8.2
rayir.f90 File Reference
Compute infrared flux divergence profile and downward flux at ground level relying on a 1D radiative scheme. More...
Functions/Subroutines
subroutine rayir (ivertc, k1, kmray, ico2, emis, qqv, qqqv, qqvinf, zqq, acinfe, dacinfe, aco2, daco2, aco2s, daco2s, acsup, dacsup, acsups, dacsups, zray, temray, qvray, qlray, fnerir, romray, preray, aeroso, foir, rayi, ncray)
More precisely, compute atmospheric infrared (IR) radiation model quantities:
  • vertical profile of IR flux divergence,
  • downward IR flux at ground level
  • upward and downward fluxes at different vertical levels
◆ rayir()
subroutine rayir ( integer  ivertc,
integer  k1,
integer  kmray,
integer  ico2,
double precision  emis,
double precision, dimension(kmx+1)  qqv,
double precision, dimension(kmx+1)  qqqv,
double precision  qqvinf,
double precision, dimension(kmx)  zqq,
double precision, dimension(kmx)  acinfe,
double precision, dimension(kmx)  dacinfe,
double precision, dimension(kmx,kmx)  aco2,
double precision, dimension(kmx,kmx)  daco2,
double precision, dimension(kmx,kmx)  aco2s,
double precision, dimension(kmx,kmx)  daco2s,
double precision, dimension(kmx)  acsup,
double precision, dimension(kmx)  dacsup,
double precision, dimension(kmx)  acsups,
double precision, dimension(kmx)  dacsups,
double precision, dimension(kmx)  zray,
double precision, dimension(kmx)  temray,
double precision, dimension(kmx)  qvray,
double precision, dimension(kmx)  qlray,
double precision, dimension(kmx)  fnerir,
double precision, dimension(kmx)  romray,
double precision, dimension(kmx)  preray,
double precision, dimension(kmx)  aeroso,
double precision  foir,
double precision, dimension(kmx)  rayi,
double precision, dimension(kmx)  ncray
[in]ivertcindex of vertical profile
[in]k1index corresponding to ground level
[in]kmraynumber of vertical levels for radiation computation
[in]ico2if ico2=1, then compute CO2 absorption
[in]emisground surface emissivity
[in]qqvwater vapor + dimers optical depth (0,z)
[in]qqqvidem qqv but for intermediates vertical levels
[in]qqvinfidem qqv but for contribution above 11000m
[in]zqqvertical coordinate
[in]acinfeabsorption for CO2 + O3 (0,z)
[in]dacinfedifferential absorption for CO2 + 03 (0,z)
[in]aco2idem acinfe but for CO2 only
[in]daco2idem dacinfe but for CO2 only
[in]aco2sidem acinfe but for CO2 only
[in]daco2sidem dacinfe but for CO2 only
[in]acsupidem acinfe, for (z,0)
[in]dacsupidem dacinfe, for (z,0)
[in]acsupsidem acinfe, for (z,0)
[in]dacsupsidem dacinfe, for (z,0)
[in]zrayaltitude (physical mesh)
[in]temraytemperature in Celsius
[in]qvrayspecific humidity for water vapor
[in]qlrayspecific humidity for liquid water
[in]fnerircloud fraction
[in]romrayair density
[in]preraypressure
[in]aerosoaerosol concentration in micro-g/m3
[out]foirdownward IR flux at the ground
[out]rayiIR flux divergence
[in]ncrayNumber of droplets interpolated on vertical grid
