character(len=12) | namgas |
double precision, pointer, save | pcigas |
double precision, dimension(:,:), pointer, save | coefeg |
double precision, dimension(:,:), pointer, save | compog |
integer | nmaxf |
integer | nmaxfm |
integer | nmaxh |
integer | nmaxhm |
integer(c_int), dimension(:), pointer, save | ientox |
integer(c_int), dimension(:), pointer, save | ientfu |
double precision, save | hstoea |
double precision, dimension(nmaxhm), save | hh |
double precision, dimension(nmaxfm), save | ff |
double precision, dimension(nmaxfm, nmaxhm), save | tfh |
real(c_double), pointer, save | tinfue |
real(c_double), pointer, save | tinoxy |
real(c_double), pointer, save | hinfue |
real(c_double), pointer, save | hinoxy |
integer, save | ngazfl |
integer, save | nki |
integer, save | nxr |
integer, save | nzm |
integer, save | nzvar |
integer, save | nlibvar |
integer, save | ikimid = 1 |
integer, save | mode_fp2m = 1 |
double precision, save | coef_k = 7.d-2 |
integer, save | flamelet_zm |
integer, save | flamelet_zvar |
integer, save | flamelet_ki |
integer, save | flamelet_xr |
integer, save | flamelet_temp |
integer, save | flamelet_rho |
integer, save | flamelet_vis |
integer, save | flamelet_dt |
integer, save | flamelet_temp2 |
integer, save | flamelet_hrr |
integer, dimension(ngazgm), save | flamelet_species |
integer, save | flamelet_c |
integer, save | flamelet_omg_c |
character(len=12), dimension(ngazgm) | flamelet_species_name |
double precision, dimension(:,:,:,:,:), allocatable | flamelet_library |
| Library for thermochemical properties in SLFM. More...
double precision, dimension(:,:,:,:,:,:), allocatable | radiation_library |
| Library for radiative properties in SLFM. More...
integer(c_int), dimension(:), pointer, save | ientgf |
integer(c_int), dimension(:), pointer, save | ientgb |
real(c_double), dimension(:), pointer, save | qimp |
real(c_double), dimension(:), pointer, save | fment |
real(c_double), dimension(:), pointer, save | tkent |
real(c_double), pointer, save | frmel |
real(c_double), pointer, save | tgf |
double precision, save | cebu |
double precision, save | hgf |
double precision, save | tgbad |
integer | ndracm |
integer, save | ndirac |
integer, dimension(ndracm), save | irhol |
integer, dimension(ndracm), save | iteml |
integer, dimension(ndracm), save | ifmel |
integer, dimension(ndracm), save | ifmal |
integer, dimension(ndracm), save | iampl |
integer, dimension(ndracm), save | itscl |
integer, dimension(ndracm), save | imaml |
integer, dimension(ndracm), save | ihhhh |
integer, save | imam |
double precision, save | vref |
double precision, save | lref |
double precision, save | ta |
double precision, save | tstar |
real(c_double), pointer, save | fmin |
real(c_double), pointer, save | fmax |
real(c_double), pointer, save | hmin |
real(c_double), pointer, save | hmax |
double precision, save | coeff1 |
double precision, save | coeff2 |
double precision, save | coeff3 |
integer(c_int), pointer, save | isoot |
real(c_double), pointer, save | xsoot |
real(c_double), pointer, save | rosoot |
logical(c_bool), pointer, save | use_janaf |
| use JANAF or not More...
integer, save | ifm |
| pointer to specify the mixing rate in isca(ifm) More...
integer, save | ifp2m |
| pointer to specify the variance of the mixing rate in isca(ifp2m) More...
integer, save | ifsqm |
| pointer to specify the second moment of the mixing rate in isca(ifsqm): More...
integer, save | ipvm |
| pointer to specify the transported progress variable ippmod(islfm) >= 2: More...
integer, save | iygfm |
| pointer to specify the fresh gas mass fraction in isca(iygfm) More...
integer, save | icm |
| the intersection computation mode. If its value is: More...
integer, save | icp2m |
| transported variable More...
integer, save | ifpcpm |
integer, save | iyfm |
integer, save | iyfp2m |
integer, save | icoyfp |
integer, dimension(ngazgm), save | iym |
| mass fractions : More...
integer, dimension(ngazgm), save | ibym |
integer, save | itemp |
| state variable (temperature) More...
integer, save | ifmin |
| state variable More...
integer, save | ifmax |
integer, save | irecvr |
| state variable: Pointer to the reconstructed variance in case of mode_fp2m = 1 More...
integer, save | itotki |
| state variable: Pointer to the total scalar dissipation rate More...
integer, save | ihrr |
| state variable: Pointer to volumetric heat release rate More...
integer, save | ixr |
| state variable: Pointer to enthalpy defect More...
integer, save | iomgc |
integer, save | ickabs |
| state variable: absorption coefficient, when the radiation modelling is activated More...
integer, save | it2m |
| state variable: term More...
integer, save | it3m |
| state variable: term, when the radiation modelling is activated More...
integer, save | it4m |
integer, save | itsc |
integer, save | inpm |
| pointer for soot precursor number in isca (isoot = 1) More...
integer, save | ifsm |
| pointer for soot mass fraction in isca (isoot = 1) More...
Module for gas combustion.
