◆ cs_turbulence_rij()
void cs_turbulence_rij |
int |
phase_id | ) |
Solve the
for incompressible flows or slightly compressible flows for one time step.
Please refer to the
model section of the theory guide for more informations, as well as the turrij section.
- Parameters
[in] | phase_id | turbulent phase id (-1 for single phase flow) ! |
◆ cs_turbulence_rij_clip()
void cs_turbulence_rij_clip |
int |
phase_id, |
cs_lnum_t |
n_cells |
Clip the turbulent Reynods stress tensor and the turbulent dissipation (coupled components version).
- Parameters
[in] | phase_id | turbulent phase id (-1 for single phase flow) |
[in] | n_cells | number of cells |
◆ cs_turbulence_rij_compute_rusanov()
void cs_turbulence_rij_compute_rusanov |
void |
Compute Rusanov equivalent diffusivity of the model.
◆ cs_turbulence_rij_init_by_ref_quantities()
Initialize Rij-epsilon variables based on reference quantities.
If uref is not provided (0 or negative), values are set at a large negative value (-cs_math_big_r) to allow for later checks.
- Parameters
[in] | uref | characteristic flow velocity |
[in] | almax | characteristic macroscopic length of the domain |
◆ cs_turbulence_rij_mu_t()
void cs_turbulence_rij_mu_t |
int |
phase_id | ) |
Compute the turbulent viscosity for the Reynolds Stress model.
- Parameters
◆ cs_turbulence_rij_solve_alpha()
void cs_turbulence_rij_solve_alpha |
int |
f_id, |
int |
phase_id, |
cs_real_t |
c_durbin_l |
Solve the equation on alpha in the framework of the Rij-EBRSM model.
Also called for alpha of scalars for EB-DFM.
- Parameters
[in] | f_id | field id of alpha variable |
[in] | c_durbin_l | constant for the Durbin length ! |
