8.2
cs_thermal_system.h
1 #ifndef __CS_THERMAL_SYSTEM_H__
2 #define __CS_THERMAL_SYSTEM_H__
5  * Functions to handle cs_thermal_system_t structure
29  * Local headers
32 #include "cs_advection_field.h"
33 #include "cs_equation.h"
34 #include "cs_field.h"
35 #include "cs_property.h"
36 #include "cs_mesh.h"
37 #include "cs_source_term.h"
38 #include "cs_time_step.h"
39 #include "cs_xdef.h"
46  * Macro definitions
48
49 /* Generic name given to fields and equations related to this module */
50
51 #define CS_THERMAL_EQNAME "thermal_equation"
52 #define CS_THERMAL_CP_NAME "thermal_capacity"
53 #define CS_THERMAL_LAMBDA_NAME "thermal_conductivity"
54
66 #define CS_THERMAL_POST_ENTHALPY (1 << 0) /* 1 */
67
72 /*=============================================================================
73  * Structure and type definitions
74  *============================================================================*/
75
77
106 typedef enum {
107
108  CS_THERMAL_MODEL_STEADY = 1<<0, /* = 1 */
110
111  /* Main variable to consider (by default the temperature in Kelvin)
112  ---------------------------------------------------------------- */
113
117
118  /* Treatment of the diffusion term
119  ------------------------------- */
120
122
123  /* Additional bit settings
124  ----------------------- */
125
126  CS_THERMAL_MODEL_IN_CELSIUS = 1<<7 /* = 128 */
127
129
130 /* Set of parameters related to the thermal module */
131
132 typedef struct {
133
134  cs_flag_t model; /* Choice of modelling */
135  cs_flag_t numeric; /* General numerical options */
136  cs_flag_t post; /* Post-processing options */
137
138  /* Equation associated to this module */
139  /* ---------------------------------- */
140
142
143  /* Properties associated to this module */
144  /* ------------------------------------ */
145
146  cs_property_t *unsteady_property; /* Property of the unsteady term: rho.cp */
147  cs_property_t *lambda; /* Thermal conductivity */
148  cs_property_t *cp; /* Heat capacity */
149  cs_property_t *rho; /* Mass density (may be shared) */
150  cs_property_t *kappa; /* lambda/cp may be NULL*/
151
152  /* value of lambda/cp in each cell (allocated if the related property kappa
153  * is not NULL and defined by array) */
155
156  /* Fields associated to this module */
157  /* -------------------------------- */
158
162
163  /* Additional members */
164  /* ------------------ */
165
167
168  /* N.B.: Other reference values for properties are stored within each
169  * property structure */
170
172
173 /*============================================================================
174  * Public function prototypes
175  *============================================================================*/
176
177 /*----------------------------------------------------------------------------*/
184 /*----------------------------------------------------------------------------*/
185
186 cs_real_t
188
189 /*----------------------------------------------------------------------------*/
196 /*----------------------------------------------------------------------------*/
197
198 void
200
201 /*----------------------------------------------------------------------------*/
207 /*----------------------------------------------------------------------------*/
208
209 cs_flag_t
211
212 /*----------------------------------------------------------------------------*/
219 /*----------------------------------------------------------------------------*/
220
221 bool
223
224 /*----------------------------------------------------------------------------*/
230 /*----------------------------------------------------------------------------*/
231
232 bool
234
235 /*----------------------------------------------------------------------------*/
245 /*----------------------------------------------------------------------------*/
246
249  cs_flag_t numeric,
250  cs_flag_t post);
251
256 /*----------------------------------------------------------------------------*/
257
258 void
260
261 /*----------------------------------------------------------------------------*/
265 /*----------------------------------------------------------------------------*/
266
269
270 /*----------------------------------------------------------------------------*/
276 /*----------------------------------------------------------------------------*/
277
278 cs_real_t *
280
281 /*----------------------------------------------------------------------------*/
287 /*----------------------------------------------------------------------------*/
288
289 void
291
292 /*----------------------------------------------------------------------------*/
300 /*----------------------------------------------------------------------------*/
301
302 void
304  const cs_cdo_quantities_t *quant,
305  const cs_time_step_t *time_step);
306
307 /*----------------------------------------------------------------------------*/
316 /*----------------------------------------------------------------------------*/
317
318 void
320  const cs_cdo_connect_t *connect,
321  const cs_cdo_quantities_t *quant,
322  const cs_time_step_t *time_step);
323
324 /*----------------------------------------------------------------------------*/
334 /*----------------------------------------------------------------------------*/
335
336 void
337 cs_thermal_system_compute(bool cur2prev,
338  const cs_mesh_t *mesh,
339  const cs_cdo_connect_t *connect,
340  const cs_cdo_quantities_t *quant,
341  const cs_time_step_t *time_step);
342
343 /*----------------------------------------------------------------------------*/
353 /*----------------------------------------------------------------------------*/
354
355 void
357  const cs_cdo_connect_t *connect,
358  const cs_cdo_quantities_t *quant,
359  const cs_time_step_t *ts);
360
361 /*----------------------------------------------------------------------------*/
371 /*----------------------------------------------------------------------------*/
372
373 void
375  const cs_cdo_connect_t *connect,
376  const cs_cdo_quantities_t *quant,
377  const cs_time_step_t *ts,
378  bool cur2prev);
379
380 /*----------------------------------------------------------------------------*/
387 /*----------------------------------------------------------------------------*/
388
389 void
391  const cs_cdo_quantities_t *cdoq);
392
393 /*----------------------------------------------------------------------------*/
415 /*----------------------------------------------------------------------------*/
416
417 void
418 cs_thermal_system_extra_post(void *input,
419  int mesh_id,
420  int cat_id,
421  int ent_flag[5],
422  cs_lnum_t n_cells,
423  cs_lnum_t n_i_faces,
424  cs_lnum_t n_b_faces,
425  const cs_lnum_t cell_ids[],
426  const cs_lnum_t i_face_ids[],
427  const cs_lnum_t b_face_ids[],
428  const cs_time_step_t *time_step);
429
430 /*----------------------------------------------------------------------------*/
434 /*----------------------------------------------------------------------------*/
435
436 void
438
439 /*----------------------------------------------------------------------------*/
440
442
443 #endif /* __CS_THERMAL_SYSTEM_H__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
Definition: cs_defs.h:325
unsigned short int cs_flag_t
Definition: cs_defs.h:334
void cs_thermal_system_compute_steady_state(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Build and solve a steady-state thermal system.
