Collaboration diagram for Time step options and variables:Variables | |
| integer(c_int), pointer, save | ntpabs |
| Absolute time step number for previous calculation. More... | |
| integer(c_int), pointer, save | ntcabs |
| Current absolute time step number. In case of restart, this is equal to ntpabs + number of new iterations. More... | |
| integer(c_int), pointer, save | ntmabs |
| Maximum absolute time step number. More... | |
| integer(c_int), pointer, save | ntinit |
| Number of time steps for initalization (for all steps between 0 and ntinit, pressure is re-set to 0 before prediction correction). More... | |
| real(c_double), pointer, save | ttpabs |
| Absolute time value for previous calculation. More... | |
| real(c_double), pointer, save | ttcabs |
| Current absolute time. More... | |
| real(c_double), pointer, save | ttmabs |
| Maximum absolute time. More... | |
| integer(c_int), pointer, save | iptlro |
| Clip the time step with respect to the buoyant effects. More... | |
| integer(c_int), pointer, save | idtvar |
| option for a variable time step More... | |
| real(c_double), pointer, save | dtref |
| Reference time step. More... | |
| real(c_double), pointer, save | coumax |
| maximum Courant number (when idtvar is different from 0) More... | |
| real(c_double), pointer, save | cflmmx |
| maximum Courant number for the continuity equation in compressible model More... | |
| real(c_double), pointer, save | foumax |
| maximum Fourier number (when idtvar is different from 0) More... | |
| real(c_double), pointer, save | varrdt |
| maximum allowed relative increase in the calculated time step value between two successive time steps (to ensure stability, any decrease in the time step is immediate and without limit). Useful when idtvar is different from 0. More... | |
| real(c_double), pointer, save | dtmin |
| lower limit for the calculated time step when idtvar is different from 0. Take dtmin = min (ld/ud, sqrt(lt/(gdelta rho/rho)), ...) More... | |
| real(c_double), pointer, save | dtmax |
| upper limit for the calculated time step when idtvar is different from 0. Take dtmax = max (ld/ud, sqrt(lt/(gdelta rho/rho)), ...) More... | |
| real(c_double), pointer, save | relxst |
| relaxation coefficient for the steady algorithm relxst = 1 : no relaxation. More... | |
| real(c_double), pointer, save cflmmx |
| real(c_double), pointer, save coumax |
| real(c_double), pointer, save dtmax |
| real(c_double), pointer, save dtmin |
| real(c_double), pointer, save dtref |
This is the time step value used in the case of a calculation run with a uniform and constant time step, i.e. idtvar =0 (restart calculation or not). It is the value used to initialize the time step in the case of an initial calculation run with a non-constant time step(idtvar=1 or 2). It is also the value used to initialise the time step in the case of a restart calculation in which the type of time step has been changed (for instance, idtvar=1 in the new calculation and idtvar = 0 or 2 in the previous calculation).
See Time step modification for examples.
| real(c_double), pointer, save foumax |
| integer(c_int), pointer, save idtvar |
| integer(c_int), pointer, save iptlro |
When density gradients and gravity are present, a local thermal time step can be calculated, based on the Brunt-Vaisala frequency. In numerical simulations, it is usually wise for the time step to be lower than this limit, otherwise numerical instabilities may appear.
iptlro indicates whether the time step should be limited to the local thermal time step (=1) or not (=0).
When iptlro=1, the log shows the number of cells where the time step has been clipped due to the thermal criterion, as well as the maximum ratio between the time step and the maximum thermal time step. If idtvar=0, since the time step is fixed and cannot be clipped, this ratio can be greater than 1. When idtvar > 0, this ratio will be less than 1, except if the constraint dtmin has prevented the code from reaching a sufficiently low value for dt. Useful when density gradients and gravity are present.
| integer(c_int), pointer, save ntcabs |
| integer(c_int), pointer, save ntinit |
| integer(c_int), pointer, save ntmabs |
| integer(c_int), pointer, save ntpabs |
| real(c_double), pointer, save relxst |
| real(c_double), pointer, save ttcabs |
For the restart calculations, ttcabs takes into account the physical time of the previous calculations.
If the time step is uniform (idtvar = 0 or 1), ttcabs increases of dt (value of the time step) at each iteration. If the time step is non-uniform (idtvar=2), ttcabs increases of dtref at each time step.
ttcabs} is initialised and updated automatically by the code, its value is not to be modified by the user.
| real(c_double), pointer, save ttmabs |
| real(c_double), pointer, save ttpabs |
| real(c_double), pointer, save varrdt |
