8.2
cs_matrix_assembler.h
1 #ifndef __CS_MATRIX_ASSEMBLER_H__
2 #define __CS_MATRIX_ASSEMBLER_H__
5  * Incremental or general construction of matrix.
31  * Local headers
34 #include "cs_defs.h"
36 #include "cs_halo.h"
37 #include "cs_log.h"
38
44  * Macro definitions
46
51 #define CS_MATRIX_DISTANT_ROW_USE_COL_IDX (1 << 0)
52 #define CS_MATRIX_DISTANT_ROW_USE_COL_G_ID (1 << 1)
53 #define CS_MATRIX_EXTERNAL_HALO (1 << 2)
54
55 /*============================================================================
56  * Type definitions
58
61 typedef struct _cs_matrix_assembler_t cs_matrix_assembler_t;
62
65 typedef struct _cs_matrix_assembler_values_t cs_matrix_assembler_values_t;
66
67 /*----------------------------------------------------------------------------*/
81 /*----------------------------------------------------------------------------*/
82
83 typedef void
85  cs_lnum_t db_size,
86  cs_lnum_t eb_size);
87
88 /*----------------------------------------------------------------------------*/
113 /*----------------------------------------------------------------------------*/
114
115 typedef void
117  cs_lnum_t n,
118  cs_lnum_t stride,
119  const cs_lnum_t row_id[],
120  const cs_lnum_t col_idx[],
121  const cs_real_t val[]);
122
123 /*----------------------------------------------------------------------------*/
145 /*----------------------------------------------------------------------------*/
146
147 typedef void
149  cs_lnum_t n,
150  cs_lnum_t stride,
151  const cs_gnum_t row_g_id[],
152  const cs_gnum_t col_g_id[],
153  const cs_real_t val[]);
154
155 /*----------------------------------------------------------------------------*/
166 /*----------------------------------------------------------------------------*/
167
168 typedef void
170
171 /*----------------------------------------------------------------------------*/
183 /*----------------------------------------------------------------------------*/
184
185 typedef void
187
188 /*============================================================================
189  * Global variables
190  *============================================================================*/
191
192 /*=============================================================================
193  * Public function prototypes
194  *============================================================================*/
195
196 /*----------------------------------------------------------------------------*/
209 /*----------------------------------------------------------------------------*/
210
212 cs_matrix_assembler_create(const cs_gnum_t l_range[2],
213  bool separate_diag);
214
233 /*----------------------------------------------------------------------------*/
234
237  bool separate_diag,
238  const cs_lnum_t row_idx[],
239  const cs_lnum_t col_id[],
240  const cs_halo_t *halo);
241
242 /*----------------------------------------------------------------------------*/
248 /*----------------------------------------------------------------------------*/
249
250 void
252
253 /*----------------------------------------------------------------------------*/
264 /*----------------------------------------------------------------------------*/
265
266 void
268  cs_lnum_t n,
269  const cs_gnum_t row_g_id[],
270  const cs_gnum_t col_g_id[]);
271
272 /*----------------------------------------------------------------------------*/
282 /*----------------------------------------------------------------------------*/
283
284 void
286
287 /*----------------------------------------------------------------------------*/
319 /*----------------------------------------------------------------------------*/
320
321 void
323  int flags);
324
325 /*----------------------------------------------------------------------------*/
336 /*----------------------------------------------------------------------------*/
337
338 int
340
341 #if defined(HAVE_MPI)
342
343 /*----------------------------------------------------------------------------*/
352 /*----------------------------------------------------------------------------*/
353
354 void
355 cs_matrix_assembler_set_comm(cs_matrix_assembler_t *ma,
356  MPI_Comm comm);
357
358 #endif /* HAVE_MPI */
359
360 /*----------------------------------------------------------------------------*/
369 /*----------------------------------------------------------------------------*/
370
371 const cs_gnum_t *
373
374 /*----------------------------------------------------------------------------*/
383 /*----------------------------------------------------------------------------*/
384
385 const cs_halo_t *
387
388 /*----------------------------------------------------------------------------*/
397 /*----------------------------------------------------------------------------*/
398
399 bool
401
402 /*----------------------------------------------------------------------------*/
