1#ifndef __CS_NAVSTO_SYSTEM_H__
2#define __CS_NAVSTO_SYSTEM_H__
133 void *scheme_context);
int cs_boundary_type_t
Definition: cs_boundary.h:69
Definition: cs_defs.h:542
Definition: cs_defs.h:342
Definition: cs_defs.h:543
Definition: cs_defs.h:335
Structure and functions handling the Maxwell module dedicated to the resolution of electro-magnetic e...
cs_flag_t cs_navsto_param_post_flag_t
Definition: cs_navsto_param.h:59
cs_navsto_param_coupling_t
Definition: cs_navsto_param.h:229
cs_navsto_param_model_t
Describe the system of equations related to the Navier-Stokes to be solved.
Definition: cs_navsto_param.h:82
cs_flag_t cs_navsto_param_model_flag_t
Definition: cs_navsto_param.h:58
cs_equation_t * cs_navsto_system_get_momentum_eq(void)
Retrieve a pointer to the equation related to the momentum equation.
Definition: cs_navsto_system.cpp:586
void cs_navsto_system_set_solid_cells(cs_lnum_t n_solid_cells, cs_lnum_t solid_cell_ids[])
Set a solid zone related to the Navier-Stokes equations.
Definition: cs_navsto_system.cpp:1493
void cs_navsto_system_log_setup(void)
Summary of the main cs_navsto_system_t structure.
Definition: cs_navsto_system.cpp:2094
void() cs_navsto_compute_t(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Compute for the current time step the new state for the Navier-Stokes system. This means that equatio...
Definition: cs_navsto_system.h:131
cs_navsto_param_t * cs_navsto_system_get_param(void)
Retrieve the structure storing the parameters for the Navier–Stokes system.
Definition: cs_navsto_system.cpp:567
void cs_navsto_system_destroy(void)
Free the main structure related to the Navier-Stokes system.
Definition: cs_navsto_system.cpp:484
cs_navsto_system_t * cs_navsto_system_activate(const cs_boundary_t *boundaries, cs_navsto_param_model_t model, cs_navsto_param_model_flag_t model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t post_flag)
Allocate and initialize the Navier-Stokes (NS) system.
Definition: cs_navsto_system.cpp:365
void cs_navsto_system_extra_op(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Predefined extra-operations for the Navier-Stokes system.
Definition: cs_navsto_system.cpp:1839
void cs_navsto_system_init_setup(void)
Start setting-up the Navier-Stokes system At this stage, numerical settings should be completely dete...
Definition: cs_navsto_system.cpp:671
void cs_navsto_system_finalize_setup(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Last step of the setup of the Navier-Stokes system.
Definition: cs_navsto_system.cpp:971
bool cs_navsto_system_is_activated(void)
Check if the resolution of the Navier-Stokes system has been activated.
Definition: cs_navsto_system.cpp:305
void cs_navsto_system_compute_steady_state(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Build, solve and update the Navier-Stokes system in case of a steady-state approach.
Definition: cs_navsto_system.cpp:1573
void cs_navsto_system_update(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Update variables and related quantities when a new state of the Navier-Stokes system has been compute...
Definition: cs_navsto_system.cpp:1536
void cs_navsto_system_define_context(const cs_mesh_t *mesh)
Initialize the scheme context structure used to build the algebraic system. This is done after the se...
Definition: cs_navsto_system.cpp:1375
void cs_navsto_system_extra_post(void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
Predefined post-processing output for the Navier-Stokes system. The prototype of this function is fix...
Definition: cs_navsto_system.cpp:1955
cs_real_t * cs_navsto_get_mass_flux(bool previous)
Retrieve the mass flux array related to the Navier-Stokes system.
Definition: cs_navsto_system.cpp:648
void cs_navsto_system_update_model(bool with_thermal)
Update the flag associated to the modelling options.
Definition: cs_navsto_system.cpp:322
void *() cs_navsto_free_scheme_context_t(void *scheme_context)
Free the context structure related to a given discretization scheme for the resolution of the Navier-...
Definition: cs_navsto_system.h:97
void cs_navsto_system_init_values(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Set an initial value for the velocity and pressure fields as well as mass fluxes and tubulent quantit...
Definition: cs_navsto_system.cpp:1420
cs_adv_field_t * cs_navsto_get_adv_field(void)
Retrieve the advection field structure (the mass flux) related to the Navier-Stokes system.
Definition: cs_navsto_system.cpp:626
void cs_navsto_system_compute(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Build, solve and update the Navier-Stokes system.
Definition: cs_navsto_system.cpp:1730
void() cs_navsto_init_values_t(const cs_navsto_param_t *nsp, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, cs_field_t *field)
According to the model, coupling algorithm and the space discretization, initialize the field values ...
Definition: cs_navsto_system.h:113
void *() cs_navsto_init_scheme_context_t(const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *fb_type, void *nscc)
Allocate and initialize the context structure related to a given discretization scheme for the resolu...
Definition: cs_navsto_system.h:77
Functions to handle the cs_thermal_system_t structure. This module can be used stand alone or linked ...
Definition: cs_time_plot.h:48
Definition: cs_advection_field.h:151
Structure storing information related to the "physical" boundaries associated with the computational ...
Definition: cs_boundary.h:155
Definition: cs_cdo_quantities.h:139
Definition: cs_field.h:131
Definition: cs_navsto_param.h:263
Structure managing the Navier-Stokes system.
Definition: cs_navsto_system.h:143
void * scheme_context
Definition: cs_navsto_system.h:326
cs_field_t * mass_density
Definition: cs_navsto_system.h:259
cs_navsto_init_values_t * init_pressure
Definition: cs_navsto_system.h:361
cs_field_t * velocity_gradient
Definition: cs_navsto_system.h:294
cs_navsto_init_values_t * init_velocity
Definition: cs_navsto_system.h:355
cs_real_t * mass_flux_array
Definition: cs_navsto_system.h:164
cs_navsto_compute_t * compute_steady
Definition: cs_navsto_system.h:368
cs_field_t * pressure
Definition: cs_navsto_system.h:196
cs_field_t * helicity
Definition: cs_navsto_system.h:281
cs_navsto_param_t * param
Definition: cs_navsto_system.h:149
cs_adv_field_t * adv_field
Definition: cs_navsto_system.h:156
cs_navsto_free_scheme_context_t * free_scheme_context
Definition: cs_navsto_system.h:348
cs_field_t * velocity_divergence
Definition: cs_navsto_system.h:237
cs_field_t * kinetic_energy
Definition: cs_navsto_system.h:251
cs_turbulence_t * turbulence
Definition: cs_navsto_system.h:213
Definition: cs_navsto_system.h:375
void * coupling_context
Definition: cs_navsto_system.h:318
cs_navsto_init_scheme_context_t * init_scheme_context
Definition: cs_navsto_system.h:340
cs_field_t * vorticity
Definition: cs_navsto_system.h:274
cs_real_t * mass_flux_array_pre
Definition: cs_navsto_system.h:172
cs_equation_t * stream_function_eq
Definition: cs_navsto_system.h:303
cs_field_t * mass_flux_balance
Definition: cs_navsto_system.h:267
cs_field_t * enstrophy
Definition: cs_navsto_system.h:288
cs_boundary_type_t * bf_type
Definition: cs_navsto_system.h:178
cs_field_t * pressure_gradient
Definition: cs_navsto_system.h:244
cs_time_plot_t * plot_writer
Definition: cs_navsto_system.h:230
Definition: cs_navsto_system.h:190
time step descriptor
Definition: cs_time_step.h:64
Structure storing the parameters related to the resolution of the turbulence modelling....
