| void | cs_macfb_monolithic_sles_init_sharing (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| | Set pointers to shared structures. More...
| void | cs_macfb_monolithic_sles_init_system_helper (const cs_navsto_param_t *nsp, const cs_param_saddle_t *saddlep, cs_macfb_monolithic_t *sc) |
| | Define the system helper for a MAC-Fb scheme solving the Navier-Stokes equation using a monolithic approach for the velocity-pressure coupling. More...
| void | cs_macfb_monolithic_sles_init_solver (const cs_navsto_param_t *nsp, const cs_param_saddle_t *saddlep, cs_macfb_monolithic_t *sc) |
| | Define the saddle solver and its context for a MAC-Fb scheme solving the Navier-Stokes equation using a monolithic approach for the velocity-pressure coupling. More...
| int | cs_macfb_monolithic_sles_alu (const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c) |
| | Solve a linear system arising from the discretization of the Navier-Stokes equation using a monolithic velocity-pressure coupling with a MAC face-based approach. Solve this system using the Augmented Lagrangian-Uzawa algorithm. More...
| int | cs_macfb_monolithic_sles_block_krylov (const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c) |
| | Solve a linear system arising from the discretization of the Navier-Stokes equation with a MAC face-based approach. The system is split into a velocity block and the (unassembled) divergence operator Block preconditioning using a Schur approximation on a Krylov solver such as the GCR or MINRES is available. More...
| int | cs_macfb_monolithic_sles_gkb_inhouse (const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c) |
| | Solve a linear system arising from the discretization of the Navier-Stokes equation using a monolithic velocity-pressure coupling with a MAC face-based approach. Solve this system using the Golub-Kahan Bidiagonalization algorithm. In-house implementation. The PETSc implementation is also available but appears less efficient in our tests. More...
| int | cs_macfb_monolithic_sles_uzawa_cg (const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c) |
| | Solve a linear system arising from the discretization of the Navier-Stokes equation using a monolithic velocity-pressure coupling with a MAC face-based approach. Solve this system using the Uzawa-CG algorithm. More...
◆ cs_macfb_monolithic_sles_alu()
- Parameters
| [in] | nsp | set of parameters related to the Navier-Stokes eqs. |
| [in,out] | solver | pointer to a cs_saddle_solver_t structure |
| [in,out] | u_f | values of the velocity at faces (1 components) |
| [in,out] | p_c | values of the pressure in cells |
- Returns
- the (cumulated) number of iterations of the solver
◆ cs_macfb_monolithic_sles_block_krylov()
- Parameters
| [in,out] | solver | pointer to a saddle-point solver |
| [in,out] | u_f | values of the velocity at faces |
- Returns
◆ cs_macfb_monolithic_sles_gkb_inhouse()
- Parameters
- Returns
◆ cs_macfb_monolithic_sles_init_sharing()
- Parameters
| [in] | connect | pointer to additional CDO connectivities |
| [in] | quant | pointer to additional CDO mesh quantities |
◆ cs_macfb_monolithic_sles_init_solver()
- Parameters
| [in] | nsp | set of parameters for the Navier-Stokes system |
| [in] | saddlep | parameters for solving a saddle-point problem |
| [in,out] | sc | pointer to a context structure cast on-the-fly |
◆ cs_macfb_monolithic_sles_init_system_helper()
- Parameters
| [in] | nsp | Navier-Stokes paremeters |
◆ cs_macfb_monolithic_sles_uzawa_cg()
- Parameters
- Returns