410 /*----------------------------------------------------------------------------*/
411
412 cs_lnum_t
414
415 /*----------------------------------------------------------------------------*/
423 /*----------------------------------------------------------------------------*/
424
425 cs_gnum_t
427
428 /*----------------------------------------------------------------------------*/
436 /*----------------------------------------------------------------------------*/
437
438 cs_lnum_t
440
441 /*----------------------------------------------------------------------------*/
457 /*----------------------------------------------------------------------------*/
458
459 const cs_lnum_t *
461
462 /*----------------------------------------------------------------------------*/
480 /*----------------------------------------------------------------------------*/
481
482 const cs_lnum_t *
484
485 /*----------------------------------------------------------------------------*/
499 /*----------------------------------------------------------------------------*/
500
501 void
503  int rc[4]);
504
505 /*----------------------------------------------------------------------------*/
513 /*----------------------------------------------------------------------------*/
514
515 void
517  cs_log_t log_id,
518  const char *name);
519
520 /*----------------------------------------------------------------------------*/
555 /*----------------------------------------------------------------------------*/
556
559  bool sep_diag,
560  cs_lnum_t db_size,
561  cs_lnum_t eb_size,
562  void *matrix,
568
569 /*----------------------------------------------------------------------------*/
579 /*----------------------------------------------------------------------------*/
580
581 void
583
584 /*----------------------------------------------------------------------------*/
609 /*----------------------------------------------------------------------------*/
610
611 void
613  cs_lnum_t n,
614  const cs_lnum_t row_id[],
615  const cs_lnum_t col_id[],
616  const cs_real_t val[]);
617
618 /*----------------------------------------------------------------------------*/
643 /*----------------------------------------------------------------------------*/
644
645 void
647  cs_lnum_t n,
648  const cs_gnum_t row_g_id[],
649  const cs_gnum_t col_g_id[],
650  const cs_real_t val[]);
651
652 /*----------------------------------------------------------------------------*/
670 /*----------------------------------------------------------------------------*/
671
672 void
674
675 /*----------------------------------------------------------------------------*/
676
678
679 #endif /* __CS_MATRIX_ASSEMBLER_H__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:332
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:310
Definition: cs_defs.h:529
Definition: cs_defs.h:325
cs_log_t
Definition: cs_log.h:48
void cs_matrix_assembler_log_rank_counts(const cs_matrix_assembler_t *ma, cs_log_t log_id, const char *name)
Log rank counts for a given matrix assembler.
Definition: cs_matrix_assembler.c:2979
void cs_matrix_assembler_values_add_g(cs_matrix_assembler_values_t *mav, cs_lnum_t n, const cs_gnum_t row_g_id[], const cs_gnum_t col_g_id[], const cs_real_t val[])
Add values to a matrix assembler values structure using global row and column ids.
Definition: cs_matrix_assembler.c:3279
const cs_gnum_t * cs_matrix_assembler_get_l_range(const cs_matrix_assembler_t *ma)
Return a pointer to local global row range associated with a matrix assembler.
Definition: cs_matrix_assembler.c:2793
bool cs_matrix_assembler_get_separate_diag(const cs_matrix_assembler_t *ma)
Indicate if the matrix assembler is based on a separate diagonal.
Definition: cs_matrix_assembler.c:2827
void cs_matrix_assembler_set_options(cs_matrix_assembler_t *ma, int flags)
Set option flags for a given matrix assembler structure.
Definition: cs_matrix_assembler.c:2631
void() cs_matrix_assembler_values_end_t(void *matrix)
Function pointer to complete the final assembly of matrix coefficients.
Definition: cs_matrix_assembler.h:186
const cs_lnum_t * cs_matrix_assembler_get_row_index(const cs_matrix_assembler_t *ma)
Return a row index associated with a matrix assembler.
Definition: cs_matrix_assembler.c:2903
void cs_matrix_assembler_compute(cs_matrix_assembler_t *ma)
Compute internal structures required by a matrix assembler.
Definition: cs_matrix_assembler.c:2737
cs_matrix_assembler_values_t * cs_matrix_assembler_values_create(const cs_matrix_assembler_t *ma, bool sep_diag, cs_lnum_t db_size, cs_lnum_t eb_size, void *matrix, cs_matrix_assembler_values_init_t *init, cs_matrix_assembler_values_add_t *add, cs_matrix_assembler_values_add_g_t *add_g, cs_matrix_assembler_values_begin_t *begin, cs_matrix_assembler_values_end_t *end)
Create and initialize a matrix assembler values structure.
