| integer | nscamx |
| | maximum number of scalars solutions of an advection equation, apart from the variables of the turbulence model ) , that is to say the temperature and other scalars (passive or not, user-defined or not) More...
| integer | nvarmx |
| | maximal number of variables = nscamx + 12 (u,v,w,P,Rij,e,alp) More...
| integer | iindef |
| | pointer for undefined type face (non-standard case) More...
| integer | ientre |
| | if itypfb=ientre: inlet face. More...
| integer | isolib |
| | if itypfb=isolib: free outlet face (or more precisely free inlet/outlet with forced pressure) More...
| integer | isymet |
| | if itypfb=isymet: symmetry face (or wall without friction). More...
| integer | iparoi |
| | if itypfb=iparoi: smooth solid wall face, impermeable and with friction. More...
| integer | iparug |
| | if itypfb=iparug: rough solid wall face, impermeable and with friction. More...
| integer | iesicf |
| | if itypfb=iesicf: imposed inlet/outlet for compressible flow (for example, supersonic inlet). More...
| integer | isspcf |
| | if itypfb=isspcf: supersonic outlet for compressible flow. More...
| integer | isopcf |
| | if itypfb=isopcf: mixed outlet for compressible flow with a given pressure. More...
| integer | iephcf |
| | if itypfb=iephcf: mixed inlet for compressible flow with given total pressure and total enthalpy (reservoir boundary conditions). More...
| integer | ieqhcf |
| integer | icscpl |
| | code/code coupling condition More...
| integer | icscpd |
| | code/code coupling condition with decentered flux More...
| integer | ifrent |
| | if itypfb=ifrent: free entrance based on Bernoulli equation when the flow is incoming, standard outlet when outgoing More...
| integer | ifresf |
| | if itypfb=ifresf: free surface for mobile mesh boundary condition More...
| integer | i_convective_inlet |
| | if itypfb=i_convective_inlet: inlet face where the total mass flux is prescribed. More...
| integer | ibfixe |
| | boundary condition type for mesh velocity in ALE: fixed wall More...
| integer | igliss |
| | boundary condition type for mesh velocity in ALE: sliding wall More...
| integer | ivimpo |
| | boundary condition type for mesh velocity in ALE: imposed velocity. More...
| integer | ibalfs |
| | Boundary condition type for mesh velocity in ALE for modelling free surface ( ). More...
| integer | nstrmx |
| | maximum number of structures in ALE More...
