8.3
cs_stl.h
1#ifndef __CS_STL_H__
2#define __CS_STL_H__
5 * STL reader and writer.
31 * Local headers
34#include "cs_defs.h"
35#include "fvm_nodal.h"
36#include "fvm_writer.h"
42/*=============================================================================
43 * Macro definitions
45
47 * Type definitions
49
50/*----------------------------------------------------------------------------
51 * Structure defining an STL mesh
52 *----------------------------------------------------------------------------*/
53
54typedef struct {
55
56 char name[20];
58 char header[80];
68 int n_seeds;
74 bool is_porous;
77 fvm_nodal_t *ext_mesh;
80
81/*----------------------------------------------------------------------------
82 * Structure containing the number of STL meshes and their associated pointers
83 *----------------------------------------------------------------------------*/
84
85typedef struct {
86
95
96/*=============================================================================
97 * Static global variables
98 *============================================================================*/
99
101
102/*=============================================================================
103 * Public function prototypes
104 *============================================================================*/
105
106/*-----------------------------------------------------------------------------
107 * Add a new STL mesh structure.
108 *
109 * parameters:
110 * path <-- path of the STL mesh
111 *
112 * returns:
113 * pointer to the new STL mesh structure
114 *----------------------------------------------------------------------------*/
115
117cs_stl_mesh_add(const char *path);
118
119/*----------------------------------------------------------------------------
120 * Return a pointer to a STL mesh based on its name if present.
121 *
122 * parameters:
123 * name <-- name of the STL mesh
124 *
125 * returns:
126 * pointer to the STL mesh structure, or NULL
127 *----------------------------------------------------------------------------*/
128
130cs_stl_mesh_get_by_name(const char *name);
131
132/*----------------------------------------------------------------------------
133 * Free all allocated STL mesh structures
134 *----------------------------------------------------------------------------*/
135
136void
138
139/*----------------------------------------------------------------------------
140 * Read a binary STL file and store its content in a STL mesh structure.
141 *
142 * parameters:
143 * stl_mesh <-- pointer to the associated STL mesh structure
144 * path <-- path to the STL file
145 *----------------------------------------------------------------------------*/
146
147void
149 const char *path);
150
151/*----------------------------------------------------------------------------
152 * Apply a transformation matrix to a STL mesh structure.
153 *
154 * parameters:
155 * stl_mesh <-- pointer to the associated STL mesh structure
156 * matrix <-- transformation matrix
157 *----------------------------------------------------------------------------*/
158
159void
161 double matrix[3][4]);
162
163/*----------------------------------------------------------------------------
164 * Apply a transformation matrix to a STL mesh structure, but use
165 * the initial coordinates as inputs
166 *
167 * parameters:
168 * stl_mesh <-- pointer to the associated STL mesh structure
169 * matrix <-- transformation matrix
170 *----------------------------------------------------------------------------*/
171
172void
174 double matrix[3][4]);
175
176/*----------------------------------------------------------------------------
177 * Apply a translation to a STL mesh structure.
178 *
179 * parameters:
180 * stl_mesh <-- pointer to the associated STL mesh structure
181 * vector <-- translation vector
182 *----------------------------------------------------------------------------*/
183
184void
186 double vector[3]);
187
188/*----------------------------------------------------------------------------
189 * Apply a rotation to a STL mesh structure.
190 *
191 * parameters:
192 * stl_mesh <-- pointer to the associated STL mesh structure
193 * tehta <-- rotation angle
194 * axis <-- rotation axis
195 * center <-- rotation center
196 *----------------------------------------------------------------------------*/
197
198void
200 double theta,
201 double axis[3],
202 double center[3]);
203
204/*----------------------------------------------------------------------------
205 * Apply a scaling to a STL mesh structure.
206 *
207 * parameters:
208 * stl_mesh <-- pointer to the associated STL mesh structure
209 * scale <-- scale factor
210 *----------------------------------------------------------------------------*/
211
212void
214 double scale);
215
216/*----------------------------------------------------------------------------
217 * Set the points outside he STL geometry. Those points will be used as seed
218 * to propagate porosity values outside the STL geometry.
