Module for the atmospheric soil model adapted to the IGN "land use" file format. More...
Modules | |
| module | atsoil |
| integer, save | nfmodsol |
| Number of boundary faces with soil features. More... | |
| integer, save | nbrsol |
| Number of soil model's type. More... | |
| real(c_double), pointer, save | tsini |
| initial soil surface temperature for Sea, it is also the surface temperature More... | |
| real(c_double), pointer, save | tprini |
| initial deep soil temperature More... | |
| real(c_double), pointer, save | qvsini |
| initial soil specific humidity More... | |
| real(c_double), pointer, save | w1ini |
| initial water content of the first reservoir More... | |
| real(c_double), pointer, save | w2ini |
| initial water content of the second reservoir More... | |
| double precision, dimension(:), pointer | csol |
| Thermal inertia of the soil. More... | |
| double precision, dimension(:), pointer | rugdyn |
| Dynamic roughness length. More... | |
| double precision, dimension(:), pointer | rugthe |
| Thermal roughness length. More... | |
| double precision, dimension(:), pointer | soil_cat_albedo |
| Albedo. More... | |
| double precision, dimension(:), pointer | soil_cat_emissi |
| emissivity More... | |
| double precision, dimension(:), pointer | soil_cat_vegeta |
| Vegetation index. More... | |
| double precision, dimension(:), pointer | soil_cat_c1w |
| maximum water capacity of shallow reservoir More... | |
| double precision, dimension(:), pointer | soil_cat_c2w |
| ratio of the maximum water capacity of the shallow reservoir to the deep reservoir [0,1] More... | |
| double precision, dimension(:), pointer | soil_cat_r1 |
| Rij value for Rij1. More... | |
| double precision, dimension(:), pointer | soil_cat_r2 |
| Rij value for Rij2. More... | |
