1 #ifndef __CS_BASE_CUDA_H__
2 #define __CS_BASE_CUDA_H__
32 #if defined(HAVE_CUDA)
51 #define CS_CUDA_CHECK(a) { \
52 cudaError_t _l_ret_code = a; \
53 if (cudaSuccess != _l_ret_code) { \
54 bft_error(__FILE__, __LINE__, 0, "[CUDA error] %d: %s\n running: %s", \
55 _l_ret_code, ::cudaGetErrorString(_l_ret_code), #a); \
59 #define CS_CUDA_CHECK_CALL(a, file_name, line_num) { \
60 cudaError_t _l_ret_code = a; \
61 if (cudaSuccess != _l_ret_code) { \
62 bft_error(file_name, line_num, 0, "[CUDA error] %d: %s\n running: %s", \
63 _l_ret_code, ::cudaGetErrorString(_l_ret_code), #a); \
71 #define CS_CUDA_WARP_SIZE 32
85 extern int cs_glob_cuda_device_id;
89 extern int cs_glob_cuda_max_threads_per_block;
90 extern int cs_glob_cuda_max_block_size;
91 extern int cs_glob_cuda_max_blocks;
92 extern int cs_glob_cuda_n_mp;
97 extern bool cs_glob_cuda_allow_graph;
128 cs_cuda_mem_malloc_device(
size_t n,
129 const char *var_name,
130 const char *file_name,
154 cs_cuda_mem_malloc_host(
size_t n,
155 const char *var_name,
156 const char *file_name,
180 cs_cuda_mem_malloc_managed(
size_t n,
181 const char *var_name,
182 const char *file_name,
206 cs_cuda_mem_free(
void *
p,
207 const char *var_name,
208 const char *file_name,
232 cs_cuda_mem_free_host(
void *
p,
233 const char *var_name,
234 const char *file_name,
252 cs_cuda_copy_h2d(
void *dst,
274 cs_cuda_copy_h2d_async(
void *dst,
295 cs_cuda_copy_d2h(
void *dst,
316 cs_cuda_copy_d2h_async(
void *dst,
337 cs_cuda_prefetch_h2d(
void *dst,
357 cs_cuda_prefetch_d2h(
void *dst,
375 cs_cuda_copy_d2d(
void *dst,
398 cs_cuda_get_host_ptr(
const void *ptr);
410 cs_cuda_mem_set_advise_read_mostly(
const void *ptr,
423 cs_cuda_mem_unset_advise_read_mostly(
const void *ptr,
445 static inline unsigned int
447 unsigned int block_size)
449 return (n % block_size) ? n/block_size + 1 : n/block_size;
454 #if defined(__NVCC__)
469 template <
typename T>
471 cs_sync_or_copy_h2d(
const T *val_h,
478 const T *_val_d = NULL;
484 size_t size = n_vals *
sizeof(T);
487 CS_CUDA_CHECK(cudaMalloc(&_buf_d, size));
488 cs_cuda_copy_h2d(_buf_d, val_h, size);
489 _val_d = (
const T *)_buf_d;
531 cs_cuda_get_stream(
int stream_id);
546 cs_base_cuda_device_info(
cs_log_t log_id);
557 cs_base_cuda_version_info(
cs_log_t log_id);
568 cs_base_cuda_compiler_info(
cs_log_t log_id);
582 cs_base_cuda_select_default_device(
void);
593 cs_base_cuda_get_device(
void);
cs_alloc_mode_t
Definition: bft_mem.h:50
@ CS_ALLOC_HOST
Definition: bft_mem.h:52
@ CS_ALLOC_HOST_DEVICE_SHARED
Definition: bft_mem.h:57
const void * cs_get_device_ptr_const(const void *ptr)
Return matching device pointer for a given constant pointer.
Definition: cs_base_accel.cxx:888
void cs_sync_h2d(const void *ptr)
Synchronize data from host to device.
Definition: cs_base_accel.cxx:1256
cs_alloc_mode_t cs_check_device_ptr(const void *ptr)
Check if a pointer is associated with a device.
Definition: cs_base_accel.cxx:1031
Definition: cs_defs.h:528
Definition: cs_defs.h:529
Definition: cs_defs.h:325
@ p
Definition: cs_field_pointer.h:67
cs_log_t
Definition: cs_log.h:48
