8.2
cs_sles_petsc.h
1 #ifndef __CS_SLES_PETSC_H__
2 #define __CS_SLES_PETSC_H__
5  * Sparse Linear Equation Solvers using PETSc
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_matrix.h"
36 #include "cs_sles.h"
43  * Macro definitions
45
47  * Type definitions
49
50 /*----------------------------------------------------------------------------
51  * Function pointer for user settings of a PETSc KSP solver setup.
52  *
53  * This function is called at the end of the setup stage for a KSP solver.
54  *
55  * Note that using the advanced KSPSetPostSolve and KSPSetPreSolve functions,
56  * this also allows setting further function pointers for pre and post-solve
57  * operations (see the PETSc documentation).
58  *
59  * Note: if the context pointer is non-NULL, it must point to valid data
60  * when the selection function is called so that value or structure should
61  * not be temporary (i.e. local);
62  *
63  * parameters:
64  * context <-> pointer to optional (untyped) value or structure
65  * ksp <-> pointer to PETSc KSP context
66  *----------------------------------------------------------------------------*/
67
68 typedef void
69 (cs_sles_petsc_setup_hook_t) (void *context,
70  void *ksp);
71
72 /* Iterative linear solver context (opaque) */
73
74 typedef struct _cs_sles_petsc_t cs_sles_petsc_t;
75
76 /*============================================================================
77  * Global variables
78  *============================================================================*/
79
80 /*=============================================================================
81  * User function prototypes
82  *============================================================================*/
83
84 /*----------------------------------------------------------------------------
85  * Function pointer for user settings of a PETSc KSP solver setup.
86  *
87  * This function is called at the end of the setup stage for a KSP solver.
88  *
89  * Note that using the advanced KSPSetPostSolve and KSPSetPreSolve functions,
90  * this also allows setting further function pointers for pre and post-solve
91  * operations (see the PETSc documentation).
92  *
93  * Note: if the context pointer is non-NULL, it must point to valid data
94  * when the selection function is called so that value or structure should
95  * not be temporary (i.e. local);
96  *
97  * parameters:
98  * context <-> pointer to optional (untyped) value or structure
99  * ksp <-> pointer to PETSc KSP context
100  *----------------------------------------------------------------------------*/
101
102 void
103 cs_user_sles_petsc_hook(void *context,
104  void *ksp);
105
106 /*=============================================================================
107  * Public function prototypes
108  *============================================================================*/
109
110 /*----------------------------------------------------------------------------
111  * Initialize PETSc if needed (calls cs_matrix_petsc_ensure_init).
112  *----------------------------------------------------------------------------*/
113
114 void
115 cs_sles_petsc_init(void);
116
117 /*----------------------------------------------------------------------------*/
147 /*----------------------------------------------------------------------------*/
148
150 cs_sles_petsc_define(int f_id,
151  const char *name,
152  const char *matrix_type,
153  cs_sles_petsc_setup_hook_t *setup_hook,
154  void *context);
155
156 /*----------------------------------------------------------------------------*/
171 /*----------------------------------------------------------------------------*/
172
174 cs_sles_petsc_create(const char *matrix_type,
175  cs_sles_petsc_setup_hook_t *setup_hook,
176  void *context);
177
178 /*----------------------------------------------------------------------------*/
189 /*----------------------------------------------------------------------------*/
190
191 void *
192 cs_sles_petsc_copy(const void *context);
193
194 /*----------------------------------------------------------------------------*/
201 /*----------------------------------------------------------------------------*/
202
203 void
204 cs_sles_petsc_destroy(void **context);
205
206 /*----------------------------------------------------------------------------*/
216 /*----------------------------------------------------------------------------*/
217
218 void
219 cs_sles_petsc_setup(void *context,
220  const char *name,
221  const cs_matrix_t *a,
222  int verbosity);
223
224 /*----------------------------------------------------------------------------*/
247 /*----------------------------------------------------------------------------*/
248
250 cs_sles_petsc_solve(void *context,
251  const char *name,
