Functions/Subroutines | |
| subroutine | pthrbm (nvar, nfbpcd, ncmast, dt, spcond, svcond) |
| Update the density | |
| subroutine | compute_td_pressure_perfect_gas (nvar, nfbpcd, ncmast, dt, spcond, svcond, new_pther) |
| Compute the thermodynamic pressure for a perfect gas. More... | |
| subroutine compute_td_pressure_perfect_gas | ( | integer, intent(in) | nvar, |
| integer, intent(in) | nfbpcd, | ||
| integer, intent(in) | ncmast, | ||
| double precision, dimension(ncelet), intent(in) | dt, | ||
| double precision, dimension(nfbpcd,nvar), intent(in) | spcond, | ||
| double precision, dimension(ncelet,nvar), intent(in) | svcond, | ||
| double precision, intent(out) | new_pther | ||
| [in] | nfbpcd | number of faces with condensation source terms |
| [in] | ncmast | number of cells with condensation source terms |
| [in] | spcond | variable value associated to the condensation source term (for ivar=ipr, spcond is the flow rate |
| [in] | svcond | variable value associated to the condensation source term (for ivar=ipr, svcond is the flow rate |
| subroutine pthrbm | ( | integer | nvar, |
| integer | nfbpcd, | ||
| integer | ncmast, | ||
| double precision, dimension(ncelet) | dt, | ||
| double precision, dimension(nfbpcd,nvar) | spcond, | ||
| double precision, dimension(ncelet,nvar) | svcond | ||
Update the density
with the
density with the state law and a thermodynamic pressure
estimated from the integral over the total fluid domain of the mass conservation equation.
