| double precision | epsicp |
| integer | npotcp |
| | maximal number of tabulation points More...
| integer(c_int), pointer, save | ncharb |
| | Number of coals. More...
| integer(c_int), pointer, save | i_comb_drift |
| | coal with drift (0: without drift (default), 1: with) More...
| integer(c_int), dimension(:), pointer, save | nclpch |
| | Number of classes per coal. More...
| real(c_double), dimension(:), pointer, save | cch |
| real(c_double), dimension(:), pointer, save | hch |
| real(c_double), dimension(:), pointer, save | och |
| real(c_double), dimension(:), pointer, save | sch |
| real(c_double), dimension(:), pointer, save | nch |
| real(c_double), dimension(:), pointer, save | pcich |
| real(c_double), dimension(:), pointer, save | rho0ch |
| real(c_double), dimension(:), pointer, save | thcdch |
| real(c_double), dimension(:), pointer, save | cck |
| real(c_double), dimension(:), pointer, save | hck |
| real(c_double), dimension(:), pointer, save | ock |
| real(c_double), dimension(:), pointer, save | sck |
| real(c_double), dimension(:), pointer, save | nck |
| real(c_double), dimension(:), pointer, save | rhock |
| real(c_double), dimension(:), pointer, save | pcick |
| real(c_double), dimension(:), pointer, save | cpashc |
| real(c_double), dimension(:), pointer, save | h0ashc |
| real(c_double), dimension(:), pointer, save | h02ch |
| real(c_double), dimension(:,:), pointer, save | crepn1 |
| real(c_double), dimension(:,:), pointer, save | crepn2 |
| real(c_double), dimension(:), pointer, save | cp2ch |
| real(c_double), dimension(:), pointer, save | xashsec |
| real(c_double), dimension(:), pointer, save | xashch |
| real(c_double), dimension(:), pointer, save | xwatch |
| integer(c_int), dimension(:), pointer, save | iy1ch |
| integer(c_int), dimension(:), pointer, save | iy2ch |
| integer(c_int), dimension(:), pointer, save | iochet |
| integer(c_int), dimension(:), pointer, save | ioetc2 |
| integer(c_int), dimension(:), pointer, save | ioetwt |
| real(c_double), dimension(:), pointer, save | y1ch |
| real(c_double), dimension(:), pointer, save | a1ch |
| real(c_double), dimension(:), pointer, save | e1ch |
| real(c_double), dimension(:), pointer, save | y2ch |
| real(c_double), dimension(:), pointer, save | a2ch |
| real(c_double), dimension(:), pointer, save | e2ch |
| real(c_double), dimension(:), pointer, save | ahetch |
| real(c_double), dimension(:), pointer, save | ehetch |
| real(c_double), dimension(:), pointer, save | ahetc2 |
| real(c_double), dimension(:), pointer, save | ehetc2 |
| real(c_double), dimension(:), pointer, save | ahetwt |
| real(c_double), dimension(:), pointer, save | ehetwt |
| integer | nsolim |
| integer(c_int), pointer, save | nsolid |
| integer(c_int), dimension(:), pointer, save | ich |
| integer(c_int), dimension(:), pointer, save | ick |
| integer(c_int), dimension(:), pointer, save | iash |
| integer(c_int), dimension(:), pointer, save | iwat |
| real(c_double), dimension(:,:), pointer, save | ehsoli |
| real(c_double), dimension(:), pointer, save | wmols |
| real(c_double), dimension(:), pointer, save | eh0sol |
| integer(c_int), pointer, save | nclacp |
| integer(c_int), dimension(:), pointer, save | ichcor |
| real(c_double), dimension(:), pointer, save | diam20 |
| real(c_double), dimension(:), pointer, save | dia2mn |
| real(c_double), dimension(:), pointer, save | rho20 |
| real(c_double), dimension(:), pointer, save | rho2mn |
| real(c_double), dimension(:), pointer, save | xmp0 |
| real(c_double), dimension(:), pointer, save | xmash |
| integer(c_int), pointer, save | ico |
| integer(c_int), pointer, save | ico2 |
| integer(c_int), pointer, save | ih2o |
| integer(c_int), pointer, save | io2 |
| integer(c_int), pointer, save | in2 |
| integer(c_int), dimension(:), pointer, save | ichx1c |
| integer(c_int), dimension(:), pointer, save | ichx2c |
| integer(c_int), pointer, save | ichx1 |
| integer(c_int), pointer, save | ichx2 |
| real(c_double), dimension(:), pointer, save | chx1 |
| real(c_double), dimension(:), pointer, save | chx2 |
| real(c_double), dimension(:), pointer, save | a1 |
