| character(len=12) | namgas |
| double precision, pointer, save | pcigas |
| double precision, dimension(:,:), pointer, save | coefeg |
| double precision, dimension(:,:), pointer, save | compog |
| integer | nmaxf |
| integer | nmaxfm |
| integer | nmaxh |
| integer | nmaxhm |
| integer(c_int), dimension(:), pointer, save | ientox |
| integer(c_int), dimension(:), pointer, save | ientfu |
| double precision, save | hstoea |
| double precision, dimension(nmaxhm), save | hh |
| double precision, dimension(nmaxfm), save | ff |
| double precision, dimension(nmaxfm, nmaxhm), save | tfh |
| real(c_double), pointer, save | tinfue |
| real(c_double), pointer, save | tinoxy |
| real(c_double), pointer, save | hinfue |
| real(c_double), pointer, save | hinoxy |
| integer, save | ngazfl |
| integer, save | nki |
| integer, save | nxr |
| integer, save | nzm |
| integer, save | nzvar |
| integer, save | nlibvar |
| integer, save | ikimid = 1 |
| integer, save | mode_fp2m = 1 |
| double precision, save | coef_k = 7.d-2 |
| integer, save | flamelet_zm |
| integer, save | flamelet_zvar |
| integer, save | flamelet_ki |
| integer, save | flamelet_xr |
| integer, save | flamelet_temp |
| integer, save | flamelet_rho |
| integer, save | flamelet_vis |
| integer, save | flamelet_dt |
| integer, save | flamelet_temp2 |
| integer, save | flamelet_hrr |
| integer, dimension(ngazgm), save | flamelet_species |
| integer, save | flamelet_c |
| integer, save | flamelet_omg_c |
| character(len=12), dimension(ngazgm) | flamelet_species_name |
| double precision, dimension(:,:,:,:,:), allocatable | flamelet_library |
| | Library for thermochemical properties in SLFM. More...
| double precision, dimension(:,:,:,:,:,:), allocatable | radiation_library |
| | Library for radiative properties in SLFM. More...
| integer(c_int), dimension(:), pointer, save | ientgf |
| integer(c_int), dimension(:), pointer, save | ientgb |
| real(c_double), dimension(:), pointer, save | qimp |
| real(c_double), dimension(:), pointer, save | fment |
| real(c_double), dimension(:), pointer, save | tkent |
| real(c_double), pointer, save | frmel |
| real(c_double), pointer, save | tgf |
| double precision, save | cebu |
| double precision, save | hgf |
| double precision, save | tgbad |
| integer | ndracm |
| integer, save | ndirac |
| integer, dimension(ndracm), save | irhol |
| integer, dimension(ndracm), save | iteml |
| integer, dimension(ndracm), save | ifmel |
| integer, dimension(ndracm), save | ifmal |
| integer, dimension(ndracm), save | iampl |
| integer, dimension(ndracm), save | itscl |
| integer, dimension(ndracm), save | imaml |
| integer, dimension(ndracm), save | ihhhh |
| integer, save | imam |
| double precision, save | vref |
| double precision, save | lref |
| double precision, save | ta |
| double precision, save | tstar |
| real(c_double), pointer, save | fmin |
| real(c_double), pointer, save | fmax |
| real(c_double), pointer, save | hmin |
| real(c_double), pointer, save | hmax |
| double precision, save | coeff1 |
| double precision, save | coeff2 |
| double precision, save | coeff3 |
| integer(c_int), pointer, save | isoot |
| real(c_double), pointer, save | xsoot |
| real(c_double), pointer, save | rosoot |
| logical(c_bool), pointer, save | use_janaf |
| | use JANAF or not More...
| integer, save | ifm |
| | pointer to specify the mixing rate in isca(ifm) More...
| integer, save | ifp2m |
| | pointer to specify the variance of the mixing rate in isca(ifp2m) More...
| integer, save | ifsqm |
| | pointer to specify the second moment of the mixing rate in isca(ifsqm): More...
| integer, save | ipvm |
| | pointer to specify the transported progress variable ippmod(islfm) >= 2: More...
| integer, save | iygfm |
| | pointer to specify the fresh gas mass fraction in isca(iygfm) More...
| integer, save | icm |
| | the intersection computation mode. If its value is: More...
| integer, save | icp2m |
| | transported variable More...
| integer, save | ifpcpm |
| integer, save | iyfm |
| integer, save | iyfp2m |
| integer, save | icoyfp |
| integer, dimension(ngazgm), save | iym |
| | mass fractions : More...
| integer, dimension(ngazgm), save | ibym |
| integer, save | itemp |
| | state variable (temperature) More...
| integer, save | ifmin |
| | state variable More...
| integer, save | ifmax |
| integer, save | irecvr |
| | state variable: Pointer to the reconstructed variance in case of mode_fp2m = 1 More...
| integer, save | itotki |
| | state variable: Pointer to the total scalar dissipation rate More...
| integer, save | ihrr |
| | state variable: Pointer to volumetric heat release rate More...
| integer, save | ixr |
| | state variable: Pointer to enthalpy defect More...
| integer, save | iomgc |
| integer, save | ickabs |
| | state variable: absorption coefficient, when the radiation modelling is activated More...
| integer, save | it2m |
| | state variable: term More...
| integer, save | it3m |
| | state variable: term, when the radiation modelling is activated More...
| integer, save | it4m |
| integer, save | itsc |
| integer, save | inpm |
| | pointer for soot precursor number in isca (isoot = 1) More...
| integer, save | ifsm |
| | pointer for soot mass fraction in isca (isoot = 1) More...
Module for gas combustion.