252  const cs_matrix_t *a,
253  int verbosity,
254  double precision,
255  double r_norm,
256  int *n_iter,
257  double *residual,
258  const cs_real_t *rhs,
259  cs_real_t *vx_ini,
260  cs_real_t *vx,
261  size_t aux_size,
262  void *aux_vectors);
263
264 /*----------------------------------------------------------------------------*/
275 /*----------------------------------------------------------------------------*/
276
277 void
278 cs_sles_petsc_free(void *context);
279
280 /*----------------------------------------------------------------------------*/
296 /*----------------------------------------------------------------------------*/
297
298 bool
301  const cs_matrix_t *a,
302  const cs_real_t *rhs,
303  cs_real_t *vx);
304
305 /*----------------------------------------------------------------------------*/
313 /*----------------------------------------------------------------------------*/
314
315 void
316 cs_sles_petsc_log(const void *context,
317  cs_log_t log_type);
318
319 /*----------------------------------------------------------------------------
320  * \brief Output the settings of a KSP structure
321  *
322  * \param[in] ksp Krylov SubSpace structure
323  *----------------------------------------------------------------------------*/
324
325 void
326 cs_sles_petsc_log_setup(void *ksp);
327
328 /*----------------------------------------------------------------------------*/
340 /*----------------------------------------------------------------------------*/
341
342 void
343 cs_sles_petsc_set_cvg_criteria(const void *context,
344  double rtol,
345  double atol,
346  double dtol,
347  int max_it);
348
349 /*----------------------------------------------------------------------------*/
359 /*----------------------------------------------------------------------------*/
360
361 const char *
362 cs_sles_petsc_get_mat_type(void *context);
363
364 /*----------------------------------------------------------------------------*/
370 /*----------------------------------------------------------------------------*/
371
372 void
374
375 /*----------------------------------------------------------------------------*/
376
378
379 #endif /* __CS_SLES_PETSC_H__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
cs_log_t
Definition: cs_log.h:48
Definition: cs_matrix.h:110
cs_sles_convergence_state_t
Definition: cs_sles.h:56
struct _cs_sles_t cs_sles_t
Definition: cs_sles.h:68
cs_sles_convergence_state_t cs_sles_petsc_solve(void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
Call PETSc linear equation solver.
Definition: cs_sles_petsc.c:1144
cs_sles_petsc_t * cs_sles_petsc_define(int f_id, const char *name, const char *matrix_type, cs_sles_petsc_setup_hook_t *setup_hook, void *context)
Define and associate a PETSc linear system solver for a given field or equation name.
Definition: cs_sles_petsc.c:551
void cs_sles_petsc_set_cvg_criteria(const void *context, double rtol, double atol, double dtol, int max_it)
Set the parameters driving the termination of an iterative process associated to a KSP structure.
Definition: cs_sles_petsc.c:1564
void * cs_sles_petsc_copy(const void *context)
Create PETSc linear system solver info and context based on existing info and context.
Definition: cs_sles_petsc.c:675
void cs_sles_petsc_log_setup(void *ksp)
Definition: cs_sles_petsc.c:1536
void cs_sles_petsc_setup(void *context, const char *name, const cs_matrix_t *a, int verbosity)
Setup PETSc linear equation solver.
Definition: cs_sles_petsc.c:745
const char * cs_sles_petsc_get_mat_type(void *context)
Return matrix type associated with PETSc linear system solver info and context.
Definition: cs_sles_petsc.c:1595
cs_sles_petsc_t * cs_sles_petsc_create(const char *matrix_type, cs_sles_petsc_setup_hook_t *setup_hook, void *context)
Create PETSc linear system solver info and context.
Definition: cs_sles_petsc.c:596
void cs_user_sles_petsc_hook(void *context, void *ksp)
Definition: cs_sles_petsc.c:497
bool cs_sles_petsc_error_post_and_abort(cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx)
Error handler for PETSc solver.
Definition: cs_sles_petsc.c:1418
void cs_sles_petsc_destroy(void **context)
Destroy PETSc linear system solver info and context.
Definition: cs_sles_petsc.c:699
Definition: cs_sles_petsc.h:74
void cs_sles_petsc_log(const void *context, cs_log_t log_type)
Log sparse linear equation solver info.
Definition: cs_sles_petsc.c:1458
void() cs_sles_petsc_setup_hook_t(void *context, void *ksp)
Definition: cs_sles_petsc.h:69
void cs_sles_petsc_init(void)
Definition: cs_sles_petsc.c:513
void cs_sles_petsc_free(void *context)
Free PETSc linear equation solver setup context.
Definition: cs_sles_petsc.c:1366
void cs_sles_petsc_library_info(cs_log_t log_type)
Print information on PETSc library.
Definition: cs_sles_petsc.c:1614