Definition: cs_thermal_system.c:746
void cs_thermal_system_destroy(void)
Free the main structure related to the thermal system.
Definition: cs_thermal_system.c:550
void cs_thermal_system_extra_op(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Predefined extra-operations for the thermal system.
Definition: cs_thermal_system.c:873
cs_flag_t cs_thermal_model_type_t
Definition: cs_thermal_system.h:76
cs_thermal_model_type_bit_t
Bit values for physical modelling related to thermal system.
Definition: cs_thermal_system.h:106
@ CS_THERMAL_MODEL_IN_CELSIUS
Definition: cs_thermal_system.h:126
@ CS_THERMAL_MODEL_STEADY
Definition: cs_thermal_system.h:108
@ CS_THERMAL_MODEL_USE_TOTAL_ENERGY
Definition: cs_thermal_system.h:116
@ CS_THERMAL_MODEL_ANISOTROPIC_CONDUCTIVITY
Definition: cs_thermal_system.h:121
@ CS_THERMAL_MODEL_NAVSTO_ADVECTION
Definition: cs_thermal_system.h:109
@ CS_THERMAL_MODEL_USE_TEMPERATURE
Definition: cs_thermal_system.h:114
@ CS_THERMAL_MODEL_USE_ENTHALPY
Definition: cs_thermal_system.h:115
void cs_thermal_system_update(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, bool cur2prev)
Update the quantities related to the thermal module.
Definition: cs_thermal_system.c:843
cs_equation_t * cs_thermal_system_get_equation(void)
Retrieve the main equation related to the thermal system.
Definition: cs_thermal_system.c:576
cs_thermal_system_t * cs_thermal_system_activate(cs_flag_t model, cs_flag_t numeric, cs_flag_t post)
Allocate and initialize the thermal system.
Definition: cs_thermal_system.c:391
bool cs_thermal_system_is_activated(void)
Check if the resolution of the thermal system has been activated.
Definition: cs_thermal_system.c:370
void cs_thermal_system_log_setup(void)
Summary of the main options related to cs_thermal_system_t structure.
Definition: cs_thermal_system.c:945
void cs_thermal_system_set_reference_temperature(cs_real_t ref)
Set the value of the reference temperature associated to the thermal system.
Definition: cs_thermal_system.c:312
cs_real_t * cs_thermal_system_get_face_temperature(void)
Retrieve the current temperature at face values.
Definition: cs_thermal_system.c:595
void cs_thermal_system_init_values(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts)
Set an initial values for all quantities related to this module This is done after the setup step.
Definition: cs_thermal_system.c:811
cs_real_t cs_thermal_system_get_reference_temperature(void)
Retrieve the value of the reference temperature associated to a thermal system.
Definition: cs_thermal_system.c:291
bool cs_thermal_system_needs_navsto(void)
Does the thermal system rely on the advection field associated to the Navier-Stokes equations ?
Definition: cs_thermal_system.c:350
void cs_thermal_system_extra_post(void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
Predefined post-processing output for the thermal system. The prototype of this function is fixed sin...
Definition: cs_thermal_system.c:909
void cs_thermal_system_finalize_setup(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Last step of the setup of the thermal system.
Definition: cs_thermal_system.c:718
void cs_thermal_system_compute(bool cur2prev, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Build and solve the thermal system.
Definition: cs_thermal_system.c:778
void cs_thermal_system_init_setup(void)
Start setting-up the thermal system At this stage, numerical settings should be completely determined...
Definition: cs_thermal_system.c:627
cs_flag_t cs_thermal_system_get_model(void)
Retrieve the model flag related to a thermal system.
Definition: cs_thermal_system.c:332
Definition: mesh.f90:26
Definition: post.f90:26
Definition: cs_cdo_quantities.h:137
Definition: cs_field.h:131
Definition: cs_mesh.h:85
Definition: cs_thermal_system.h:132
cs_field_t * total_energy
Definition: cs_thermal_system.h:161
cs_flag_t numeric
Definition: cs_thermal_system.h:135
cs_field_t * enthalpy
Definition: cs_thermal_system.h:160
cs_real_t ref_temperature
Definition: cs_thermal_system.h:166
cs_equation_t * thermal_eq
Definition: cs_thermal_system.h:141
cs_flag_t post
Definition: cs_thermal_system.h:136
cs_property_t * unsteady_property
Definition: cs_thermal_system.h:146
cs_field_t * temperature
Definition: cs_thermal_system.h:159
cs_property_t * rho
Definition: cs_thermal_system.h:149
cs_property_t * lambda
Definition: cs_thermal_system.h:147
cs_flag_t model
Definition: cs_thermal_system.h:134
cs_real_t * kappa_array
Definition: cs_thermal_system.h:154
cs_property_t * kappa
Definition: cs_thermal_system.h:150
cs_property_t * cp
Definition: cs_thermal_system.h:148
time step descriptor
Definition: cs_time_step.h:64
