◆ cs_cf_model_eos_t
| Enumerator |
| CS_EOS_NONE | |
| CS_EOS_IDEAL_GAS | |
| CS_EOS_STIFFENED_GAS | |
| CS_EOS_GAS_MIX | |
| CS_EOS_HOMOGENEOUS_TWO_PHASE | |
| CS_EOS_MOIST_AIR | |
◆ cs_cf_add_property_fields()
| void cs_cf_add_property_fields |
void |
Property field definitions for the compressible module, according to calculation type selected by the user.
◆ cs_cf_add_variable_fields()
| void cs_cf_add_variable_fields |
void |
Variable field definitions for the compressible module, according to calculation type selected by the user.
◆ cs_cf_initialize()
| void cs_cf_initialize |
void |
Initialize variables of the compressible flow model.
◆ cs_cf_model_log_setup()
| void cs_cf_model_log_setup |
void |
Print the compressible module options to setup.log.
◆ cs_cf_physical_properties()
| void cs_cf_physical_properties |
void |
Compute variable physical properties for the compressible module.
◆ cs_cf_setup()
| void cs_cf_setup |
void |
Setup options specific to the compressible model.
◆ cs_get_glob_cf_model()
Provide access to compressible model global structure cs_glob_cf_model.
◆ cs_glob_cf_model
