8.2
cs_param_sles_setup.h
1 #ifndef __CS_PARAM_SLES_SETUP_H__
2 #define __CS_PARAM_SLES_SETUP_H__
5  * Routines to handle the SLES settings relying on a cs_param_sles_t
31  * Local headers
34 #include "cs_param_sles.h"
48  * Macro definitions
50
52  * Type definitions
54
55 /*============================================================================
56  * Global variables
58
59 /*============================================================================
60  * Public function prototypes
62
63 /*----------------------------------------------------------------------------*/
73 /*----------------------------------------------------------------------------*/
74
75 int
76 cs_param_sles_setup(bool use_field_id,
77  cs_param_sles_t *slesp);
78
79 /*----------------------------------------------------------------------------*/
91 /*----------------------------------------------------------------------------*/
92
93 void
94 cs_param_sles_setup_cvg_param(bool use_field_id,
95  const cs_param_sles_t *slesp);
96
97 #if defined(HAVE_PETSC)
98 /*----------------------------------------------------------------------------*/
107 /*----------------------------------------------------------------------------*/
108
109 void
110 cs_param_sles_setup_petsc_cmd(bool use_prefix,
111  const char *prefix,
112  const char *keyword,
113  const char *keyval);
114
115 /*----------------------------------------------------------------------------*/
124 /*----------------------------------------------------------------------------*/
125
126 void
127 cs_param_sles_setup_petsc_ksp(const char *label,
128  cs_param_sles_t *slesp,
129  void *p_ksp);
130
131 /*----------------------------------------------------------------------------*/
139 /*----------------------------------------------------------------------------*/
140
141 void
142 cs_param_sles_setup_petsc_pc_amg(const char *prefix,
143  cs_param_sles_t *slesp,
144  void *p_pc);
145 #endif
146
147 /*----------------------------------------------------------------------------*/
148
150
151 #endif /* __CS_PARAM_SLES_SETUP_H__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:529
Structure and routines handling the SLES ((Sparse Linear Equation Solver) settings stored inside a cs...
void cs_param_sles_setup_cvg_param(bool use_field_id, const cs_param_sles_t *slesp)
Update the settings associated to a cs_sles_t structure and apply those defined in the given cs_param...
Definition: cs_param_sles_setup.c:2848
int cs_param_sles_setup(bool use_field_id, cs_param_sles_t *slesp)
Define cs_sles_t structure in accordance with the settings of a cs_param_sles_t structure (SLES = Spa...
Definition: cs_param_sles_setup.c:2771
char * label
Definition: keywords.h:58
Definition: cs_param_sles.h:64
