_t *probes, cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, cs_lnum_t n_vertices, const cs_lnum_t cell_list[], const cs_lnum_t i_face_list[], const cs_lnum_t b_face_list[], const cs_lnum_t vertex_list[], const cs_time_step_t *ts) |
User function for output of values on a post-processing mesh. More... | |
void | cs_user_postprocess_activate (int nt_max_abs, int nt_cur_abs, double t_cur_abs) |
void cs_user_postprocess_activate | ( | int | nt_max_abs, |
int | nt_cur_abs, | ||
double | t_cur_abs | ||
Override default frequency or calculation end based output.
This allows fine-grained control of activation or deactivation,
[in] | nt_max_abs | maximum time step number |
[in] | nt_cur_abs | current time step number |
[in] | t_cur_abs | absolute time at the current time step |
void cs_user_postprocess_meshes | ( | void | ) |
The main post-processing meshes may be configured, and additional post-processing meshes may be defined as a subset of the main mesh's cells or faces (both interior and boundary).
void cs_user_postprocess_probes | ( | void | ) |
Profiles are defined as sets of probes.
void cs_user_postprocess_values | ( | const char * | mesh_name, |
int | mesh_id, | ||
int | cat_id, | ||
cs_probe_set_t * | probes, | ||
cs_lnum_t | n_cells, | ||
cs_lnum_t | n_i_faces, | ||
cs_lnum_t | n_b_faces, | ||
cs_lnum_t | n_vertices, | ||
const cs_lnum_t | cell_list[], | ||
const cs_lnum_t | i_face_list[], | ||
const cs_lnum_t | b_face_list[], | ||
const cs_lnum_t | vertex_list[], | ||
const cs_time_step_t * | ts | ||
[in] | mesh_name | name of the output mesh for the current call |
[in] | mesh_id | id of the output mesh for the current call |
[in] | cat_id | category id of the output mesh for the current call |
[in] | probes | pointer to associated probe set structure if the mesh is a probe set, null otherwise |
[in] | n_cells | local number of cells of post_mesh |
[in] | n_i_faces | local number of interior faces of post_mesh |
[in] | n_b_faces | local number of boundary faces of post_mesh |
[in] | n_vertices | local number of vertices faces of post_mesh |
[in] | cell_list | list of cells (0 to n-1) of post-processing mesh |
[in] | i_face_list | list of interior faces (0 to n-1) of post-processing mesh |
[in] | b_face_list | list of boundary faces (0 to n-1) of post-processing mesh |
[in] | vertex_list | list of vertices (0 to n-1) of post-processing mesh |
[in] | ts | time step status structure, or nullptr |
void cs_user_postprocess_writers | ( | void | ) |
The default output format and frequency may be configured, and additional post-processing writers allowing outputs in different formats or with different format options and output frequency than the main writer may be defined.
