8.3
cs_turbulence_ke.h
1#ifndef __CS_TURBULENCE_KE_H__
2#define __CS_TURBULENCE_KE_H__
5 * k-epsilon turbulence model.
31 * Local headers
34#include "cs_defs.h"
41 * Public function prototypes
44/*----------------------------------------------------------------------------*/
54/*----------------------------------------------------------------------------*/
55
56void
57cs_turbulence_ke(int phase_id,
58 cs_real_t *prdv2f);
59
60/*----------------------------------------------------------------------------*/
69/*----------------------------------------------------------------------------*/
70
71void
72cs_turbulence_ke_clip(int phase_id,
73 cs_lnum_t n_cells,
74 int iclip);
75
76/*----------------------------------------------------------------------------*/
82/*----------------------------------------------------------------------------*/
83
84void
85cs_turbulence_ke_mu_t(int phase_id);
86
87/*----------------------------------------------------------------------------*/
95/*----------------------------------------------------------------------------*/
96
97void
98cs_turbulence_ke_q_mu_t(int phase_id);
99
100/*----------------------------------------------------------------------------*/
108/*----------------------------------------------------------------------------*/
109
110void
111cs_turbulence_ke_q(int phase_id,
112 cs_real_6_t rij[]);
113
114/*----------------------------------------------------------------------------*/
115
117
118#endif /* __CS_TURBULENCE_KE_H__ */
Definition: cs_defs.h:542
Definition: cs_defs.h:342
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:361
Definition: cs_defs.h:543
Definition: cs_defs.h:335
@ rij
Definition: cs_field_pointer.h:75
void cs_turbulence_ke_q_mu_t(int phase_id)
Calculation of turbulent viscosity for the non-linear quadratic K-epsilon from Baglietto et al....
Definition: cs_turbulence_ke.cpp:2480
void cs_turbulence_ke_clip(int phase_id, cs_lnum_t n_cells, int iclip)
Clipping of the turbulent kinetic energy and turbulent dissipation.
Definition: cs_turbulence_ke.cpp:2161
void cs_turbulence_ke_q(int phase_id, cs_real_6_t rij[])
Calculation of non linear terms of the quadratic k-epsilon model (Baglietto et al....
Definition: cs_turbulence_ke.cpp:2594
void cs_turbulence_ke(int phase_id, cs_real_t *prdv2f)
Solve the k-epsilon equations.
Definition: cs_turbulence_ke.cpp:284
void cs_turbulence_ke_mu_t(int phase_id)
Calculation of turbulent viscosity for the K-epsilon model.
Definition: cs_turbulence_ke.cpp:2397