219 *
220 * parameters:
221 * stl_mesh <-- pointer to the associated STL mesh structure
222 * n_points <-- number of points
223 * coords <-- coordinates (x1,y1,z1,...,xn,yn,zn)
224 * (size : 3*n_point)
225 *----------------------------------------------------------------------------*/
226
227void
229 int n_points,
230 cs_real_t *coords);
231
232/*----------------------------------------------------------------------------*/
236/*----------------------------------------------------------------------------*/
237
238int
240
241/*----------------------------------------------------------------------------
242 * Create a new writer that will contains the STL mesh added by the user
243 * The writer_id is stored in the cs_glob_stl_meshes structure.
244 *
245 * case_name associated case name
246 * dir_name associated directory name
247 * fmt_name associated format name
248 * fmt_opts associated format options string
249 * time_dep FVM_WRITER_FIXED_MESH if mesh definitions
250 * are fixed, FVM_WRITER_TRANSIENT_COORDS if
251 * coordinates change, FVM_WRITER_TRANSIENT_CONNECT if
252 * connectivity changes
253 * output_at_start force output at calculation start if true
254 * output_at_end force output at calculation end if true
255 * frequency_n default output frequency in time-steps, or < 0
256 * frequency_t default output frequency in secon
257 *----------------------------------------------------------------------------*/
258
259void
260cs_stl_post_init_writer(const char *case_name,
261 const char *dir_name,
262 const char *fmt_name,
263 const char *fmt_opts,
264 fvm_writer_time_dep_t time_dep,
265 bool output_at_start,
266 bool output_at_end,
267 int frequency_n,
268 double frequency_t);
269
270/*----------------------------------------------------------------------------
271 * Associate a STL mesh to the default writer
272 *
273 * stl_mesh <-- pointer to the associated STL mesh structure
274 *----------------------------------------------------------------------------*/
275
276void
278
279/*----------------------------------------------------------------------------
280 * Write a binary STL file according to a given STL mesh structure.
281 *
282 * parameters:
283 * stl_mesh <-- pointer to the associated STL mesh structure
284 * path <-- path to the STL file
285 *----------------------------------------------------------------------------*/
286
287void
289 const char *path);
290
291/*----------------------------------------------------------------------------
292 * Compute intersection between a STL mesh and the main mesh.
293 *
294 * parameters:
295 * stl_mesh <-- pointer to the associated STL mesh structure
296 * n_input <-- number of cells on which intersection is done
297 * input_index <-- index of input cells (size: n_input)
298 * n_selected_cells --> number of intersecting cells
299 * selected_cells --> index of output cells (size: n_output)
300 * tria_in_cell_idx --> start index of triangle intersecting each cell
301 * (size: n_output)
302 * tria_in_cell_lst --> list of triangles in intersecting cells
303 * max_size --> maximum size of tria_in_cell_lst array
304 *----------------------------------------------------------------------------*/
305
306void
308 cs_lnum_t n_input,
309 cs_lnum_t *input_idx,
310 cs_lnum_t *n_selected_cells,
311 cs_lnum_t *selected_cells,
312 cs_lnum_t *tria_in_cell_idx,
313 cs_lnum_t **tria_in_cell_lst,
314 cs_lnum_t *max_size);
315
316/*----------------------------------------------------------------------------
317 * Refine the mesh following a given STL mesh
318 *
319 * parameters:
320 * stl_mesh <-- pointer to the associated STL mesh structure
321 * n_ref <-- level of refinement
322 * n_add_layer <-- additional layers between two refinement stage
323 *----------------------------------------------------------------------------*/
324
325void
327 int n_ref,
328 int n_add_layer);
329
330/*----------------------------------------------------------------------------
331 * Compute porosity field according to a given STL mesh
332 *
333 * parameters:
334 * stl_mesh <-- pointer to the associated STL mesh structure
335 * n_ref_point <-- number of prescribed points outside the STL
336 * ref_coords <-- coordinates of the reference points :
337 * x1,y1,z1,...,xn,yn,zn (size : 3*n_ref_point)
338 * porosity --> interpolated porosity field
339 * indic --> indicator of the STL location (NULL if not needed)
340 *----------------------------------------------------------------------------*/
341
342void
344 cs_real_t *porosity,
345 int *indic);
346
347/*----------------------------------------------------------------------------*/
348
350
351#endif /* __CS_STL_H__ */
Definition: cs_defs.h:542
Definition: cs_defs.h:342
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:359
Definition: cs_defs.h:543
Definition: cs_defs.h:335
void cs_stl_mesh_destroy_all(void)
Free all allocated STL mesh structures.
