1#ifndef __CS_EQUATION_BC_H__
2#define __CS_EQUATION_BC_H__
Definition: cs_defs.h:542
Definition: cs_defs.h:342
Definition: cs_defs.h:543
unsigned short int cs_flag_t
Definition: cs_defs.h:344
void cs_equation_bc_set_edge_flag(const cs_cdo_connect_t *connect, const cs_cdo_bc_face_t *face_bc, cs_flag_t *edge_flag)
Define an array of flags for each edge collecting the flags of associated boundary faces.
Definition: cs_equation_bc.cpp:1044
void() cs_cdo_enforce_bc_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Enforcement of a boundary condition (Dirichlet, Robin, sliding...)
Definition: cs_equation_bc.h:90
void() cs_cdo_apply_boundary_t(short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Apply a boundary condition for a given face (inlet, outlet, wall, sliding wall, symmetry....
Definition: cs_equation_bc.h:69
void cs_equation_bc_dirichlet_at_vertices(cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, cs_flag_t *bcflag, cs_real_t *values)
Compute the values of the Dirichlet BCs when DoFs are attached to vertices.
Definition: cs_equation_bc.cpp:1108
void cs_equation_bc_set_cw_eb(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Set the BC into a cellwise view of the current system. Case of edge-based schemes.
Definition: cs_equation_bc.cpp:544
void cs_equation_bc_dirichlet_at_faces(const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, cs_real_t t_eval, cs_real_t *values)
Compute the values of the Dirichlet BCs at boundary faces. This can be applied to CDO face-based sche...
Definition: cs_equation_bc.cpp:1312
void cs_equation_bc_cw_robin(cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *rob_values)
Compute the values of the Robin BCs for a face (cell-wise compute relying on the cs_cell_mesh_t struc...
Definition: cs_equation_bc.cpp:2046
void cs_equation_compute_neumann_svb(cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
Compute the values of the Neumann BCs when DoFs are scalar-valued and attached to a vertex-based sche...
Definition: cs_equation_bc.cpp:1550
void cs_equation_bc_circulation_at_edges(cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, cs_real_t *values)
Compute the values of the circulation along primal edges lying on the domain boundary (the integral o...
Definition: cs_equation_bc.cpp:2146
void cs_equation_bc_update_for_increment(cs_cell_sys_t *csys)
Update the boundary conditions to fullfill the constraint when an incremental solve is set.
Definition: cs_equation_bc.cpp:2233
void cs_equation_bc_set_cw_macfb(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_macfb_builder_t *macb, cs_cell_sys_t *csys)
Set the BC into a cellwise view of the current system. Case of MAC Face-based schemes.
Definition: cs_equation_bc.cpp:739
void cs_equation_compute_neumann_sfb(cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
Compute the values of the Neumann BCs when DoFs are attached to the face f. Case of scalar-valued equ...
Definition: cs_equation_bc.cpp:1762
void cs_equation_compute_neumann_vfb(cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
Compute the values of the Neumann BCs at the face f when DoFs are attached to faces....
Definition: cs_equation_bc.cpp:1949
void cs_equation_bc_set_cw_vb(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_flag_t vtx_bc_flag[], const cs_real_t dir_values[], cs_real_t t_eval, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Set the BC into a cellwise view of the current system. Case of vertex-based schemes.
Definition: cs_equation_bc.cpp:427
void cs_equation_bc_set_cw_fb(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Set the BC into a cellwise view of the current system. Case of CDO Face-based schemes.
Definition: cs_equation_bc.cpp:619
void cs_equation_compute_full_neumann_svb(cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
Definition: cs_equation_bc.cpp:1656
void cs_equation_bc_set_vertex_flag(const cs_cdo_connect_t *connect, const cs_cdo_bc_face_t *face_bc, cs_flag_t *vflag)
Define an array of flags for each vertex collecting the flags of associated boundary faces.
Definition: cs_equation_bc.cpp:984
void cs_equation_compute_full_neumann_sfb(cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
Definition: cs_equation_bc.cpp:1854
void cs_equation_bc_init_boundary_flux(cs_real_t t_eval, const cs_cdo_quantities_t *cdoq, const cs_equation_param_t *eqp, cs_real_t *values)
Set the values for the normal boundary flux stemming from the Neumann boundary conditions (zero is le...
Definition: cs_equation_bc.cpp:344
void cs_equation_bc_set_cw_cb(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Set the BC into a cellwise view of the current system. Case of Face-based schemes.
Definition: cs_equation_bc.cpp:887
@ fm
Definition: cs_field_pointer.h:129
Definition: cs_cdo_bc.h:106
Definition: cs_cdo_quantities.h:139
Definition: cs_cdo_local.h:60
Set of local quantities and connectivities related to a mesh face Structure used to get a better memo...
Definition: cs_cdo_local.h:280
Definition: cs_hodge.h:183
Definition: cs_macfb_builder.h:54
Structure storing the evaluation of a property and its related data.
Definition: cs_property.h:223