Definition: cs_matrix_assembler.c:3052
void() cs_matrix_assembler_values_add_t(void *matrix, cs_lnum_t n, cs_lnum_t stride, const cs_lnum_t row_id[], const cs_lnum_t col_idx[], const cs_real_t val[])
Function pointer for addition to matrix coefficients using local row ids and column indexes.
Definition: cs_matrix_assembler.h:116
cs_lnum_t cs_matrix_assembler_get_n_rows(const cs_matrix_assembler_t *ma)
Return the number of rows associated with a matrix assembler.
Definition: cs_matrix_assembler.c:2843
void cs_matrix_assembler_values_done(cs_matrix_assembler_values_t *mav)
Start assembly of matrix values structure.
Definition: cs_matrix_assembler.c:3513
const cs_lnum_t * cs_matrix_assembler_get_col_ids(const cs_matrix_assembler_t *ma)
Return a column ids associated with a matrix assembler.
Definition: cs_matrix_assembler.c:2929
cs_lnum_t cs_matrix_assembler_get_n_columns(const cs_matrix_assembler_t *ma)
Return the number of columns associated with a matrix assembler.
Definition: cs_matrix_assembler.c:2875
int cs_matrix_assembler_get_options(const cs_matrix_assembler_t *ma)
Return the option flags for a given matrix assembler structure.
Definition: cs_matrix_assembler.c:2657
cs_matrix_assembler_t * cs_matrix_assembler_create(const cs_gnum_t l_range[2], bool separate_diag)
Create a matrix assembler structure.
Definition: cs_matrix_assembler.c:2369
cs_gnum_t cs_matrix_assembler_get_n_g_rows(const cs_matrix_assembler_t *ma)
Return the global number of rows associated with a matrix assembler.
Definition: cs_matrix_assembler.c:2859
void cs_matrix_assembler_get_rank_counts(const cs_matrix_assembler_t *ma, int rc[4])
Return info on the number of neighbor ranks a matrix assembler may communicate with.
Definition: cs_matrix_assembler.c:2951
const cs_halo_t * cs_matrix_assembler_get_halo(const cs_matrix_assembler_t *ma)
Return a pointer to the halo structure associated with a matrix assembler.
Definition: cs_matrix_assembler.c:2810
void() cs_matrix_assembler_values_add_g_t(void *matrix, cs_lnum_t n, cs_lnum_t stride, const cs_gnum_t row_g_id[], const cs_gnum_t col_g_id[], const cs_real_t val[])
Function pointer for addition to matrix coefficients using global row ids and column indexes.
Definition: cs_matrix_assembler.h:148
void cs_matrix_assembler_destroy(cs_matrix_assembler_t **ma)
Destroy a matrix assembler structure.
Definition: cs_matrix_assembler.c:2558
cs_matrix_assembler_t * cs_matrix_assembler_create_from_shared(cs_lnum_t n_rows, bool separate_diag, const cs_lnum_t row_idx[], const cs_lnum_t col_id[], const cs_halo_t *halo)
Create a matrix assembler structure based on a given connectivity and associated halo structure.
Definition: cs_matrix_assembler.c:2456
void cs_matrix_assembler_values_finalize(cs_matrix_assembler_values_t **mav)
Finalize matrix assembler values structure.
Definition: cs_matrix_assembler.c:3122
void cs_matrix_assembler_add_g_ids(cs_matrix_assembler_t *ma, cs_lnum_t n, const cs_gnum_t row_g_id[], const cs_gnum_t col_g_id[])
Add entries to a matrix assembler structure.
Definition: cs_matrix_assembler.c:2676
void cs_matrix_assembler_values_add(cs_matrix_assembler_values_t *mav, cs_lnum_t n, const cs_lnum_t row_id[], const cs_lnum_t col_id[], const cs_real_t val[])
Add values to a matrix assembler values structure using local row and column ids.
Definition: cs_matrix_assembler.c:3169
void() cs_matrix_assembler_values_init_t(void *matrix, cs_lnum_t db_size, cs_lnum_t eb_size)
Function pointer for initialization of matrix coefficients using local row ids and column indexes.
Definition: cs_matrix_assembler.h:84
void() cs_matrix_assembler_values_begin_t(void *matrix)
Function pointer to start the final assembly of matrix coefficients.
Definition: cs_matrix_assembler.h:169
Definition: cs_halo.h:77
