1#ifndef __CS_CDOVB_VECTEQ_H__
2#define __CS_CDOVB_VECTEQ_H__
void cs_cdovb_vecteq_solve_steady_state(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build and solve the linear system arising from a vector steady-state convection/diffusion/reaction eq...
Definition: cs_cdovb_vecteq.cpp:1337
bool cs_cdovb_vecteq_is_initialized(void)
Check if the generic structures for building a CDO-Vb scheme are allocated.
Definition: cs_cdovb_vecteq.cpp:699
void cs_cdovb_vecteq_finalize_sharing(void)
Free work buffer and general structure related to CDO vertex-based schemes.
Definition: cs_cdovb_vecteq.cpp:799
void cs_cdovb_vecteq_init_values(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the initial values of the variable field taking into account the boundary conditions....
Definition: cs_cdovb_vecteq.cpp:1222
void cs_cdovb_vecteq_init_sharing(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Allocate work buffer and general structures related to CDO vector-valued vertex-based schemes Set sha...
Definition: cs_cdovb_vecteq.cpp:720
void cs_cdovb_vecteq_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb)
Definition: cs_cdovb_vecteq.cpp:782
void cs_cdovb_vecteq_update_field(const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
Store solution(s) of the linear system into a field structure Update extra-field values if required (...
Definition: cs_cdovb_vecteq.cpp:1568
void * cs_cdovb_vecteq_free_context(void *builder)
Destroy a cs_cdovb_vecteq_t structure.
Definition: cs_cdovb_vecteq.cpp:1185
void cs_cdovb_vecteq_extra_post(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_cdovb_vecteq.cpp:1709
void cs_cdovb_vecteq_current_to_previous(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Operate a current to previous operation for the field associated to this equation and potentially for...
Definition: cs_cdovb_vecteq.cpp:1685
void * cs_cdovb_vecteq_init_context(cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a cs_cdovb_vecteq_t structure storing data useful for building and managing such a scheme.
Definition: cs_cdovb_vecteq.cpp:835
cs_real_t * cs_cdovb_vecteq_get_vertex_values(void *context, bool previous)
Retrieve an array of values at mesh vertices for the variable field associated to the given context T...
Definition: cs_cdovb_vecteq.cpp:1606
cs_real_t * cs_cdovb_vecteq_get_cell_values(void *context, bool previous)
Compute an array of values at mesh cells by interpolating the variable field associated to the given ...
Definition: cs_cdovb_vecteq.cpp:1638
Definition: cs_defs.h:542
Definition: cs_defs.h:342
Definition: cs_defs.h:543
double precision, dimension(:,:), pointer solu
Definition: atincl.f90:308
Definition: cs_cdo_quantities.h:139
Definition: cs_cdo_local.h:60
time step descriptor
Definition: cs_time_step.h:64