| real(c_double), dimension(:), pointer, save | b1 |
| real(c_double), dimension(:), pointer, save | c1 |
| real(c_double), dimension(:), pointer, save | d1 |
| real(c_double), dimension(:), pointer, save | e1 |
| real(c_double), dimension(:), pointer, save | f1 |
| real(c_double), dimension(:), pointer, save | a2 |
| real(c_double), dimension(:), pointer, save | b2 |
| real(c_double), dimension(:), pointer, save | c2 |
| real(c_double), dimension(:), pointer, save | d2 |
| real(c_double), dimension(:), pointer, save | e2 |
| real(c_double), dimension(:), pointer, save | f2 |
| integer(c_int), pointer, save | ihgas |
| integer(c_int), dimension(:), pointer, save | if1m |
| integer(c_int), dimension(:), pointer, save | if2m |
| integer(c_int), pointer, save | if4m |
| integer(c_int), pointer, save | if5m |
| integer(c_int), pointer, save | if6m |
| integer(c_int), pointer, save | if7m |
| integer(c_int), pointer, save | if8m |
| integer(c_int), pointer, save | if9m |
| integer(c_int), pointer, save | ifvp2m |
| integer(c_int), dimension(:), pointer, save | ixck |
| integer(c_int), dimension(:), pointer, save | ixch |
| integer(c_int), dimension(:), pointer, save | inp |
| integer(c_int), dimension(:), pointer, save | ih2 |
| integer(c_int), dimension(:), pointer, save | ixwt |
| integer(c_int), dimension(:), pointer, save | iym1 |
| integer(c_int), pointer, save | irom1 |
| integer(c_int), pointer, save | immel |
| integer(c_int), dimension(:), pointer, save | itemp2 |
| integer(c_int), dimension(:), pointer, save | irom2 |
| integer(c_int), dimension(:), pointer, save | idiam2 |
| integer(c_int), dimension(:), pointer, save | ix2 |
| integer(c_int), dimension(:), pointer, save | igmdch |
| integer(c_int), dimension(:), pointer, save | igmhet |
| integer(c_int), dimension(:), pointer, save | igmtr |
| integer(c_int), dimension(:), pointer, save | ighco2 |
| integer(c_int), dimension(:), pointer, save | igmdv1 |
| integer(c_int), dimension(:), pointer, save | igmdv2 |
| integer(c_int), dimension(:), pointer, save | igmsec |
| integer(c_int), pointer, save | ibcarbone |
| integer(c_int), pointer, save | iboxygen |
| integer(c_int), pointer, save | ibhydrogen |
| real(c_double), dimension(:,:), pointer, save | ehgaze |
| | engaze(ij) is the massic enthalpy (J/kg) of the i-th elementary gas component at temperature th[j] More...
| integer(c_int), pointer, save | ihy |
| integer(c_int), pointer, save | ih2s |
| integer(c_int), pointer, save | iso2 |
| integer(c_int), pointer, save | ihcn |
| integer(c_int), pointer, save | inh3 |
| integer(c_int), pointer, save | noxyd |
| real(c_double), dimension(:), pointer, save | af3 |
| real(c_double), dimension(:), pointer, save | af4 |
| real(c_double), dimension(:), pointer, save | af5 |
| real(c_double), dimension(:), pointer, save | af6 |
| real(c_double), dimension(:), pointer, save | af7 |
| real(c_double), dimension(:), pointer, save | af8 |
| real(c_double), dimension(:), pointer, save | af9 |
| integer(c_int), pointer, save | ieqnox |
| integer(c_int), pointer, save | imdnox |
| integer(c_int), pointer, save | irb |
| integer(c_int), pointer, save | ihtco2 |
| integer(c_int), pointer, save | ieqco2 |
| integer(c_int), pointer, save | iyco2 |
| integer(c_int), pointer, save | iyhcn |
| integer(c_int), pointer, save | iyno |
| integer(c_int), pointer, save | iynh3 |
| integer(c_int), pointer, save | ihox |
| integer(c_int), pointer, save | ighcn1 |
| integer(c_int), pointer, save | ighcn2 |
| integer(c_int), pointer, save | ignoth |
| integer(c_int), pointer, save | ignh31 |
| integer(c_int), pointer, save | ignh32 |
| integer(c_int), pointer, save | ifhcnd |
| integer(c_int), pointer, save | ifhcnc |
| integer(c_int), pointer, save | ifnh3d |
| integer(c_int), pointer, save | ifnh3c |
| integer(c_int), pointer, save | ifnohc |
| integer(c_int), pointer, save | ifnonh |
| integer(c_int), pointer, save | ifnoch |
| integer(c_int), pointer, save | ifnoth |
| integer(c_int), pointer, save | ifhcnr |
| integer(c_int), pointer, save | icnohc |
| integer(c_int), pointer, save | icnonh |
| integer(c_int), pointer, save | icnorb |
| integer(c_int), pointer, save | igrb |