Definition: cs_stl.cpp:1169
void cs_stl_mesh_rotate(cs_stl_mesh_t *stl_mesh, double theta, double axis[3], double center[3])
Definition: cs_stl.cpp:1562
void cs_stl_set_porosity_seed(cs_stl_mesh_t *stl_mesh, int n_points, cs_real_t *coords)
Set the points outside he STL geometry. Those points will be used as.
Definition: cs_stl.cpp:1609
cs_stl_mesh_t * cs_stl_mesh_add(const char *path)
Definition: cs_stl.cpp:1095
void cs_stl_post_add_mesh(cs_stl_mesh_t *stl_mesh)
Associate a STL mesh to the default writer.
Definition: cs_stl.cpp:1687
cs_stl_mesh_t * cs_stl_mesh_get_by_name(const char *name)
Definition: cs_stl.cpp:1148
void cs_stl_file_read(cs_stl_mesh_t *stl_mesh, const char *path)
Definition: cs_stl.cpp:1204
void cs_stl_file_write(cs_stl_mesh_t *stl_mesh, const char *path)
Definition: cs_stl.cpp:1717
void cs_stl_refine(cs_stl_mesh_t *stl_mesh, int n_ref, int n_add_layer)
Refine the mesh following a given STL mesh.
Definition: cs_stl.cpp:2016
void cs_stl_mesh_transform(cs_stl_mesh_t *stl_mesh, double matrix[3][4])
Definition: cs_stl.cpp:1463
void cs_stl_mesh_transform_from_init(cs_stl_mesh_t *stl_mesh, double matrix[3][4])
Apply a transformation matrix to a STL mesh structure, but use.
Definition: cs_stl.cpp:1500
int cs_stl_post_get_writer_id(void)
Return writer_id used for stl meshes. 0 means unused.
Definition: cs_stl.cpp:1627
void cs_stl_intersection(cs_stl_mesh_t *stl_mesh, cs_lnum_t n_input, cs_lnum_t *input_idx, cs_lnum_t *n_selected_cells, cs_lnum_t *selected_cells, cs_lnum_t *tria_in_cell_idx, cs_lnum_t **tria_in_cell_lst, cs_lnum_t *max_size)
Definition: cs_stl.cpp:1817
void cs_stl_mesh_translate(cs_stl_mesh_t *stl_mesh, double vector[3])
Definition: cs_stl.cpp:1534
void cs_stl_mesh_scale(cs_stl_mesh_t *stl_mesh, double scale)
Definition: cs_stl.cpp:1584
void cs_stl_post_init_writer(const char *case_name, const char *dir_name, const char *fmt_name, const char *fmt_opts, fvm_writer_time_dep_t time_dep, bool output_at_start, bool output_at_end, int frequency_n, double frequency_t)
Create a new writer that will contains the STL mesh added by the user.
Definition: cs_stl.cpp:1644
cs_stl_mesh_info_t * cs_glob_stl_meshes
void cs_stl_compute_porosity(cs_stl_mesh_t *stl_mesh, cs_real_t *porosity, int *indic)
Compute porosity field according to a given STL mesh.
Definition: cs_stl.cpp:2164
Definition: fvm_writer.h:57
double precision, dimension(:,:,:), allocatable theta
Definition: atimbr.f90:122
Definition: cs_stl.h:85
cs_stl_mesh_t ** mesh_list
Definition: cs_stl.h:87
int writer_id
Definition: cs_stl.h:92
cs_lnum_t n_meshes
Definition: cs_stl.h:90
Definition: cs_stl.h:54
cs_real_3_t * coords_ini
Definition: cs_stl.h:65
cs_lnum_t n_faces
Definition: cs_stl.h:60
Definition: cs_stl.h:62
bool is_porous
Definition: cs_stl.h:74
int n_seeds
Definition: cs_stl.h:68
cs_real_t * seed_coords
Definition: cs_stl.h:71
fvm_nodal_t * ext_mesh
Definition: cs_stl.h:77
