#include <cs_combustion_gas.h>
Collaboration diagram for cs_combustion_gas_model_t:Gas combustion model parameters structure
mass fraction conversion coefficients from global species to elementary species
mole fraction conversion coefficients from global species to elementary species
cpgazg[j][i] is the massic calorific capacity (J/kg/K) of the i-th global species at temperature
| char* data_file_name |
| double fmax_lwc |
| double fmin_lwc |
Libby Williams parameters
| double fs[CS_COMBUSTION_GAS_MAX_GLOBAL_REACTIONS] |
Mixing rate at the stoichiometry
| double hinfue |
input mass enthalpy for fuel
| double hinoxy |
input mass enthalpy for the oxidant
| double hmax_lwc |
| double hmin_lwc |
| int iic |
use NIST-JANAF tables for enthalpy/temperature conversion rank of C in gas composition (base 1)
| int iico2 |
rank of CO2 in gas composition (base 1)
| int iio2 |
rank of O2 in gas composition (base 1)
| int isoot |
soot production modeling flag
| int n_atomic_species |
number of atomic species
| int n_gas_el_comp |
number of elementary gas components
| int n_gas_species |
number of global species
| int n_reactions |
number of global reactions in gas phase
| int n_tab_points |
number of tabulation points
| double oxyco2[CS_COMBUSTION_GAS_MAX_OXYDANTS] |
composition of CO2 oxidants
| double oxyh2o[CS_COMBUSTION_GAS_MAX_OXYDANTS] |
composition of H2O oxidants
| double oxyn2[CS_COMBUSTION_GAS_MAX_OXYDANTS] |
composition of N2 oxidants
| double pcigas |
combustible reaction enthalpy (Lower Calorific Value)
| double rosoot |
soot density
| double srrom |
sub-relaxation coefficient for the density:
(hence, with a zero value, there is no sub-relaxation)
| double th[CS_COMBUSTION_GAS_MAX_TABULATION_POINTS] |
temperature in K
| double tinfue |
input temperature for fuel en K
| double tinoxy |
input temperature for oxydant
combustion model type
| bool use_janaf |
| double wmolat[CS_COMBUSTION_GAS_MAX_ATOMIC_SPECIES] |
molar mass of atomic species
| double wmole[CS_COMBUSTION_GAS_MAX_ELEMENTARY_COMPONENTS] |
molar mass of an elementary gas component
| double wmolg[CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES] |
molar mass of global species
| double xco2 |
molar coefficient of CO2
| double xh2o |
molar coefficient of H2O
| double xsoot |
soot fraction production (isoot = 0)
